Anfänger braucht Hilfe bei LED Stuerung mit Arduino
Das komische ist das die Led von Anfang an immer ein bisschen leuchtet
und wenn Sie eig "HIGH" haben sollte nach der Zeit dann passiert gar nichts,
wo ist da mein Fehler?
MFG
// # Scriptname : DS1307_Test.pde
// # Author     : Peter Schmelzer, Oliver Kraus
// # Date       : 2011-04-08
// # Editor     : Lauren from DFRobot
// # Date       : 30.12.2011
// # Description:
// # Test file for the DS1307new library. Assumes that you have a DS1307
// # connected to the I2C-Bus of your Arduino and that it has a battery backup.
// # Update the library and sketch to compatible with IDE V1.0 and earlier
// # Version    : 1.0
// INCLUDE
#include <Wire.h>                       // For some strange reasons, Wire.h must be included here
#include <DS1307new.h>
// DEFINE
// VARIABLES
uint16_t startAddr = 0x0000;            // Start address to store in the NV-RAM
uint16_t lastAddr;                      // new address for storing in NV-RAM
uint16_t TimeIsSet = 0xaa55;            // Helper that time must not set again
// SETUP
  pinMode(2, INPUT);                    // Test of the SQW pin, D2 = INPUT
  digitalWrite(2, HIGH);                // Test of the SQW pin, D2 = Pullup on
   PLEASE NOTICE: WE HAVE MADE AN ADDRESS SHIFT FOR THE NV-RAM!!!
                  NV-RAM ADDRESS 0x08 HAS TO ADDRESSED WITH ADDRESS 0x00=0
                  TO AVOID OVERWRITING THE CLOCK REGISTERS IN CASE OF
                  ERRORS IN YOUR CODE. SO THE LAST ADDRESS IS 0x38=56!
  RTC.setRAM(0, (uint8_t *)&startAddr, sizeof(uint16_t));// Store startAddr in NV-RAM address 0x08
   Uncomment the next 2 lines if you want to SET the clock
   Comment them out if the clock is set.
   DON'T ASK ME WHY: YOU MUST UPLOAD THE CODE TWICE TO LET HIM WORK
   AFTER SETTING THE CLOCK ONCE.
//  TimeIsSet = 0xffff;
//  RTC.setRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));
  Control the clock.
  Clock will only be set if NV-RAM Address does not contain 0xaa.
  DS1307 should have a battery backup.
  RTC.getRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));      // 54 auf 55 stellen und datum + Zeiteinstellen
  if (TimeIsSet != 0xaa55)
    RTC.stopClock();
    RTC.fillByYMD(2014,9,1);
    RTC.fillByHMS(11,36,0);
    RTC.setTime();
    TimeIsSet = 0xaa55;
    RTC.startClock();
    RTC.getTime();
   Control Register for SQW pin which can be used as an interrupt.
  RTC.ctrl = 0x00;                      // 0x00=disable SQW pin, 0x10=1Hz,
                                        // 0x11=4096Hz, 0x12=8192Hz, 0x13=32768Hz
  RTC.setCTRL();
  Serial.println("DS1307 Testsketch");
  Serial.println("Format is \"hh:mm:ss dd-mm-yyyy DDD\"");
  uint8_t MESZ;
  MESZ = RTC.isMEZSummerTime();
  Serial.print("MEZ=0, MESZ=1 : ");
  Serial.println(MESZ, DEC);
  Serial.println();
// MAIN (LOOP)
  RTC.getTime();
  if (RTC.hour < 10)                    // correct hour if necessary
    Serial.print("0");
    Serial.print(RTC.hour, DEC);
  Serial.print(":");
  if (RTC.minute < 10)                  // correct minute if necessary
    Serial.print("0");
    Serial.print(RTC.minute, DEC);
  Serial.print(":");
  if (RTC.second < 10)                  // correct second if necessary
    Serial.print("0");
    Serial.print(RTC.second, DEC);
  Serial.print(" ");
  if (RTC.day < 10)                    // correct date if necessary
    Serial.print("0");
    Serial.print(RTC.day, DEC);
  Serial.print("-");
  if (RTC.month < 10)                   // correct month if necessary
    Serial.print("0");
    Serial.print(RTC.month, DEC);
  Serial.print("-");
  Serial.print(RTC.year, DEC);          // Year need not to be changed
  Serial.print(" ");
  switch (RTC.dow)                      // Friendly printout the weekday
    case 1:
      Serial.print("MON");
      break;
    case 2:
      Serial.print("TUE");
      break;
    case 3:
      Serial.print("WED");
      break;
    case 4:
      Serial.print("THU");
      break;
    case 5:
      Serial.print("FRI");
      break;
    case 6:
      Serial.print("SAT");
      break;
    case 7:
      Serial.print("SUN");
      break;
  Serial.print(" seconds since 1.1.2000:");
  Serial.print(RTC.time2000, DEC);
  uint8_t MESZ = RTC.isMEZSummerTime();
  Serial.print(" MEZ=0, MESZ=1 : ");
  Serial.print(MESZ, DEC);
  Serial.print(" - Address in NV-RAM is: ");
  RTC.getRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
  Serial.print(lastAddr, HEX);
  lastAddr = lastAddr + 1;              // we want to use it as addresscounter for example
  RTC.setRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
  if (TimeIsSet == 0xaa55)              // check if the clock was set or not
    Serial.println(" - Clock was set!");
    Serial.println(" - Clock was NOT set!");
  delay(1000);                          // wait a second
  int Zeit = RTC.second + RTC.minute *60 + RTC.hour *3600;      //Sketch für Led
   int rot = 9;
if (Zeit >= 53100){
   digitalWrite(rot, HIGH);}
   digitalWrite(rot, LOW);
   if(Zeit <= 60000){
