Android tablet as keypad for RFID door entry
Hi All,
I'm pretty new to the Arduino / RPi world. My Arduino is in the mail and I should be receiving it anytime now.
I have been trying to use the RPi as an I/O controller but was recommended to use the Arduino instead.
As the title states, I would like to use an Android tablet as a touchscreen keypad. User swipes his RFID card, and he will be prompted to enter his pin. I see this working with a hard keypad, my question is, is it possible to use a soft keypad?
I may plan to use the Arduino and RPi as a slave / master scnerio and have them communicate via I2C, as I see this may be the only option to have this type of scenario to work...maybe a php interface or an app built on the Android...but I'm reaching out to anyone that has experience in this type of project with a tablet, or even a robust touchscreen 7 inch ?
Thank you in advance!
I don't know enough about android. Can you force it to enter a lock-down mode that it can't exit? Otherwise the person can close your app, browse the internet or do other things not related to a keypad. Plus it's expensive keypad. A regular keypad is no more than a couple of dollars.
eros:
You can get an Arduino-compatible touchscreen colour LCD display up to about 5" for £30-£60. Would that be big enough? It would make your solution a lot simpler.
liudr:
I was hoping for a robust soft keypad on a touchscreen. It actually doesn't have to be Android, it can be any reliable touchscreen out there.
PeterH:
eros:
Do you have a picture of the solution you're describing? Also would this mean I wouldn't need an RPi integration? Someone told me the Arduino isn't able to display any type of graphics.
With a TFT LCD display using the libraries UTFT, UTouch and my library TFT_Extension, you can do this very easily.
In fact, I even give an example keypad/password sketch.
HazardsMind:
Hi HazardsMind,
Where is the sketch you speak of?
eros:
Search for Arduino touchscreen. There are plenty of suppliers, such as adafruit, ladyada, sparkfun. Typically they are up to around 3" but bigger sizes are available too.
Look in the Examples folder, its called Password.
My apologies, I did not update that sketch in a long time so it is using the old ITDB02 libraries, instead of the UTFT and UTouch libraries.
Here is the fixed version.
#include <Wire.h>
#include <UTouch.h>
#include <UTFT.h>
#include <TFT_Extension.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
//myGLCD(RS,WR,CS,RST,ALE,mode);
UTFT myGLCD(ITDB32S,A1,A2,A0,A3,A5);   //
UTouch  myTouch(13,10,11,12,A4);
TFT_Extension myTFT(&myGLCD, &myTouch, LANDSCAPE);
char * text[4][3] = {
  {"1","2","3"},
  {"4","5","6"},
  {"7","8","9"},
  {"*","0","#"}
char Pass[5];
char master[5] = "2651";
int Pcount=0;
int XC,YC;
int PassCounter=0;
byte orient = LANDSCAPE;
  myGLCD.InitLCD(LANDSCAPE);
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch(LANDSCAPE);
  myTouch.setPrecision(PREC_EXTREME);
  for(int line = 0; line <= 239; line++) // custom background color
    myGLCD.setColor(0, 0, line);//text color White
    myGLCD.drawLine(0, line, 319, line);
  PassWord_makeButton();
  PassWord_buttonText();
  //RUN();
  myTouch.read();
  int tx = myTouch.TP_X;
  int ty = myTouch.TP_Y;
  XC= constrain (map(tx, 205, 3900,0,239),0,239);
  YC= constrain (map(ty, 300, 3850,0,319),0,319);
  GetNum(XC,YC);
void RUN()
  //  while(1) // Not using the Loop() function,
  //    myTouch.read();
  //    int tx = myTouch.TP_X;
  //    int ty = myTouch.TP_Y;
  //    XC= constrain (map(tx, 205, 3900,0,239),0,239);
  //    YC= constrain (map(ty, 300, 3850,0,319),0,319);
  //    GetNum(XC,YC);
void PassWord_makeButton()
  for(int y = 0; y < 300;y+=100)
    for(int x = 0; x < 200; x+=50)
      drawButton(20+x,90+y,50+x,30+y); // this will draw the button on the screen by so many pixels
  return;
void drawButton(int x1, int y1,int x2, int y2)
  myGLCD.setColor(170,170,170); // grey
  myGLCD.fillRoundRect(y1-3, x1+3, y2-3, x2+3);//Button Shading
  myGLCD.setColor(255, 255, 255); // white
  myGLCD.fillRoundRect(y1, x1, y2, x2);// outter button color
  myGLCD.setColor(200,0,0); // red
  myGLCD.fillRoundRect(y1-5, x1+5, y2+5, x2-5);//inner button color
  return;
void PassWord_buttonText()
  myGLCD.setFont(BigFont);
  myGLCD.setBackColor(200, 0, 0);
  myGLCD.setColor(255,255,255);
  for(int tr = 0; tr < 300; tr+=100)
    for(int tc = 0; tc < 200; tc+=50)
      char *myText = text[tc/50][tr/100];
      myGLCD.print(myText,52+tr,27+tc,0); //this will print the number into the center of the buttons
void GetNum(int tx,int ty) {
  char * lastText;
      if(myTFT.TouchButton((90+tr),(20+tc),(30+tr),(50+tc),XC,YC)) // this check to see if any of the buttons were pressed, then it sends the corresponding number to the "check" function
        check(*myText);
void check(char pass)
  Pass[Pcount] = pass;  //store incoming numbers in an array
  myGLCD.print(Pass,CENTER, 1); // show the password as it is being entered
  if(Pcount == 3)// only when the array is filled, does it check the numbers
    if(!strcmp(Pass, master)) // compare the password to the master password
      myGLCD.print("GOOD",CENTER, 1);
      myGLCD.print("    ",CENTER, 1);
      myGLCD.print("FAIL",CENTER, 1);
    clearPassword(); // Clear the password
  Pcount++;
  if(Pcount > 3) // this ensure the count does not exceed the maximum lenght of the password
    Pcount = 0;
    PassCounter = 0;
void clearPassword()
  byte i = 3;
  while(i != 0)
    Pass[i--] = NULL;
