Sorry to be so slow responding -- got very busy.
The code involved is below. I consider the resort of the code is not relevant to this, since the difficulty occurs in setup(), before anything else has run.
I also had to eliminate all variable definitions to get this to fit in a post.
#include <PinChangeInt.h>
#include <EEPROM.h>
#include <Wire.h>
#include <SPI.h>
#include<RH_RF22.h>
RH_RF22 rf22;
int i;
byte data;
pinMode(shutdownPin, OUTPUT);
digitalWrite(shutdownPin, HIGH); //turns on the 5 v. supply
Serial.begin(57600);
analogReference(DEFAULT); //rely on the power supply voltage standard for analog
pinMode(sonicPin, INPUT); //interrupt 0, for microphone input pulses
pinMode(XBPin, INPUT); //interrupt 1, for radar input
pinMode(radLEDPin, OUTPUT);
digitalWrite(radLEDPin, LOW);
pinMode(trainBtnPin, INPUT_PULLUP);
pinMode(trainLEDPin, OUTPUT);
digitalWrite(trainLEDPin, LOW);
pinMode(txLEDPin, OUTPUT);
digitalWrite(txLEDPin, LOW);
pinMode(batMonPin, INPUT);
pinMode(mainsMonPin, INPUT);
pinMode(peakReadPin, INPUT);
pinMode(alertPin, OUTPUT);
digitalWrite(alertPin, LOW);
pinMode(tempInPin, INPUT);
attachInterrupt(1, int1_ISR, FALLING); //counts microphone pulses for smoke detector audio detection
attachPinChangeInterrupt(XBPin, radarCount, RISING);
radioOK = false;
if(rf22.init()) radioOK = true;
//set up timer 2 as a 0.5 ms clock
cli(); //disable all interrupts
//setting up timer0 for 0.5 ms. (max) cycle
TCCR2A = 0; //clear both timer0 configuration registers: gonna use as a 0.5 msec. timer
TCCR2B = 0;
TCNT2 = 0; //set the counter register to 0, and set
OCR2A = 125; //255x64/16000000 = 0.5 ms.
TCCR2A = TCCR2A | B00000010; //turn on CTC mode
TCCR2B = B00001100; //CS1:2:0 to 101 to operate at clock speed/64
//this also establishes that WGM13:0 = 0100, i.e., CTC mode
TIMSK2 = TIMSK2 | B00000010; //enable the CTC interrupt
sei();
data = EEPROM.read(0);
if (data != 0b10101010) //EEPROM address 0 contains this flag if the sytem has been trained
for(i = 0; i < 3; i++) //use 3 flashes of radar LED (red) to indicate smoke detector detector is untrained
digitalWrite(radLEDPin, HIGH);
wait(300);
wait(300);
trained = false;
trained = true;
targetFreq = EEPROM_ReadInt(1);
Serial.print("SD Freq: "); Serial.println(targetFreq);
for(i = 0; i < 3; i++) //use 3 flashes of train LED (yellow) to indicate smoke detector detector is trained
digitalWrite(trainLEDPin, HIGH);
wait(300);
wait(300);
minTemp = EEPROM_ReadInt(3); //pick the temp/humidity limis from EEPROM
maxTemp = EEPROM_ReadInt(5);
minHum = EEPROM_ReadInt(7);
maxHum = EEPROM_ReadInt(9);
Serial.print("Min. temp. = "); Serial.println(minTemp);
Serial.print("Max. temp. = "); Serial.println(maxTemp);
Serial.print("Min. hum. = "); Serial.println(minHum);
Serial.print("Max. hum. = "); Serial.println(maxHum);
if(radioOK) //3 flashes of TxLED (blue) to indicate radio has initialized
for (i = 0; i < 3; i++)
digitalWrite(txLEDPin, HIGH);
wait(300);
wait(200);
Serial.println(F("Radio Init OK."));
digitalWrite(alertPin, HIGH); //test the beeper
wait(200);
Serial.print("Determining average noise...");
bufIndex = 0;
for(i = 0; i < 20; i++) //compute an initial value for average noise
{ //gathering 20 samples over 10 seconds
data = analogRead(peakReadPin);
noiseVolts = (float(data)/1023.0)*ARef;
if (bufIndex < 20)
noiseArray[bufIndex] = noiseVolts; //initial filling of buffer
bufIndex++;
if (bufIndex == 19)
avgNoise = 0.0;
for(i = 0; i < 20; i++) avgNoise = avgNoise + noiseArray[i];
avgNoise = avgNoise/20;
noiseStart = true;
Serial.print(avgNoise); Serial.println(" v.");
wait(500);
}//for i
tempAvg = 0.0;
humAvg = 0.0;
cycleCount = avgCount + 1; //prevents counting until training is over
nmbrDetects = 0;
clockTick = 0;
secTick = 0;
minTick = 0;
sddAlerts = 0;
notify = false;
noiseDetects = 0;
freqData = false;
freqIndex = 0;
nextTempRdg = 60000; //first temp/humidity readingat 30 sec.
noiseWait = 0;
later = 0;
nextTempWarn = 0;
nextNoise = 2000; //first noise reading 1 sec.
noiseStart = false;
mainsDead = false;
fireCount = 0;
}//setup
