"and" & if
a simple question for some.
i need both things to becorrect using and..
What have I messed up with my "and"?if((rdsBuffer[0] =='\0')+(smsmuteState == LOW));
thanks
Plus is NOT and. && is.
If statements rarely end with semicolons.
Hackdub:
thanks
   if  ((rdsBuffer[0] =='\0') && (smsmuteState == LOW))
       //insert code
Like that?
bingo... thanks
I want my GSM module not to text if "sms mute state" is HIGH, but it still sends sms does...
I have checked "smsmuteState" and it is definately hi, as the LCD displayes correctly "SMS Mute"
Have I got the %% correct?
        if((rdsBuffer[0] =='\0')&&(smsmuteState == LOW));
          sms.beginSMS("0xxx66404142");
          lcd.clear();
          lcd.setCursor(0, 1);
          lcd.print(" SITE FAULT ! ");
          lcd.clear();
          lcd.print("SMS SENDING");
          sms.print("myemail\xFEgmail.com ");
          sms.print(Names[NameIndex]);
          sms.print("  ");
          sms.print(channel);
          sms.print(" SHUT DOWN");
          sms.endSMS();
          lcd.clear();
          lcd.print("SMS SENT OK");
          delay(5000);
          lcd.clear();
        if (smsmuteState == HIGH);
          lcd.print("SMS MUTE!");
          delay(5000);
          lcd.clear();
What was said about Mr. if and Mr Semicolon not being friends?
:wink: tx
nope still texting although that input is hi
          sms.beginSMS("0xxxx6404142");
          lcd.clear();
          lcd.clear();
          sms.print("xxxxxxx\xFEgmail.com ");
          sms.print("  ");
          sms.print(channel);
          sms.endSMS();
          lcd.clear();
          delay(5000);
          lcd.clear();
          delay(5000);
          lcd.clear();
See my earlier reply.
May need braces too.
I wonder why?
You are not testing for HIGH!
Confused.. what you mean?
          sms.beginSMS("0xxxxxxxx142");
          lcd.clear();
          lcd.clear();
          sms.print("mrdxxxxxxxin\xFEgmail.com ");
          sms.print("  ");
          sms.print(channel);
          sms.endSMS();
          lcd.clear();
          delay(5000);
          lcd.clear();
          delay(5000);
          lcd.clear();
I have pulled that pin hi, and im looking for a low to text?
smsmute pin
That pin? What does that mean? Use names that reflect what you are using in the code.
I've pulled smsmutePin High
full code
// libraries
#include <GSM.h>
#include <LiquidCrystal.h>
#include <Si4703_Breakout.h>
#include <Wire.h>
// PIN Number
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;     // include a 'true' parameter to enable debugging
GSM_SMS sms;
GSMScanner scannerNetworks;
GSMModem modemTest;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 9, 8);
// This section descibes button connection.
const int buttonPin = A0;
const int upbuttPin = A2;
const int downbuttPin = A3;
const int selectPin =  A1;
const int smsmutePin = 6;
//radio connection
int resetPin = 10;
int SDIO = A4;
int SCLK = A5;
///////////freq map
int Freq[][5] ={
    995, 899 , 921, 943, 0  }//WV
  {895 , 917, 939, 964, 0  }};//kvh
const int NUM_FREQS = sizeof Freq[0]/sizeof Freq[0][0];
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
int upbuttState = 0;         // variable for reading the pushbutton status
int downbuttState = 0;
int selectbuttState = 0;
int smsmuteState = 0;
int select = 0;
Si4703_Breakout radio(resetPin, SDIO, SCLK);
int channel;
int volume;
char rdsBuffer[20];
// Save data variables
String IMEI = "";
// serial monitor result messages
String errortext = "ERROR";
/// NAME INDEX
char * Names[] = {
  "Wenvoe  ", "Kilvey Hill  "};
const int NAME_COUNT = sizeof Names / sizeof Names[0];
int NameIndex = 0;
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(upbuttPin, INPUT);
  pinMode(downbuttPin, INPUT);
  pinMode(selectPin, INPUT);
  pinMode(smsmutePin, INPUT);
  // pinMode(ledPin, OUTPUT);
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
    radio.powerOn();
    radio.setVolume(0);
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("FM Rover by DM");
  delay(3000);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("--Please  Wait--");
  lcd.print("-GSM Connecting-");
  // Serial.println("GSM networks scanner");
  scannerNetworks.begin();
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      lcd.clear();
      lcd.print("Connected");
      delay(2000);
      lcd.clear();
      Serial.println("Not connected");
      lcd.clear();
      lcd.print("NO GSM !");
  // get modem parameters
  // IMEI, modem unique identifier
  //  Serial.print("Modem IMEI: ");
  IMEI = modemTest.getIMEI();
  IMEI.replace("\n","");
  if(IMEI != NULL);
  //  Serial.println(IMEI);
///////////////// SELECT SITE NAME //////////////////////
  while(select==0){
    // read the state of the pushbutton value:
    upbuttState = digitalRead(upbuttPin);
    downbuttState = digitalRead(downbuttPin);
    selectbuttState = digitalRead(selectPin);
    smsmuteState = digitalRead(smsmutePin);
    // if it is, the upbuttState is HIGH:
    if (upbuttState == HIGH) {
      // increment name
      NameIndex = (NameIndex+1)%NAME_COUNT;
    } // Wrap around
    //if it is, the upbuttState is HIGH:
    if (downbuttState == HIGH) {
      // increment name
      NameIndex = (NameIndex-1)%NAME_COUNT;
      if (NameIndex < 0) {
        NameIndex=NAME_COUNT-1;
    } // Wrap around
    if (selectbuttState == HIGH){
      select=1;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("> ");
    lcd.setCursor(2,0);
    lcd.print (Names[NameIndex]);
    lcd.setCursor(0,1);
    lcd.print("Select Location ");
    lcd.clear();
    volume --;
    if (volume < 0) volume = 15;
    radio.setVolume(volume);
    displayInfo();
    for(int i=0; i<NUM_FREQS; i++) {
      channel=Freq[NameIndex][i];
      if (channel != 0) {
        //channel = 995; // Radio 1
        radio.setChannel(channel);
        displayInfo();
        radio.readRDS(rdsBuffer, 10000);
        //lcd.clear();
        lcd.setCursor(0, 0);
        lcd.print(rdsBuffer);
        delay(5000);
        lcd.print(Names[NameIndex]);
          sms.beginSMS("0xxxxxx142");
          lcd.clear();
          lcd.clear();
          sms.print("xxxxxxxxx\xFEgmail.com ");
          sms.print("  ");
          sms.print(channel);
          sms.endSMS();
          lcd.clear();
          delay(5000);
          lcd.clear();
          delay(5000);
          lcd.clear();
void displayInfo()
  //////////////////DISPLAY GSM INFO ON LCD ///////////////
  // currently connected carrier
  //  Serial.print("Current carrier: ");
  //  Serial.println(scannerNetworks.getCurrentCarrier());
  //lcd.clear();
  // Print a message to the LCD.
  lcd.print(scannerNetworks.getCurrentCarrier());
  // returns strength and ber
  // signal strength in 0-31 scale. 31 means power > 51dBm
  //  // BER is the Bit Error Rate. 0-7 scale. 99=not detectable
  // Serial.print("Signal Strength: ");
  //  Serial.print(scannerNetworks.getSignalStrength());
  //  Serial.println(" [0-31]");
  // set up the LCD's number of columns and rows:
  lcd.setCursor(15, 1);
  lcd.print("%");
  lcd.setCursor(13, 1);
  lcd.print(scannerNetworks.getSignalStrength().toInt() * 100 / 32);
  if(IMEI != NULL);
What was the purpose of that?
          delay(5000);
          lcd.clear();
Are you hoping those 4 lines are controlled by the "if"? The indentation says "yes" but the code says "no".
And you test to see that it is LOW:
If it is:
          lcd.clear();
          lcd.clear();
          sms.print("  ");
          sms.print(channel);
          sms.endSMS();
Now, I could be wrong, but that looks like code to send an SMS when smsmuteState is LOW (not HIGH).
Exactly I dont want it to send sms when the pin is high..
          sms.beginSMS("077xxxx42");
          lcd.clear();
          lcd.clear();
          sms.print("xxxxxxn\xFEgmail.com ");
          sms.print("  ");
          sms.print(channel);
          sms.endSMS();
          lcd.clear();
          delay(5000);
          lcd.clear();
         {lcd.setCursor(0, 1);
          delay(5000);
          lcd.clear();}
And, it doesn't. So, what is the problem?
well pin6 smsmutePin is currently held high, & it still sends SMS!
Where do you actually read the state of the pin? In setup()! Try actually reading it in loop().
AHH DOH :wink:
thanks, still learning.
Take care David
