Analogue pins to digital problem
Hi everyone, so I am making this project and I have used every single I/O pin except D0,1,12. Since 0 and 1 are for RX and TX I am not gonna use them. I have decided to use the analogue pins as my digital inputs and one digital output(I need 3 buttons and 1 led for indication).
So I did this to the code:
const int MemwriteLOW = A0; //button to A0 to write the LOW value in the EEPROM
const int MemwriteHIGH = A1; //button to A1 to write the HIGH value in the EEPROM
const int MemwriteCLR = A2; //button to A2 to clear the values in the EEPROM
const int MemwriteBLINK = A3; //LED to A3 to indicate memory write in EEPROM
byte MemwriteLOWstate = 0;
byte MemwriteHIGHstate = 0;
byte MemwriteCLRstate = 0;
 pinMode(MemwriteLOW, INPUT); //button low as input
  pinMode(MemwriteHIGH, INPUT); //button low as input
  pinMode(MemwriteCLR, INPUT); //button low as input
  pinMode(MemwriteBLINK, OUTPUT); //led as output
So the problem is here. This should work but it doesn't. I have a small part of the code which checks if the button is pressed and overall that part works everywhere except with the analogue pins. The led pin is working like a charm, but A0 and A1 do nothing, and A3 if pressed does the code for A2 and if pressed for a longer period it does its own code.
Here is the sample code for the buttons(its the same for the three it just has different values):
 MemwriteLOWstate = digitalRead(MemwriteLOW);
if (MemwriteLOWstate == HIGH) {
   WriteStuffLOW(encoder0Pos);
   digitalWrite(MemwriteBLINK, HIGH);
   delay(300);
   digitalWrite(MemwriteBLINK, LOW);
   delay(300);
Does anyone know why I am getting this weird behavior?
How are your buttons wired? Do they have pull down resistors to ground? The best way to wire switches is one side of the switch to ground and the other side of the switch to an input and the input will be set to INPUT_PULLUP in pinMode. The switch will read LOW when pushed.
I have connected the buttons according to the Arduino example, a resistor to GND and the arduino pin on one side and +5V on the other side, so I think I got this right, I have other buttons on the board and they are working like a charm.
Yeah so I decided to look at the buttons and discovered that they are a different model from the ones I have already used, I connected them properly now and everything works.
Thanks for the help!
