analogWrite sensor LDR
hello everyone.
I wanted to ask about the value of "4" on the analogWrite (ledPin, val / 4). what is the function of a "4" and the explanation.
complete the following code:
int ledPin = 9;      // LED connected to digital pin 9
int analogPin = 3;   // potentiometer connected to analog pin 3
int val = 0;         // variable to store the read value
  pinMode(ledPin, OUTPUT);   // sets the pin as output
  val = analogRead(analogPin);
  analogWrite(ledPin, val / 4);
The code I will use as a light detection sensor with LDR and Led as the indicator, if the LDR is exposed to light and the LED will be ON if the LDR is not exposed to light then the LED will be OFF.
Thanx 4all :slight_smile:
analogRead() returns a value from 0-1023, analogWrite() expects a value from 0-255, so you div the read value by 4.
Rob
You'll probably want some threshold ( a value in the range 0..1023) defined to decided what is, and what is not, "exposed to light".
