Ich hab mir jetzt einfach ein fertiges Arduino-Programm aus dem Netz drauf gezogen.
Das ist auch ganz gut gemacht und die Anzeige ist auf 10 Gram genau
Das ist also die Lösung des Threads:
* Copyright (c) 2022 by M5Stack
* Equipped with M5Core2 sample source code
* 配套 M5Core2 示例源代码
* Visit for more information: https://docs.m5stack.com/en/app/scales_kit
* 获取更多资料请访问: https://docs.m5stack.com/zh_CN/app/scales_kit
* describe: SCALES KIT WEIGHT UNIT EXAMPLE.
* Date: 2022/02/23
Connect WEIGHT UNIT to port A (G32/33), calibration instructions: touch button
A to remove the tare weight when there is no load, touch button B, switch the
standard weight value left and right and put down the corresponding weight,
confirm for calibration. 将WEIGHT UNIT连接至端口A(G32/33), 校准说明:
无负重情况下触摸按键A去处皮重,
触摸按键B,左右触摸切换标准重量值并放下对应重量砝码,comfirm进行校准。
Libraries:
- [HX711](https://github.com/bogde/HX711)
#include <M5Unified.h>
#include <M5GFX.h>
#include "HX711.h"
M5GFX display;
M5Canvas canvas(&display);
// HX711 related pin Settings. HX711 相关引脚设置
#define LOADCELL_DOUT_PIN 33
#define LOADCELL_SCK_PIN 32
HX711 scale;
M5.begin(); // Init M5Stack. 初始化M5Stack
display.begin();
canvas.setColorDepth(1); // mono color
canvas.createSprite(display.width(), display.height());
canvas.setTextDatum(MC_DATUM);
canvas.setPaletteColor(1, GREEN);
canvas.drawString("Calibration sensor....", 160, 80);
canvas.pushSprite(0, 0);
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_gain();
// The scale value is the adc value corresponding to 1g
scale.set_scale(27.61f); // set scale
scale.tare(); // auto set offset
char info[100];
canvas.fillSprite(BLACK);
canvas.setTextSize(1);
canvas.drawString("Connect the Weight Unit to PortB(G26,G36)", 160, 40);
canvas.drawString("Click Btn A for Tare deduction", 160, 55);
canvas.drawString("Click Btn B Switch to Calibration mode", 160, 70);
float weight = scale.get_units(10) / 1000.0;
// float weight = scale.get_units(10) / 1.0;
canvas.setTextSize(3);
if (weight >= 0) {
Serial.printf("Weight: %.2f", weight);
sprintf(info, "Weight: %.2f", weight);
canvas.drawString(String(info) + "kg", 160, 150);
// canvas.drawString(String(info) + "g", 160, 150);
canvas.drawString("Weight: 0kg", 160, 150);
// canvas.drawString("Weight: 0g", 160, 150);
M5.update();
if (M5.BtnA.wasPressed()) {
scale.tare();
canvas.drawString("0g Calibration!", 160, 180);
if (M5.BtnB.wasPressed()) {
long kg = 5;
while (1) {
M5.update();
40);
canvas.drawString("Click Btn A/C to change kg value", 160, 55);
canvas.drawString("Click Btn B Calibration Comfirm", 160, 70);
canvas.drawString("Calibration:" + String(kg) + "kg", 160, 150);
canvas.drawString("comfirm", 160, 200);
canvas.fillTriangle(40, 200, 60, 220, 60, 180, 1);
canvas.fillTriangle(280, 200, 260, 220, 260, 180, 1);
if (M5.BtnA.isPressed()) {
kg--;
if (M5.BtnC.isPressed()) {
kg++;
delay(10);
long kg_adc = scale.read_average(20);
kg_adc = kg_adc - scale.get_offset();
scale.set_scale(kg_adc / (kg * 1000.0));
// canvas.drawString(String(kg) + "kg Calibration: " + String(kg_adc /
// (kg * 1000.0)), 160, 180);
canvas.drawString("Set Scale: " + String(kg_adc / (kg * 1000.0)), 160,
180);
