So I understand that the voltage coming in from the pin is mapped to a value between 0 and 1023. Why this range? what is the source of this range?
Why this range?
Because it is a ten bit analogue to digital converter.
And 2^10=1024
hammy:
And 2^10=1024
Nope.
2^10 == 8.
210 == 1024.
Try googling “2^10”
Mine sez 1024
That's odd - mine does [sup][/sup] either as text, or from the toolbar.
hammy:
And 2^10=1024
AWOL:
Nope.
2^10 == 8.210 == 1024.
byte x1 = 2; //00000010
byte x2 = 10; //00001010
x1 ^= x2;
Serial.print(x1, BIN); //00001000 = 8 = (2 EOR 10) = (00000010 EOR 00001010)
li16:
Hope, the following figure might help you understanding the mechanism for analog voltage (0 - 5V) to undergo transformation/mapped into 0 -1023 (0x0000 - 0x03FF).
Figure-1: ADC Module of Atmega328P MCU
1. When input voltage is 0V, all bits of ADC assume 0s (B9 - B0 = 00 00000000 = 0x0000 = 0)
2. When input voltage is 5V, all bits of ADC assume 1s (B9 - B0 = 11 11111111 = 0x03FF = 1023)
Edit: Diagram of Fig-1 is edited to contain VREF as 5V and not 1.1V. The revision is made in respect of Post#8.
GolamMostafa:
Hope, the following figure might help you understanding the mechanism for analog voltage (0 - VREF0 to undergo transformation/mapped into 0 -1023 (0x0000 - 0x03FF).
Does that seem likely, really?
AWOL:
The diagram of Post#7 has been edited to comply with the text description of VREF = 5V. ++++++++++ again. Ooops, does not take!
GolamMostafa:
x1 ^= x2;
JUNK! The ^ operator in C means "exclusive or" (XOR), in mathematics it means "power of". It is two different things and 2^10 = 1024!
GolamMostafa:
Do you honestly thing that someone who is asking such a fundamental question is going to understand that diagram?
I am having trouble understanding its relevance.
Danois90:
In mathematics?
Really?
Or in BASIC?
Danois90:
Should I remind you that we are playing here (in a predominantly) Programming Forum; so, the ^ performs a bit-wise exclusive (XOR/EOR operation. 2^10 == 8 is the pseudo code of: x = 00000010 XOR 00001010 = 00001000 = 8.
Danois90:
Not according to actual mathmeticians...
Grumpy_Mike:
Do you honestly thing that someone who is asking such a fundamental question is going to understand that diagram?I am having trouble understanding its relevance.
As a poster, I have tried to pour whatever I have thinking that it may add some value to someone? We may recall that the words/sounds that we utter are ultimately linked with some kind of objects; the said diagram is an object that resembles 'ADC and 0- 1023'.
I love these absolutely meaningless discussions that have nothing to do with the OP's post. For what it's worth, according to the ISO 31-11 standard defining mathematical signs and symbols, the only use of the caret (upper case 6, '^') is in describing a conjunction in set theory.
Beyond that, it is also stated that it 'can be used as a surrogate symbol for superscript and exponentiation where superscript is not readily usable' (people actually get paid to write like that).
Not sure what the question mark is about there.
But what you actually do more often than not is pile in so much information that is not relevant in an attempt to help that you just end up confusing and frightening a beginner into thinking things are a lot more complex than they are. Can you please try and resist this temptation.
Grumpy_Mike:
But what you (do), actually do more often than not, is pile in so much information that is not relevant in an attempt to help; (that) you just end up confusing and frightening a beginner (with) (into thinking) things (that) are a lot more complex than they are. Can you please try and resist this temptation(.)(?)
C'mon my fellow pendants, using ^ to denote "to the power of" is pretty well accepted in math and science shorthand. If I type 2^10 into my Wolfram Alpha app, it returns 1024. So who ya gonna believe, Wolfram or Wolfram?
