analogRead() >> help
Hello Everybody …
I need someone to help me out to finish up my project, it’s due tomorrow …
the Prof. asked us to attach the photoresistor between analog input 1 and 5 V and attach a 10kΩ resistor between analog input 1 and ground. The program will take a reading from the photoresistor using analogRead() and display it on the 7 segment display once per second. The value should be displayed as a number 0 through 9, with 0 corresponding to dark and 9 corresponding to light. The analogRead() function outputs numbers from 0 to 1023, so I can just divide the analogRead() output by 103 to get numbers between 0 and 9.
How to get that done, although, I wired up everything correctly …
Would anyone please help me to get this project done?
thanks ,
Post your code. Please use
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags.
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
 for (int count = 0; count<10; count++){
 if(count == 0){
 digitalWrite(2, LOW);
 digitalWrite(3, LOW);
 digitalWrite(4, LOW);
 digitalWrite(5, LOW);
 digitalWrite(6, LOW);
 digitalWrite(7, LOW);
 digitalWrite(8, HIGH);
  if(count == 1){
 digitalWrite(2, HIGH);
 digitalWrite(5, HIGH);
 digitalWrite(6, HIGH);
 digitalWrite(7, HIGH);
  if(count == 2){
 digitalWrite(4, HIGH);
 digitalWrite(8, LOW);
  if(count == 3){
  if(count == 4){
  if(count == 5){
 digitalWrite(3, HIGH);
  if(count == 6){
  if(count == 7){
  if(count == 8){
  if(count == 9){
Get rid of this:
and the closing } at the end.
Replace it with:
int count = analogRead(somePin) / 103;
