I connected a keypad to my Uno board using the voltage divider and AnalogRead method in order to have my digital pins available to control my 4-channel relay board by pressing a specified key. I am able to read which key is pressed through my serial monitor. My experience in programming is limited and I am not quite sure how or where to add the PinMode and DigitalWrite commands. I would like to be able to send and latch a low signal to all 4 relay modules with each having its own key assigned. Below is the program I am using to read the keypad on my serial monitor. Any advise or example is appreciated.
int keypressed = 0;
int keyboardPin = 0; // Analog input pin that the keypad is attached to
int keyboardValue = 0; // value read from the keyboard
void setup(){
Serial.begin(9600); //hardware serial to PC
void loop(){
keyboardValue = analogRead(keyboardPin); // read the keyboard value (0 - 1023)
while (keyboardValue < 25){
//do nothing until a key is pressed
delay(50);
}//end of do nothing till a key is pressed
readkeyboard(); //get the value of key being pressed “keypressed” i.e. 0-9
//read the keyboard routine
void readkeyboard(){
keyboardValue = analogRead(keyboardPin); // read the value (0-1023)
if (keyboardValue <25){keypressed = 0;}
if ((keyboardValue >25) && (keyboardValue < 67)){keypressed = 1;}
if ((keyboardValue >67) && (keyboardValue < 108)){keypressed = 2;}
if ((keyboardValue >108) && (keyboardValue < 162)){keypressed = 3;}
if ((keyboardValue >162) && (keyboardValue < 253)){keypressed = 4;}
if ((keyboardValue >253) && (keyboardValue < 361)){keypressed = 5;}
if ((keyboardValue >361) && (keyboardValue < 479)){keypressed = 6;}
if ((keyboardValue >479) && (keyboardValue < 619)){keypressed = 7;}
if ((keyboardValue >619) && (keyboardValue < 765)){keypressed = 8;}
if ((keyboardValue >765) && (keyboardValue < 819)){keypressed = 9;}
if ((keyboardValue >819) && (keyboardValue < 889)){keypressed = 0;}
if ((keyboardValue >889) && (keyboardValue < 938)){keypressed = 0;}
if (keyboardValue >938){keypressed = 0;}
while (keyboardValue > 25) {
delay (100);
}//wait until key no longer being pressed before continuing
Serial.println(keypressed); // print the value back to the Serial view window on your PC
delay(1000); // wait 1000 milliseconds before the next loop
First thing I notice is that you read the keypad 4 times but you only use it in your readkeyboard() function. maybe this is because using delay() is interfering with reading the keypad?
I got rid of the extra reads and the delays()
also you had 4 if statements setting keypressed = 0 it can be reduced to 1
Changed void readkeyboard() to byte readkeyboard() and moved keyboardvalue and keypressed to be local to that function and let the function return the keypressed variable which is stored in a new key variable in void loop().
finally put in a state machine (switch statement) that can be used to determine what happens after a key is pressed.
byte key;
void setup(){
void loop(){
key = readkeyboard(); //get the value of key being pressed "keypressed" i.e. 0-9
switch (key)
case 0:
Serial.println "State Machine = 0"
// if you dont want anything to happen here dont put anything here
case 1:
Serial.println "State Machine = 1"
buttonOneFunction();
case 2:
Serial.println "State Machine = 2"
buttonTwofunction();
// etc. etc. etc...........
byte readkeyboard(){
byte keypressed = 0;
if ((keyboardValue < 25) || (keyboardValue > 819)){keypressed = 0;}
return(keypressed);
heres a example of a way to deal with the keyboard
const byte relayPin = 13;
//int keyboardValue = 0; // value read from the keyboard
byte prevkey = 0;
pinMode(relayPin, OUTPUT);
byte key = readkeyboard(); //get the value of key being pressed "keypressed" i.e. 0-9
//value of key is now equal to the key being pressed
//if you only want to do this once use a state detection if not remove lines using
//prevkey
if (key != prevkey) {
//the switch is like writting 10 ifs but it allows the processor to sort faster
switch (key) {
case 0:
Serial.println("no key pressed");
digitalWrite(relayPin, LOW);//if LOW is off relay shield would be other way around
case 1:
Serial.println("key one pressed");
digitalWrite(relayPin, HIGH);//if HIGH is on relay shield would be other way around
case 2:
Serial.println("key two pressed");
case 3:
Serial.println("key three pressed");
case 4:
Serial.println("key four pressed");
case 5:
Serial.println("key five pressed");
case 6:
Serial.println("key six pressed");
case 7:
Serial.println("key seven pressed");
case 8:
Serial.println("key eight pressed");
case 9:
Serial.println("key nine pressed");
prevkey = key;
byte readkeyboard() {
int keyboardValue = analogRead(keyboardPin); // read the value (0-1023)
//double read of keyboardValue done on purpose to get a better read
//may not be required
static byte keypressed = 0;
if (keyboardValue < 25) {
keypressed = 0;
if ((keyboardValue >= 25) && (keyboardValue < 67)) {
keypressed = 1;
if ((keyboardValue >= 67) && (keyboardValue < 108)) {
keypressed = 2;
if ((keyboardValue >= 108) && (keyboardValue < 162)) {
keypressed = 3;
if ((keyboardValue >= 162) && (keyboardValue < 253)) {
keypressed = 4;
if ((keyboardValue >= 253) && (keyboardValue < 361)) {
keypressed = 5;
if ((keyboardValue >= 361) && (keyboardValue < 479)) {
keypressed = 6;
if ((keyboardValue >= 479) && (keyboardValue < 619)) {
keypressed = 7;
if ((keyboardValue >= 619) && (keyboardValue < 765)) {
keypressed = 8;
if ((keyboardValue >= 765) && (keyboardValue < 819)) {
keypressed = 9;
if ((keyboardValue >= 819) && (keyboardValue < 889)) {
keypressed = 0;
if ((keyboardValue >= 889) && (keyboardValue < 938)) {
keypressed = 0;
if (keyboardValue >= 938) {
keypressed = 0;
return keypressed;
