I am building a system that requires sending an integer/decimal value from android app via BLE based Blugeiga module BLE112, to arduino for further controlling process. But on using simple Serial.read(), I am getting some random number, most of the time, its 255. Where do I need to make modifications to get the correct value?
Are you making sure that there is actually something available before reading it ? As you have not posted your code it is difficult to give advice. Would this query not be better in the Programming section of the forum ?
My arduino code involves just reading the UART data. The code is as following-
#include <SoftwareSerial.h>
int datalength=10;
char str[10];
int data;
char senddata;
int i=0;
//itoa(senddata, str1, 10); //Turn value into a character array
if (Serial.available()>0)
while(Serial.available())
//i++;
//data= Serial.read();
Serial.write(Serial.read());
// if (i>0)
//Serial.println(str);
My android BLE write characteristic code is as below-
BluetoothGattService RxService = mBluetoothGatt.getService(RX_SERVICE_UUID); // getting service indicated by BLE device
showMessage(“mBluetoothGatt null” + mBluetoothGatt);
if (RxService == null) {
showMessage(“Rx service not found!”); // if no service found
broadcastUpdate(DEVICE_DOES_NOT_SUPPORT_UART);
return;
BluetoothGattCharacteristic RxChar = RxService.getCharacteristic(RX_CHAR_UUID);
if (RxChar == null) {
showMessage(“Rx charateristic not found!”);
broadcastUpdate(DEVICE_DOES_NOT_SUPPORT_UART); // if no characteristics found
return;
RxChar.setValue(value); //sets the value and the Rx stores the value to be sent over BLE
boolean status = mBluetoothGatt.writeCharacteristic(RxChar); //status is set on setting the “value”
Log.d(TAG, “data written over BLE” + RxChar + value);
System.out.println(“DATA SENT:”);
System.out.println(RxChar);
System.out.println(value);
Please suggest what am I missing to get the data in the correct format?
Not fully read all the code…
but…
#include<SoftwareSeria.h>
will need a line such as:
SoftwareSerial mySerial(6,7);//Rx on pin 6, Tx on pin 7
mySerial.begin(9600); // Initilise the software serial with 9600 baud.
Serial.begin(9600); //Start the arduino Serial line for PC comms via USB
void loop(){
if (mySerial.available){ //If there is some byte available from the software serial...
Serial.println(mySerial.read()); // Print it out via the Arduino Serial connection to the PC.
