Also mein Projekt nimmt Form an…
Ich habe ein interessantes Projekt mit einer Alarmanlage gesehen. Das ist Hier:
http://www.electroschematics.com/10760/arduino-gsm-home-security-alarm-system/
Den original Code hierfür ist dieser hier:
* Arduino Home Security GSM Alarm
* An Arduino + SIM900A Project
* T.K.Hareendran
* Tested at TechNode PROTOLABZ
* 21 August 2014
* http:// www.electroschematics.com
//Connect the Tx pin of the GSM modem to D3
//Connect the Rx pin of the GSM modem to D4
//SMS Trigger Key/Input connected to D7 (Active LOW)
//CALL Trigger Key connected to D8 (Active LOW)
//END Key Connected to D9 (Active LOW)
#include <NewSoftSerial.h>
NewSoftSerial mySerial(3,4); // RX and TX pins to communicate with GSM module
#define msg_key 7
#define call_key 8
#define end_key 9
String number ="0000000000"; // Add the 10-Digit Mobile Number to which message / call is to be //made,by replacing the 0's
mySerial.begin(9600);
pinMode(msg_key,INPUT);
pinMode(call_key,INPUT);
pinMode(end_key,INPUT);
digitalWrite(msg_key,HIGH);
digitalWrite(call_key,HIGH);
digitalWrite(end_key,HIGH);
//Sends an sms everytime msg_key is pressed
//if (digitalRead(msg_key)==LOW) // Check if the sms key is being pressed
mySerial.println("AT+CMGF=1"); // Set the Mode as Text Mode
delay(150);
mySerial.println("AT+CMGS=\"+00"+number+"\""); // Specify the Destination number in international //format by replacing the 0's
delay(150);
mySerial.print("Warning! Intruder Alert!"); // Enter the message
delay(150);
mySerial.write((byte)0x1A); // End of message character 0x1A : Equivalent to Ctrl+z
delay(50);
mySerial.println();
//Makes a call when call_key is pressed
else if (digitalRead(call_key)==LOW) // Check if the call key is being pressed
mySerial.println("ATD+91"+number+";"); //Specify the number to call
while(digitalRead(call_key)==LOW);
delay(50);
//Hang the call
else if (digitalRead(end_key)==LOW) // Check if the hang up key is being pressed
mySerial.println("ATH");
while(digitalRead(end_key)==LOW);
delay(50);
Da ich die Call Funktion nicht brauche habe ich ihn hier angepasst:
* Arduino Wasser Alarm
#define msg_key 7
#define call_key 8
#define end_key 9
//Sends an sms everytime msg_key is pressed if (digitalRead(msg_key)==LOW) // Check if the sms key is //being pressed
delay(150);
delay(150);
mySerial.print("ACHTUNG WASSER LAEUFT UEBER!"); // Enter the message
delay(150);
delay(50);
mySerial.println();
Wenn nun Pin 7 auf Masse gebracht wird, wird doch diese eine SMS ausgelöst, richtig?
Welcher Arduino ist das denn un diesem Projekt? Ist das der Nano oder der Micro? Kann ich generell einen Nano oder Micro nehmen, passen dann die Pin Belegungen noch?
Ich bin noch nicht so ganz schlau daraus geworden, das der “end key” zu tun hat. Der ist doch nur zum auflegen der Telefonverbindung, oder?
Dann ich diesen dann auch einfach weg lassen?
Würde folgende Hardware passen, wenn ich mir diese schnell bestelle?
http://www.ebay.de/itm/SIM900-GPRS-GSM-Board-Quad-Band-Module-antenna-Kit-fur-Arduino-Raspberry-Pi-DIY-/111881284759?hash=item1a0ca4ec97:g:a7UAAOSwHnFVukAw
Und als Controller:
Passt das an Hardware? Vor allem hat der eBay GSM Shield 5V anstatt 12V wie der aus dem Tutorial.
Damit könnte ich ja mit dem abgeänderten Code einfach loslegen, oder?
Danke schon mal
