Anfänger braucht Hilfe bei LED Stuerung mit Arduino
Sorry hatte ich vergessen ist aber immer noch auch wenn ich den Sketch so mit pinMode schreibe.
MFG
// # Scriptname : DS1307_Test.pde
// # Author     : Peter Schmelzer, Oliver Kraus
// # Date       : 2011-04-08
// # Editor     : Lauren from DFRobot
// # Date       : 30.12.2011
// # Description:
// # Test file for the DS1307new library. Assumes that you have a DS1307
// # connected to the I2C-Bus of your Arduino and that it has a battery backup.
// # Update the library and sketch to compatible with IDE V1.0 and earlier
// # Version    : 1.0
// INCLUDE
#include <Wire.h>                       // For some strange reasons, Wire.h must be included here
#include <DS1307new.h>
// DEFINE
// VARIABLES
uint16_t startAddr = 0x0000;            // Start address to store in the NV-RAM
uint16_t lastAddr;                      // new address for storing in NV-RAM
uint16_t TimeIsSet = 0xaa55;            // Helper that time must not set again
// SETUP
  pinMode(2, INPUT);                    // Test of the SQW pin, D2 = INPUT
  digitalWrite(2, HIGH);                // Test of the SQW pin, D2 = Pullup on
   PLEASE NOTICE: WE HAVE MADE AN ADDRESS SHIFT FOR THE NV-RAM!!!
                  NV-RAM ADDRESS 0x08 HAS TO ADDRESSED WITH ADDRESS 0x00=0
                  TO AVOID OVERWRITING THE CLOCK REGISTERS IN CASE OF
                  ERRORS IN YOUR CODE. SO THE LAST ADDRESS IS 0x38=56!
  RTC.setRAM(0, (uint8_t *)&startAddr, sizeof(uint16_t));// Store startAddr in NV-RAM address 0x08
   Uncomment the next 2 lines if you want to SET the clock
   Comment them out if the clock is set.
   DON'T ASK ME WHY: YOU MUST UPLOAD THE CODE TWICE TO LET HIM WORK
   AFTER SETTING THE CLOCK ONCE.
//  TimeIsSet = 0xffff;
//  RTC.setRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));
  Control the clock.
  Clock will only be set if NV-RAM Address does not contain 0xaa.
  DS1307 should have a battery backup.
  RTC.getRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));      // 54 auf 55 stellen und datum + Zeiteinstellen
  if (TimeIsSet != 0xaa55)
    RTC.stopClock();
    RTC.fillByYMD(2014,9,1);
    RTC.fillByHMS(11,36,0);
    RTC.setTime();
    TimeIsSet = 0xaa55;
    RTC.startClock();
    RTC.getTime();
   Control Register for SQW pin which can be used as an interrupt.
  RTC.ctrl = 0x00;                      // 0x00=disable SQW pin, 0x10=1Hz,
                                        // 0x11=4096Hz, 0x12=8192Hz, 0x13=32768Hz
  RTC.setCTRL();
  Serial.println("DS1307 Testsketch");
  Serial.println("Format is \"hh:mm:ss dd-mm-yyyy DDD\"");
  uint8_t MESZ;
  MESZ = RTC.isMEZSummerTime();
  Serial.print("MEZ=0, MESZ=1 : ");
  Serial.println(MESZ, DEC);
  Serial.println();
// MAIN (LOOP)
  RTC.getTime();
  if (RTC.hour < 10)                    // correct hour if necessary
    Serial.print("0");
    Serial.print(RTC.hour, DEC);
  Serial.print(":");
  if (RTC.minute < 10)                  // correct minute if necessary
    Serial.print("0");
    Serial.print(RTC.minute, DEC);
  Serial.print(":");
  if (RTC.second < 10)                  // correct second if necessary
    Serial.print("0");
    Serial.print(RTC.second, DEC);
  Serial.print(" ");
  if (RTC.day < 10)                    // correct date if necessary
    Serial.print("0");
    Serial.print(RTC.day, DEC);
  Serial.print("-");
  if (RTC.month < 10)                   // correct month if necessary
    Serial.print("0");
    Serial.print(RTC.month, DEC);
  Serial.print("-");
  Serial.print(RTC.year, DEC);          // Year need not to be changed
  Serial.print(" ");
  switch (RTC.dow)                      // Friendly printout the weekday
    case 1:
      Serial.print("MON");
      break;
    case 2:
      Serial.print("TUE");
      break;
    case 3:
      Serial.print("WED");
      break;
    case 4:
      Serial.print("THU");
      break;
    case 5:
      Serial.print("FRI");
      break;
    case 6:
      Serial.print("SAT");
      break;
    case 7:
      Serial.print("SUN");
      break;
  Serial.print(" seconds since 1.1.2000:");
  Serial.print(RTC.time2000, DEC);
  uint8_t MESZ = RTC.isMEZSummerTime();
  Serial.print(" MEZ=0, MESZ=1 : ");
  Serial.print(MESZ, DEC);
  Serial.print(" - Address in NV-RAM is: ");
  RTC.getRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
  Serial.print(lastAddr, HEX);
  lastAddr = lastAddr + 1;              // we want to use it as addresscounter for example
  RTC.setRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
  if (TimeIsSet == 0xaa55)              // check if the clock was set or not
    Serial.println(" - Clock was set!");
    Serial.println(" - Clock was NOT set!");
  delay(1000);                          // wait a second
  int Zeit = RTC.second + RTC.minute *60 + RTC.hour *3600;      //Sketch für Led
  int rot = 8;
   pinMode (8, OUTPUT);
if (Zeit >= 60000){
   digitalWrite(rot, HIGH);}
   digitalWrite(rot, LOW);
   if(Zeit <= 70000){
