Analog writing while using IR input?
I am attempting to write a PWM signal to a motor controller and use an IR Receiver + remote to control it wirelessly. I am currently able to read IR values in my program and print them, but my motor controller is acting funny. One of my 2 motors is running (PWM pin 5 is running, 6 is not). I am using an Arduino Uno R2, I can run a test code with just basic output, and the motors work as expected. I only run into this issue while using the IR library/functions.
I am looking at the github for the IR receiver (GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols) but I am somewhat confused by what I need to do to make the minimal receiver work without a timer and work with my motor controller. Any help would be much appreciated.
 *  MinimalReceiver.cpp
 *  Small memory footprint and no timer usage!
 *  Receives IR protocol data of NEC protocol using pin change interrupts.
 *  On complete received IR command the function handleReceivedIRData(uint16_t aAddress, uint8_t aCommand, bool isRepetition)
 *  is called in Interrupt context but with interrupts being enabled to enable use of delay() etc.
 *  Functions called in interrupt context should be running as short as possible,
 *  so if you require longer action, save the data (address + command) and handle it in the main loop.
 *  Copyright (C) 2020-2021  Armin Joachimsmeyer
 *  armin.joachimsmeyer@gmail.com
 *  This file is part of IRMP https://github.com/ukw100/IRMP.
 *  This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
 *  IRMP is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/gpl.html>.
#include <Arduino.h>
 * Set sensible receive pin for different CPU's
#if defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__) || defined(__AVR_ATtiny87__) || defined(__AVR_ATtiny167__)
#include "ATtinySerialOut.hpp" // Available as Arduino library "ATtinySerialOut"
#  if defined(ARDUINO_AVR_DIGISPARKPRO)
#define IR_INPUT_PIN    9 // PA3 - on Digispark board labeled as pin 9
#  else
#define IR_INPUT_PIN    0 // PCINT0
#  endif
#elif defined(__AVR_ATtiny1616__)  || defined(__AVR_ATtiny3216__) || defined(__AVR_ATtiny3217__)
#define IR_INPUT_PIN    10
#else
//#define DO_NOT_USE_FEEDBACK_LED // activating saves 12 bytes
#endif
 * Second: include the code and compile it.
#include "TinyIRReceiver.hpp"
 * Helper macro for getting a macro definition as string
#define STR_HELPER(x) #x
#define STR(x) STR_HELPER(x)
#define enA 6 //Left-Hand Motor (Right Hand Wheel)
#define enB 5 // Right-Hand Motor (Left Hand Wheel)
#define in1 8 //Black
#define in2 7 //Light Grey
#define in3 1 //Dark Grey
#define in4 0 //Purple Wire
#if defined(__AVR_ATmega32U4__) || defined(SERIAL_USB) || defined(SERIAL_PORT_USBVIRTUAL) || defined(ARDUINO_attiny3217)
    delay(4000); // To be able to connect Serial monitor after reset or power up and before first print out. Do not wait for an attached Serial Monitor!
#endif
    // Just to know which program is running on my Arduino
#if defined(ESP8266)
#endif
    Serial.println(F("START " __FILE__ " from " __DATE__));
    initPCIInterruptForTinyReceiver();
    Serial.println(F("Ready to receive NEC IR signals at pin " STR(IR_INPUT_PIN)));
     * Put your code here
  digitalWrite(in1, 1); // Swap these values if mototres are going wrong direction
  digitalWrite(in2, 0);
  analogWrite(enA, 250);
  analogWrite(enB, 250);
  digitalWrite(in3, 1);
  digitalWrite(in4, 0);
 * This is the function is called if a complete command was received
void ICACHE_RAM_ATTR handleReceivedTinyIRData(uint16_t aAddress, uint8_t aCommand, bool isRepeat)
#elif defined(ESP32)
void IRAM_ATTR handleReceivedTinyIRData(uint16_t aAddress, uint8_t aCommand, bool isRepeat)
#else
void handleReceivedTinyIRData(uint16_t aAddress, uint8_t aCommand, bool isRepeat)
#endif
     * Print only very short output, since we are in an interrupt context and do not want to miss the next interrupts of the repeats coming soon
    Serial.print(F("A=0x"));
    Serial.print(aAddress, HEX);
    Serial.print(F(" C=0x"));
    Serial.print(aCommand, HEX);
    Serial.print(F(" R="));
    Serial.print(isRepeat);
Have you checked for PWM/timer conflicts with this library?
Is the Uno r2 the Uno WiFi Rev2?
Are you using the hardware serial pins (0 and 1) to control a motor?
I think that's what the resource I linked was talking about, but the minimalReceiver example it mentioned is what this was built on top of. It mentioned it didn't use a timer which is a source of some confusion.
I am not using the serial pins to control the motor directly. I have 2 motors hooked up to a dual Hbridge motor controller which takes polarity on the serial pins, and speed on the enA/enB PWM pin.
OK, then.
