Android APP - Bluetooth Mate SIlver- Arduino
Hello,
I have made an Android app for controlling two devices connected to an Arduino : led and fan. At first, I have tried to see if the app works using the LED 13 on the Arduino board. It worked, at my commands sent from the app, the arduino was controlling on/off the devices. The initial code was :
#include <OneWire.h>
#include <DallasTemperature.h>
#define pinSenzorLumina A0
#define pinSenzorPrezenta A1
#define ledPin 13
#define ONE_WIRE_BUS 4
//const int ledPin = 13;
// led pin
unsigned int temperatura;
unsigned int lumina;
unsigned int prezenta;
int state = 0;
// if state is 1, the LED will turn on and
// if state is 0, the LED will turn off
int flag = 0;         // a flag to prevent duplicate messages
int cmd = -1;
String inputString = "";
boolean stringComplete = false;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  sensors.begin();
  //status LED
  if (inputString.startsWith("1")) {
    int ledStatus = digitalRead(13);
    Serial.println(ledStatus);
    //status cooler
  else if (inputString.startsWith("2")) {
    int coolerStatus = digitalRead(13);
    Serial.println(coolerStatus);
    //start LED
  else if (inputString.startsWith("31")) {
    //stop LED
  else if (inputString.startsWith("30")) {
   digitalWrite(ledPin, LOW);
    //start cooler
  else if (inputString.startsWith("41")) {
    //stop cooler
  else if (inputString.startsWith("40")) {
    //INTRUDER
  else if (inputString.startsWith("8")) {
    int miscare = analogRead(A0);
    if (miscare > 150) {
      Serial.println("1");
    else {
      Serial.println("0");
  Serial.flush();
  sensors.requestTemperatures();
  temperatura = sensors.getTempCByIndex(0);
  lumina =  analogRead(pinSenzorLumina);
  prezenta = analogRead(A0);
  inputString = "";
void serialEvent() {
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    inputString += inChar;
    if (inChar == '\n' || inChar == '\r') {
      stringComplete = true;
After that, I've written another code, setting the inputs/outputs for my sensors and output devices. I have also wanted to implement the concept of home automation, by using a photoresistor and a temperature sensor. Infortunately, after I have uploaded the new code to Arduino, the sistem doesn't work, neither the automatisation part, neither the controll by app. I'm new at this, so if you could give me an advice regarding the code or possibile problems, maybe with the Bluetooth Module.
I have tested using serial monitor and the only command processed is turning the LED on and display the status of the devices - for the fan, the system reads it as if it was ON, but the fan is not activated.
The after code is :
#define pinSenzorLumina A2
#define pinSenzorTemperatura 4
#define pinVentilator A0
#define pinLed 13
boolean stareVentilator;
int state = 0;
// if state is 1, the LED will turn on and             if state is 0, the LED will turn off
int cmd = -1;
String inputString ="";
pinMode(pinLed, OUTPUT);
pinMode (pinVentilator, OUTPUT);
digitalWrite (pinVentilator, LOW);
digitalWrite (pinLed, LOW);
//Pentru comunicare prin bluetooth TREBUIE 115200
//    Serial.begin(9600);
      sensors.begin();
 //status lLED
 if (inputString.startsWith("1")){
   //status cooler
 } else if (inputString.startsWith("2")){
   int coolerStatus = digitalRead(A0);
   //start led
 } else if (inputString.startsWith("31")) {
   digitalWrite(pinLed, HIGH);
   //stop led
 } else if (inputString.startsWith("30")) {
   digitalWrite(pinLed, LOW);
   //start cooler
 } else if (inputString.startsWith("41")) {
   digitalWrite(pinVentilator, HIGH);
   //stop cooler
 } else if (inputString.startsWith("40")) {
   digitalWrite(pinVentilator, LOW);
   //trimitere status miscare
 } else if (inputString.startsWith("8")) {
   if (miscare > 150){
   else {
   Serial.flush();
int lumina =  analogRead(A2);
if (lumina < 1){
        digitalWrite(pinLed, HIGH);   }
     else {
        digitalWrite(pinLed, LOW);}
int temperatura = sensors.getTempCByIndex(0);
stareVentilator=false;
  if(temperatura < 0 && stareVentilator){
               stareVentilator = false;
   if(temperatura > 0 && !stareVentilator){
                 stareVentilator = true;
inputString ="";
Any ideas or opinions are welcomed. Thank you!
You really should have read How to use this forum before posting. (Especially item #7.)
ie Your code and any error messages should always be placed between
[code]code tags[/code]
. Posting it inline as you have done makes it much harder to read or copy and paste for diagnosis, and often also corrupts the code with italics or smilies.
It's still not too late to edit your post and do this. You'll make potential helpers much happier. :slight_smile:
Also, get rid of all of those unnecessary blank lines, and format your code correctly by hitting Ctrl-T or ">Tools >Auto Format" in the IDE.
Sorry, you are right, hope that now it's ok. Thank you!
AnaGh:
That's an improvement. Thanks.
It's getting a bit late here, and there are quite a number of things that could be addressed in your code, but I'm sure someone will come along and help.
