analogRead stalls entire program when used alongside register programming
I am attempting to utilise the FHT library from open mic labs (OML) to use beat detection with a neopixel strip on an uno board. I have implemented the example provided by OML (FHTExample - Open Music Labs Wiki) in a class however now every time I use analogRead anywhere (using any analog pin) in my program the entire thing completely stops running.
I have a feeling it has something to do with either the timer or how the ADC is used by OML but I don't understand registers anywhere near enough to troubleshoot this by myself.
Thanks in advance!
I am aware the library uses the ADC. My problem is that I need to read from an analog pin elsewhere in my program and this library seems to break the analogRead() function.
I suspect the library is interrupt driven and precludes use of the ADC externally - there's only one ADC and its a hardware resource that can't be both interrupt driven and asynchronously driven at the same time.
The only solutions I can think of involve either understanding and modifying the
library or finding another library that doesnt drive the ADC the same way.
Ahhh ok that makes sense, thanks for the insight!
