I'm working on musical board game that runs on an arduino and a couple of shift register chains.
I use daisy chained 7 segment LEDS to shift out players' scores as the games goes on. I would like to add a component that displays the chord and key in play at a given time.
A 16 segment display seems suitable for the letter component (A-G), but I'm not sure how I can display the sharp and flat symbols. Do you have any suggestions?
I'm not married to LED display if there is a better alternative, practically and aesthetically.
Common anode 10x13mm if possible. I'll control it with two shift registers and shift out integer equivalents of the binary that lines up with its segment denotations.
Hi, how do you display "#" with those 16-seg displays? Won't that note symbol look just like a "b"?
have you considered lcd displays? 16x2 character are the most common and cheapest. Each character is made up of a 5x7 grid of dots, and I'm pretty sure you can define your own characters if you can't find suitable ones built-in.
