analoge Daten Daten auf Processing-Oscilloscope ausgeben
hey,
ich versuche gerade, analoge Daten Daten auf Processing-Oscilloscope auszugeben, aber das Processing Window bleibt leer.
Auf dem normalen Ardunino-Sketch-Serial Monitor sehe ich, wie die Daten sich ändern, aber weder mit noch ohne Arduino-Monitor ist auf dem Processing-Window etwas zu sehen.
Hat jemand eine Idee?
Dies sind die analogen Daten auf Sketch serial Monitor:
H,1022,1022,
H,1023,1022,
H,1023,1022,
H,1023,1023,
H,1021,1023,
H,1022,1023,
H,1023,1023,
H,1023,1023,
H,1022,1023,
H,1023,1023,
H,1022,1023,
H,1022,1021,
H,1022,1023,
H,1022,1023,
H,1023,1023,
H,1023,1022,
H,1022,1022,
Dies ist der Arduino-Code
/* CommaDelimitedOutput sketch */
#define ANALOG_IN_Ch1 0
#define ANALOG_IN_Ch2 1
  int val1 = analogRead(ANALOG_IN_Ch1); /* Reads values from analog Pin0 = Channel1 */
  int val2 = analogRead (ANALOG_IN_Ch2); /* Reads values from analog Pin1 = Channel2 */
  Serial.print('H'); /* Unique header to identify start of message */
  Serial.print(",");
  Serial.print(val1,DEC);
  Serial.print(",");
  Serial.print(val2,DEC);
  Serial.print(",");  /* Note that a comma is sent after the last field */
  Serial.println();  /* send a cr/lf */
  delay(50); //This may be able to be faster than 50ms
Processing-Code (ver. 2.2.1):
* Oscilloscope
* Gives a visual rendering of three analog pins in realtime.
* This Software expands the channel amount of a previous version.
* The previous version was a project that is part of Accrochages
* See http://accrochages.drone.ws
* The author of this adapted software has no relation to Accrochages.
* He thanks them for the great template and the inspiration to write this software.
* The following declaration was part of the original software.
* This is for your information.
* (c) 2008 Sofian Audry (info@sofianaudry.com)
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
import processing.serial.*;
Serial myPort; /* Create object from Serial class */
char HEADER = 'H'; /* character to identify the start of a message */
short LF = 10; /* ASCII linefeed */
short portIndex = 0; /* determines the USB port used */
int[] val = {-1, -1}; /* Variable used for getY function, 2 positions for 2 channels */
int[] valuesCh1; /* The next three variables will hold the data of the window in memory so that they can be pushed and displayed */
int[] valuesCh2;
float zoom; /* Define "zoom" as floating-point variable */
    //size(1014, 690); /* Opens a window of specific size, max size of my laptop screen, delay problems may occur */
    size(600, 400); /* smaller screen => less to calculate => no delay problems */
    myPort = new Serial(this, Serial.list()[portIndex], 9600); /* Open the port that the board is connected to and use the same speed (9600 bps) */
    valuesCh1 = new int[width]; /* Define array with as many elements as x-pixel in window, used for plotting data of Channel1 */
    valuesCh2 = new int[width]; /* ... of Channel2 */
    zoom = 1.0f; /* Start with 1x zoom factor */
    smooth(); /* Drawing images with smooth edges */
/* This function converts a channel data value into pixels shown from
* top of graph (which is the 0 position)
* this function returns an integer value */
int getY(int val)
      return (int)(height - val / 1023.0f * (height - 1));
/* Function that reads the serial string data that were sent by arduino
* Puts out an array with the three values of the arduino
* Function is called in draw function */
int[] getData()
      int[]ChValues = {-1, -1}; /* Define array for this function */
      String message = myPort.readStringUntil(LF); /* Read in the serial data string sent by arduino */
      if(message != null) /* Do this only when a complete valid message was received */
          String [] data  = message.split(","); /* Split the comma-separated message into it's segments */
          if(data[0].charAt(0) == HEADER)       /* Check for header character in the first field, always true for complete message */
              for (int i = 1; i < data.length-1; i++) /* Skip the header and terminate cr and lf => look only at the three data points */
                   ChValues[i-1] = Integer.parseInt(data[i]); /* Write channel data into array, i shifted from data to array by 1 due to header */
         return ChValues; /* Returns array ChValues which contains channel data */
/* This function pushes all the data points of the window one position further to the left, then it adds the data point that was just read */
void pushValue(int[] value)
    for (int i=0; i<width-1; i++)
        valuesCh1[i] = valuesCh1[i+1]; /* Move the data point over by on position */
        valuesCh2[i] = valuesCh2[i+1];
    valuesCh1[width-1] = value[0]; /* Add data point */
    valuesCh2[width-1] = value[1];
/* This function draws the data into the window */
void drawLines()
    int displayWidth = (int) (width / zoom); /* Calculates width of window, considering the x-change if a zoom is set */
    int k = valuesCh1.length - displayWidth; /* This calculates position up to which the data points are shown */
    int x0 = 0; /* x value at very left of window (=0) is assigned to x0 and used for all channels */
    int ya0 = getY(valuesCh1[k]); /* y value of the last shown point is assigned to ya0 for channel1 */
    int yb0 = getY(valuesCh2[k]); /* y value of the last shown point is assigned to yb0 for channel2 */
    for (int i=1; i<displayWidth-1; i++) /* Loop that runs from point k to the very right side of window */
        k++; /* Increment k for next data point */
        int x1 = (int) (i * (width-1) / (displayWidth-1)); /* Calculate next x value */
        int ya1 = getY(valuesCh1[k]); /* Get next y-value for channel1 */
        int yb1 = getY(valuesCh2[k]); /* Get next y-value for channel2 */
        strokeWeight(2);  /* Draw thicker lines */
        stroke(255, 0, 0); /* Draw a red line for channel1 */
        line(x0, ya0, x1, ya1); /* Plot a line segment for channel1 */
        stroke(0, 255, 0); /* Draw a green line for channel2 */
        line(x0, yb0, x1, yb1); /* Plot a line segment for channel2 */
        x0 = x1; /* Shift x value to calculate next line segments */
        ya0 = ya1; /* Shift y-value for channel1 to calculate next line segments */
        yb0 = yb1; /* Shift y-value for channel2 to calculate next line segments */
/* This function draws grid lines into the window
* I spaced the lines so they represent 10% and 20% steps in 2 different colors
* For Signals of 5V max, that is 0.5 & 1.0V steps */
void drawGrid()
    stroke(150, 150, 0);
    line(0, height/5, width, height/5);
    line(0, height*2/5, width, height*2/5);
    line(0, height*3/5, width, height*3/5);
    line(0, height*4/5, width, height*4/5);
    stroke(150, 150, 150);
    line(0, height/10, width, height/10);
    line(0, height*3/10, width, height*3/10);
    line(0, height*5/10, width, height*5/10);
    line(0, height*7/10, width, height*7/10);
    line(0, height*9/10, width, height*9/10);
/* This function allows to zoom in the x-axis of the data
* It runs in the background and notices when the right key is pressed
* Zoom in with pressing "+"
* Zoom out with pressing "-" */
void keyReleased()
    switch (key)
        case '+':
        zoom *= 2.0f;
        println(zoom);
        if ( (int) (width / zoom) <= 1 )
        zoom /= 2.0f;
        case '-':
        zoom /= 2.0f;
        if (zoom < 1.0f)
        zoom *= 2.0f;
/* This is the main function that calls the other functions
* This function runs continuously */
void draw()
    background(1); /* Sets the background of the window */
    drawGrid(); /* Draws the grid into the window */
    val = getData(); /* Reads the data from the three Channels as sent by the arduino into an array */
    if (val[0] != -1) /* If data is in first channel, then carry out function */
        pushValue(val); /* Pushes data down one position and adds one new data point */
    drawLines(); /* Add the next data set to the window */
    if (mousePressed) /*perform action when mouse button is pressed */
       save("D:/Processing/OsciData1.png");  /* save screen shot of data window, but beware image will be overwritten with second mouse click */
ps
hatte zuerst nicht die Einstellung für den COM-Port 6 gefunden, aber wenn ich jetzt einsetze
myPort = new Serial(this, Serial.list()[6], 9600);
erhalte ich eine
ArrayIndexOutOfBoundsExeption :frowning:
wie kann ich das denn jetzt umgehen?
ArrayIndexOutOfBoundsExeption in Java kriegst du natürlich wegen der [6]
Als Java-Dummy würde ich rausfinden wollen:
Was liefert denn Serial.list() ?
Da gibts doch sicher ein .count oder .length ?
Dann rauskriegen, was die Elemente [ 0 ] bis [ Count-1 ] sind :
Wer sagt, dass "COM1" Serial.list() [ 0 ] ist und Serial.list() [ 1 ] "COM2" ?
Das sind nur irgendwelche Windows-Spezifische Namen ...
edit: Eckige Klammern sind mit Vorsicht zu verwenden :wink:
ich bin bei Java nicht nur Dummy sondern eher schon ... naja, ich sags lieber nicht.
Java ist für mich der blanke Horror.
Java ist da sehr gnädig, da du bei sowas Exceptions bekommst. Den Fehler kannst du genauso in C/C++ machen, nur dass da das Programm munter weiterläuft und einfach auf ungültigen Speicher zugreift.
vllt hat jmd einen Link, wie jetzt in
stattdessen der COM port richtig eingestellt wird, wenn nicht als "6"?
vllt sogar einfach "COM6" als Konstante?
Hallo,
lass Dir mit println(Serial.list()); anzeigen, welche COM-Ports Du hast. Der erste hat bei Serial.list()[meinIndex] den Wert meinIndex=0, der nächste meinIndex=1 und so weiter. Wenn Du den gewünschten COM-Port gefunden hast, kannst Du diesen Index übernehmen.
Gruß,
Ralf
ach soo, danke, das sind also relative Werte...
das ist allerdings blöd, ich habe ja oftmals verschiedene und auh verschieden viele serielle Geäte angeschlossen.
Da wäre es doch besser, man könnte hier absolute Werte für den COM port benutzen
Dann iteriere mit einer for-Schleife über die Liste und frag ab an welchem Index dein gewünschter Com-Port steht.
Hallo,
den gewünschten Index kannst Du z.B. so finden (aber Achtung! Es wird nicht auf Fehler geprüft, falls der angegebene Port nicht existiert.)
int meinIndex=0;
for(String s:Serial.list()) {
  if(s.equals("COM6"))
  meinIndex++;
println("Der Index ist: ", meinIndex);
Übrigens: Ich finde Java cool :slight_smile:
Gruß,
Ralf
das ist auch cool, danke :slight_smile:
