"<" and ">" working opposite from what I think it should
I was having trouble with a sketch in using the “<” and “>” Boolean operators. They seem to be operating opposite from what I think they should. I have attached a very simple test showing the issue I am having. In this sketch I have defined a numer as “NUM” with a value of one “1” and have incremented it “NUM++” each time the loop runs. I wanted it to stop when NUM is greater than 10. well, it will not run! When I change the “<” to a “>” it runs and stops at 10, just as designed. Why do I have to use a “>” rather than a “<”? It does not seem logical!
//Incremental Number test
void setup(){
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println(“Number Increment Test While NUM<10”);
int NUM=0;
while(NUM<10);
Serial.print(NUM);
Serial.write(’\n’); // Carriage Return
NUM++;
What comes after the while statement must be in curly brackets. You have nothing there.
var = 0;
while(var < 200){
  // do something repetitive 200 times
  var++;
void setup(){
   while (!Serial) {
Serial.println("Number Increment Test While NUM<10");
int NUM=0;
while(NUM<10){
  Serial.print(NUM);
Serial.write('\n'); //  Carriage Return
NUM++;
The ; at the end of the while should not be there, you want this:
while(NUM<10)
Serial.print(NUM);
NUM++;
Then the stuff in { } will execute until the while condition becomes not true.
Darn fingers are too slow!
Hee, hee!
try this variant
int NUM=0;
  while(NUM<10)  Serial.println(NUM++);
try this variant
Try it, by all means, but then put the conditional expression on a separate line inside curly braces {}, to make it easier to read.
