Good morning, I need help with a code which I do not understand how to send data to the android.
The code from esp sends data to the android and it works perfectly sends data from the ds18b20 sensors. Allows to receive data is Termik4Temp to be downloaded from the gplay store.
Besides, I would like to receive data on the second esp but I do not really know how to do it.
I receive data on the second esp but the indications are not correct reading 110 or 50.
Below is a fragment of the esp satellite code.
WiFiUDP Udp;
unsigned int localUdpPort = 12346;
char incomingPacket[255];
char replyPacekt[] = "Dokonano pomiaru temperatur :-)";
wifi_init();
Serial.print(".");
Serial.println(" connected");
Udp.begin(localUdpPort);
Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.localIP().toString().c_str(), localUdpPort);
int packetSize = Udp.parsePacket();
if (packetSize)
// receive incoming UDP packets
sensors.requestTemperatures();
Serial.printf("Received %d bytes from %s, port %d\n", packetSize, Udp.remoteIP().toString().c_str(), Udp.remotePort());
int len = Udp.read(incomingPacket, 255);
if (len > 0)
incomingPacket[len] = 0;
delay(750);
Serial.printf("UDP packet contents: %s\n", incomingPacket);
float temp1;
temp1 = sensors.getTempCByIndex(0);
String Pomiar1;
Pomiar1=String(temp1, 1);
Serial.println(Pomiar1);
temp1 = sensors.getTempCByIndex(1);
String Pomiar2;
Pomiar2=String(temp1, 1);
Serial.println(Pomiar2);
temp1 = sensors.getTempCByIndex(2);
String Pomiar3;
Pomiar3=String(temp1, 1);
Serial.println(Pomiar3);
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
String tempp1 ;
tempp1 += "n1=";
tempp1 += Pomiar1;
tempp1 += "x";
tempp1 += "n2=";
tempp1 += Pomiar2;
tempp1 += "x";
tempp1 += "n3=";
tempp1 += Pomiar3;
tempp1 += "x";
Udp.println(tempp1);
Udp.endPacket();
And here is the piece of code that I want to receive data from 1 esp.
Client.begin(12346);
const int port=80;
int i=0;
udpsend();
char serverack = Client.parsePacket();
Serial.println(serverack);
if (serverack)
tempp1=Client.read();
Serial.print("temperatura 1 : ");
Serial.println(tempp1);
void udpsend()
const char ip[]="10.10.0.55";
Client.beginPacket(ip,12346);
Client.write(serdata);
Client.endPacket();
return;
I will be extremely grateful for your help.
greetings Piotr
