Perhaps someone already mentioned this problem: with Arduino Zero analogReference() does not compile....Any suggestion?
You have to use it with differents enums than other arduino :
- AR_INTERNAL (2.2297V)
- AR_EXTERNAL (AREF pin is the ref)
- AR_INTERNAL1V0 (1.0V)
- AR_INTERNAL1V65 (1.65V)
- AR_DEFAULT (1.65V)
These is the analogReference() implementation :
void analogReference( eAnalogReference ulMode )
syncADC();
switch ( ulMode )
case AR_INTERNAL:
case AR_INTERNAL2V23:
ADC->INPUTCTRL.bit.GAIN = ADC_INPUTCTRL_GAIN_1X_Val; // Gain Factor Selection
ADC->REFCTRL.bit.REFSEL = ADC_REFCTRL_REFSEL_INTVCC0_Val; // 1/1.48 VDDANA = 1/1.48* 3V3 = 2.2297
case AR_EXTERNAL:
ADC->REFCTRL.bit.REFSEL = ADC_REFCTRL_REFSEL_AREFA_Val;
case AR_INTERNAL1V0:
ADC->REFCTRL.bit.REFSEL = ADC_REFCTRL_REFSEL_INT1V_Val; // 1.0V voltage reference
case AR_INTERNAL1V65:
ADC->REFCTRL.bit.REFSEL = ADC_REFCTRL_REFSEL_INTVCC1_Val; // 1/2 VDDANA = 0.5* 3V3 = 1.65V
case AR_DEFAULT:
default:
ADC->INPUTCTRL.bit.GAIN = ADC_INPUTCTRL_GAIN_DIV2_Val;
AloyseTech:
You have to use it with different MACRO than other arduino :
They're actually enums, not macros.
Hi Aloyse,
Thanks a lot. Looking at the implementation I see some Gain Multipliers are admitted: e.g.: 1X and DIV2.
My question is: can other multipiers be used? For instance a standard industrial voltage range is:
0 to 2.5 V.
So to have a multiplier which would implement AR_INTERNAL = 2.5 V would be very useful, because an external ref. generator could be eliminated, at least for preliminary testing.
oqibidipo:
Tht's right, I edited the post
Glovisol : check the datasheet for possible value of GAIN register and RESSEL register. RESSEL let you choose the base reference voltage and GAIN the multiplier (/2, X1, X2, X4, X8 and X16).
You will only be able to get 2.5V reference with an external voltage I guess.
Hi Aloyse,
The following enum compiles and should work and produce a 2V internal voltage reference, which could be a fair compromise near to 2.5 V.
ADC->INPUTCTRL.bit.GAIN = ADC_INPUTCTRL_GAIN_2X_Val; // Gain Factor Selection
ADC->REFCTRL.bit.REFSEL = ADC_REFCTRL_REFSEL_INT1V_Val; // 2.0V voltage reference
Furthermore the 1.1 V reference is a high stability precision bandgap reference. According to Table 36.35 variation over wide temp range is +/- 20 mV. The 2.2 V reference would have a tolerance of +/- 40 mV, or +/- 2%, which is a remarkable level of precision.
This could be further refined by linear interpolation of data stored in the chip, by applying data of table 36.38 in reverse, e.g. using data of an ext. temp sensor to correct bandgap voltage, but requires further hard work.
If exactly 2.5V is not needed, you could use the AR_INTERNAL enum, which is supposed to give around 2.23V
Hi Aloise,
I sent you a post which was in error and I deleted it. You are right AR_2V29 can be used for testing before applying AR_EXTERNAL 2.5 V
Apologies,
glovisol
Hi, Aloyse Tech,
I tested your long enumerations and they work! See the PWM change posts. Thanks & my compliments to you.
glovisol
