Hello, me and some classmates were working over a simple sketch to read an resistance soil moisture sensor. The problem itself come over when we tried to set off the sensor for an x time and power it only when we were asking for the value. When we read the sensor the analog output, which should be between 0 and 1023, only retrieves 0 - 5 numbers. We figure out that the delay after shutting off the sensor was the main problem and also found that giving a 500 ms delay between power up and analogRead() could solve a bit the problem, but the readings were still different from the always-powered-sensor sketch. Next I will attach the code we are using. I would like to know the electronics principles behind the problem. (For now I know that the cumulative ADC analog port need at least 100ms to retrieve a good read, but still doesn't mean any sense to the problem itself)
digitalWrite(7,HIGH); //powers up the sensor
delay(100); //this delay solves the problem accurately only over 500ms
val=analogRead(analogPin); //fills the variable for sensor value
Serial.println("Value string " + String(val)); //printsout value
digitalWrite(7,LOW); //shuts down the sensor
delay(1000); //this delay is the one making the problem,
//if you get rid of it you dont even need the first delay to give time for analogRead
