hallo,
ich kapere mal den thread, die problematik trifft ziemlich genau mein problem:
ich habe eine modellbau-lok umgebaut, es ist ein esp32-pico drin, ein accu, ein arduino-tt-motor. Ich habe bisher diesen code:
/https://lastminuteengineers.com/creating-esp32-web-server-arduino-ide/
#include <WiFi.h>
#include <WebServer.h>
/* Put your SSID & Password */
const char* ssid = "xxxxxxx"; // Enter SSID here
const char* password = "yyyyyyyy"; //Enter Password here
/* Put IP Address details */
IPAddress local_ip(192, 168, 1, 101);
IPAddress gateway(192, 168, 1, 101);
IPAddress subnet(255, 255, 255, 0);
WebServer server(80);
uint8_t LED1pin = 9;
bool LED1status = LOW;
uint8_t LED2pin = 5;
bool LED2status = LOW;
uint8_t LED3pin = 10;
bool LED3status = LOW;
pinMode(LED1pin, OUTPUT);
pinMode(LED2pin, OUTPUT);
pinMode(LED3pin, OUTPUT);
// WiFi.softAP(ssid, password);
// WiFi.softAPConfig(local_ip, gateway, subnet);
WiFi.begin(ssid, password);
delay(100);
server.on("/", handle_OnConnect);
server.on("/led1on", handle_led1on);
server.on("/led1off", handle_led1off);
server.on("/led2on", handle_led2on);
server.on("/led2off", handle_led2off);
server.on("/led3on", handle_led3on);
server.on("/led3off", handle_led3off);
server.onNotFound(handle_NotFound);
server.begin();
Serial.println("HTTP server started");
server.handleClient();
if (LED1status)
digitalWrite(LED1pin, HIGH);
digitalWrite(LED1pin, LOW);
if (LED2status)
digitalWrite(LED2pin, HIGH);
digitalWrite(LED2pin, LOW);
if (LED3status)
digitalWrite(LED3pin, HIGH);
digitalWrite(LED3pin, LOW);
void handle_OnConnect() {
LED1status = LOW;
LED2status = LOW;
LED3status = LOW;
Serial.println("GPIO4 Status: OFF | GPIO5 Status: OFF | GPIO10 = OFF");
server.send(200, "text/html", SendHTML(LED1status, LED2status, LED3status));
void handle_led1on() {
LED1status = HIGH;
Serial.println("GPIO4 Status: ON");
void handle_led1off() {
LED1status = LOW;
Serial.println("GPIO4 Status: OFF");
void handle_led2on() {
LED2status = HIGH;
Serial.println("GPIO5 Status: ON");
void handle_led2off() {
LED2status = LOW;
Serial.println("GPIO5 Status: OFF");
void handle_led3on() {
LED3status = HIGH;
Serial.println("GPI10 Status: ON");
void handle_led3off() {
LED3status = LOW;
Serial.println("GPI10 Status: OFF");
void handle_NotFound() {
server.send(404, "text/plain", "Not found");
String SendHTML(uint8_t led1stat, uint8_t led2stat, uint8_t led3stat) {
String ptr = "<!DOCTYPE html> <html>\n";
ptr += "<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";
ptr += "<title>LED Control</title>\n";
ptr += "<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n";
ptr += "body{margin-top: 50px;} h1 {color: #444444;margin: 50px auto 30px;} h3 {color: #444444;margin-bottom: 50px;}\n";
ptr += ".button {display: block;width: 80px;background-color: #3498db;border: none;color: white;padding: 13px 30px;text-decoration: none;font-size: 25px;margin: 0px auto 35px;cursor: pointer;border-radius: 4px;}\n";
ptr += ".button-on {background-color: #3498db;}\n";
ptr += ".button-on:active {background-color: #2980b9;}\n";
ptr += ".button-off {background-color: #34495e;}\n";
ptr += ".button-off:active {background-color: #2c3e50;}\n";
ptr += "p {font-size: 14px;color: #888;margin-bottom: 10px;}\n";
ptr += "</style>\n";
ptr += "</head>\n";
ptr += "<body>\n";
ptr += "<h1>ESP32 Web Server</h1>\n";
ptr += "<h3>Using Access Point(AP) Mode</h3>\n";
if (led1stat)
ptr += "<p>LED1 Status: AN</p><a class=\"button button-off\" href=\"/led1off\">AUS</a>\n";
ptr += "<p>LED1 Status: AUS</p><a class=\"button button-on\" href=\"/led1on\">AN</a>\n";
if (led2stat)
ptr += "<p>LED2 Status: AN</p><a class=\"button button-off\" href=\"/led2off\">AUS</a>\n";
ptr += "<p>LED2 Status: AUS</p><a class=\"button button-on\" href=\"/led2on\">AN</a>\n";
if (led3stat)
ptr += "<p>LED3 Status: AN</p><a class=\"button button-off\" href=\"/led3off\">AUS</a>\n";
ptr += "<p>LED3 Status: AUS</p><a class=\"button button-on\" href=\"/led3on\">AN</a>\n";
ptr += "</body>\n";
ptr += "</html>\n";[
return ptr;
der code ist noch lange nicht fertig, die handles sind da noch als LED’s bezeichnet, ich kann aber mit einem der buttons den motor starten und anhalten, mit dem zweiten die drehrichtung ändern. Wie kann ich da jetzt ein “drehregler” statt des dritten buttons zur geschwindigkeits regelung integrieren?
dank und gruss
inka
