Analogue input Help!!! please!!!!!!!
Hi, I have just done a lux meter with a graphical display (KS108) and I want to include a temperature meter into it, but I have no free analogue inputs...
what can i do? one of the analogue inputs is used for my lux reading (a5) and the rest are taken for the screen.
Kind Regards
Poli
poli:
Kind Regards
Poli
Cross-posting won't help your cause...
Look at DS18B20 .. takes only 1 Digital input.
I am using that, but as I said I ran out of analogue inputs, I have A5 for the LDR reading and the rest for the GLCD
Regards
ds18b20 doesn't need an analog input. .... Please read the datasheet.
Why are you using analog pins for a glcd?
because the wireing diagram says so... have you got another wireing diagram that doesnt use analogue input ports?
Regards
I dont think you can do that tho…
there I am attaching the code I am using…
do you change the pin number definitions in the code like a normal 16x2 lcd or I have to change it from the library I am using? I need help on this please!
#include <ks0108.h> //  library for LCD
#include "SystemFont5x7.h"   // we need this for character display, included with ks0108.h download
int LDRPINA5 = 5;
int LDRREADING5;
float Resistance = 10.0;
int val = 0;
GLCD.Init(NON_INVERTED);   // load the GLCD library
GLCD.ClearScreen();
GLCD.SelectFont(System5x7);  // choose font to use (note this needs to match the #include above
  countdown(4);
  GLCD.ClearScreen();
GLCD.DrawRect(0, 0, 127, 63,BLACK);
GLCD.CursorTo(1, 1);
// set cursor to top left of LCD (uses character coordinates
// not pixel coordinates
GLCD.Puts("   Welcome To The"); // sends strings to LCD. Does not wrap to next line!
GLCD.CursorTo(1, 2);
GLCD.Puts("#AMAZING LUX METER#");
GLCD.CursorTo(0, 3);
GLCD.Puts("Project Developed by:");
GLCD.CursorTo(1, 4);
GLCD.Puts("Sixto Llorens Zabala");
GLCD.CursorTo(1, 5);
GLCD.Puts("Student No: 08154978");
delay(900);
GLCD.ClearScreen();
GLCD.Puts("Lux Given in Lumens:"); // sends strings to LCD. Does not wrap to next line!
GLCD.CursorTo(1, 3);
GLCD.Puts("       LUX\t=  ");
void loop(void)
LDRREADING5 = analogRead(5);
float Vout5=(LDRREADING5);
float lux5=((Vout5));
GLCD.CursorTo(12,3);
GLCD.PrintNumber(lux5);
GLCD.ClearScreen();
delay(20);
void countdown(int count){
  while(count--){  // do countdown
    GLCD.CursorTo(10,3);   // first column, second row (offset is from 0)
    GLCD.PutChar(count + '0');
Thanks in advance
anyone?
