AND Bitwise SPI question
Hi guys!,
trying to overcome this awkward n00b-phase, I have a question about some BITwise magic I came accros in a sketch which is used to read from an EEPROM through SPI bit banging. Here is the piece of code:
int read_8(int address)
char bit;
char inbit;
char index;
int value = 0;
chip_select_low();
send_8(READ);
send_address(address);
for(index = 0; index < 8; index++)
bit = digitalRead(From_Data_Out);
inbit = bit & 0x01;
if(inbit == 1)
value = value + (0x80>>index);
sclk();
sclk();
chip_select_high();
return value;
If I’m right this piece of code reads out a byte bit by bit starting with the MSB and ending with the LSB. I think I understand the code except this line:
inbit = bit & 0x01;
Why is this line nessecary? Can’t the ‘bit’ variable not be used directly for the following if-statement?
I hope somebody can give me an explanation about this :slight_smile:
cheers!
Why is this line nessecary? Can't the 'bit' variable not be used directly for the following if-statement?
digitalRead will return either HIGH or LOW. HIGH is defined as 1 and LOW is defined as zero. The line "inbit = bit & 0x01;" will make certain that inbit is indeed 1 or 0. Since we know already however that bit is either 1 or 0, it really isn't needed and so you could use "bit" directly as you suggested.
Looks like it could be simplified even more as:
    int value         = 0;
    unsigned int bit  = 0x80;
    chip_select_low();
    send_8(READ);
    do
        if ( digitalRead(From_Data_Out) & 0x01 )
            value |= bit;
        sclk();
    } while ( bit >>= 1 )
    chip_select_high();
    return value;
