AnalogWrite() Uno and Nano value of 240 // Sketch
hello everyone ...
I would like to control a motor. I noticed when I use the arduino uno that the rotation speed with analogwrite (240) turns faster than when I use the arduino nano 33 ble with the same code.
Why does the motor of the arduino nano 33 ble turn more slowly with the same pin assignment.
#define drehrichtungMotorLinks 6
#define drehrichtungMotorRechts 7
#define drehgeschwindigkeitMotorLinks 9
#define drehgeschwindigkeitMotorRechts 10
void setup(){
  //TCCR2B = TCCR2B & 0b11111000 | 0x01;         // Timer 2 zu 31300HZ. Timer 2 kontrolliert  die Pins 9 und 10
  pinMode(drehrichtungMotorLinks, OUTPUT);     // Drehrichtung des linken Motors vorgegeben
  pinMode(drehrichtungMotorRechts, OUTPUT);    // Drehrichtung des rechten Motors vorgegeben
  void loop(){
         digitalWrite(drehrichtungMotorLinks, HIGH);
         digitalWrite(drehrichtungMotorRechts, HIGH);
        analogWrite(drehgeschwindigkeitMotorLinks, 240);
        analogWrite(drehgeschwindigkeitMotorRechts, 240);
Could it be due the fact that the Nano 33 is a 3.3V device, as its name implies, whereas the Uno is a 5V device ?
How is the motor powered and connected to the Arduinos ?
oh yes, the operating voltage is lower for arduino nano than for a uno. how can I fix the problem that still rotates faster?
The Arduino nano is directly connected to a motor driver. this motor driver is then directly connected to the brushless DC motor.
Do you use something like this? This can be powered separately.
this is what I used: motor driver of: tmcm 1630 and a voltage converter: velleman k1823 to reduce the voltage of the battery from 36v to 9v input voltage.
@horemansp // @UKHeliBob
Where does the power for the motors come from ?
the motors are powered by a lithium ion battery with 36 volts. the arudino nano is then connected to an input voltage of 12 volts via a voltage converter.
Your description is becoming quote complicated to follow
Please post a schematic of your project. A photo of a hand drawn
better to understand?
Thanks, but we could do with more detail. For instance, is there a common GND between all of teh devices ?
all devices are connected to the same gnd. with the arduino uno it works without any problems with the code only with the nano it runs very, very slowly.
@UKHeliBob
Which input of your TMCM-1630 do you use?
I'm sorry but for a project of this level, you must have a schematic.
PLEASE, include ALL power connections and label ALL connections to Nano, motor drivers and DC-DC converter.
This will help us to give some more informed answers.
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
Yes, that diagram is called a BLOCK DIAGRAM, and is useful to describe the concept of the project, but a SCHEMATIC, or CIRCUIT diagram shows all the internal detail needed to probe, verify or even to assemble the project.
You must answer this question.
What I see in the documentation for pin2 would indicate that there will be a difference between the 5v and 3.3v pwm.
2 Velocity analogue Used for velocity control in stand alone operation by
supplying external 0 – 10V signal
Problem was solved. The problem is that the operating voltage of nano is designed for 3.3 V. and not 5 V. Therefore the input voltage of the motor driver had to be increased. Thanks anyway for the help and for the tip on how to post a post next time.
