Analog vs Digital
I am making a GPS watch and both the GPS and the LCD use almost all of the digital I/O pins and I still need 5 pushbuttons to change the start, start, volume, etc. I spend about half a second thinking and i realize that none of my analog pins are being used. Problem solved... sort of. I just have no idea what code to use to use the analog pin instead of a digital pin. I figure this is possible because a potentiometer is practically a pushbutton with a ton of values between off and on. (I think like 1023 but thats not the point). So thats that.
Thanks in advance :astonished: :money_mouth_face::money_mouth_face: :astonished:
jrwj
On Arduino 2009 analog pins A0-A4 are digital pins D14-D18.
The reference section on this site, which is duplicated off line in the IDE in the help menu, has a lot of information about the functions that are available to you, organized by category. Have you looked there?
So how will you know when the "button" is pressed or not? Or long-pressed? Or double-pressed?
To address your problem more directly, it is possible to detect multiple push buttons with a resistor network and one analog input.
It is also possible to reduce the number of buttons from 5.
florinc: It is also possible to reduce the number of buttons from 5.
Sure. Most watches only have 3.
I didn't see watches with potentiometer yet :)
florinc: I didn't see watches with potentiometer yet :)
It might make setting the time easier. :)
