I'm trying to use an arduino uno to read the voltage of a sensor on an engine.
The temperature sensor on the engine is connected to the ECU which has an inbuilt 1k pullup resistor. I find that if I connect the sensor to the arduino, it changes the value that the ECU see.
I didn't think that the arduino would have an effect of the voltage of the sensor, but it's obviously is. Is there anyway around this?
This is because the Arduino is only a 5V system and your car's ECU is not. It sounds like the Arduino input is clamping the sensor signal.
Try connecting the sensor to the Arduino through a potential divider circuit so that the Arduino never sees a voltage greater than 5V, that will stop the sensor voltage from being pulled down.
Thanks for the feedback
The sensor on the engine is 5v, with a 1k pull up resistor from the ECU. I didn't think the arduino would have had this much affect on the voltage being read. What it the resistance of the analogue inputs?
