Hello everyone. This is not really a problem, more like sharing a neat code with you all. This is a code that displays animated Snorlax on classic ssd1306 0.96" 128x64 OLED display. It may not seem like he's animated at times but that's because it has about 12 seconds of the same animation (40 frames at 0.3s delay). I started with Upir's code which I just modified for more frames and different animation. Do note that this is displaying white background and black Snorlax lines so it might not be very power efficient. Hope you like this.
Edit: even though it's a lengthy code, it will fit on Arduino uno or Nano for sure
#include <Arduino.h>
#include <U8g2lib.h> // u8g2 library used for drawing on the OLED display
#include <Wire.h> // library requires for IIC communication
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // initialization for the 128x64px display
//U8G2_SSD1306_72X40_ER_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);// 72x40px display [full framebuffer, size = 360 bytes]
// images below are generated using the image2cpp website
const unsigned char epd_bitmap_blob_01 [] PROGMEM = {
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x7e, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0x00, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0xf0, 0x03, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xcc, 0xff, 0x0f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x1f, 0x1e, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7e, 0xf8, 0x19, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8f, 0x7f, 0x3e, 0xf0, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x3c, 0x00, 0xf0, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xc0, 0xff, 0xf0, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xf0, 0xff, 0xe7, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf0, 0xff, 0xdf, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf4, 0xff, 0x3f, 0x18, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf4, 0xff, 0x0f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xf8, 0xff, 0x03, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xfa, 0xff, 0x05, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x4b, 0xfa, 0xff, 0x00, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3d, 0xfd, 0xff, 0x06, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfd, 0xff, 0xff, 0x01, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xff, 0xff, 0x05, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xff, 0xff, 0x03, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x77, 0xfe, 0xff, 0xff, 0x0f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x6d, 0xfd, 0xff, 0xff, 0x3f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xad, 0xfd, 0xff, 0xff, 0x7f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x6f, 0x12, 0xfd, 0xff, 0xff, 0x7f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x6f, 0xff, 0xfc, 0xff, 0xff, 0x7f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xfd, 0xff, 0xff, 0x7f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xfb, 0xff, 0xff, 0x3f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xf7, 0xff, 0xff, 0x3f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xff, 0xe7, 0xff, 0xff, 0xdf, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xff, 0xcf, 0xff, 0xff, 0xef, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xf5, 0x0f, 0xfc, 0xff, 0xe7, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xe0, 0x0f, 0xc0, 0xff, 0x00, 0x18, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xe0, 0x0f, 0x00, 0x00, 0xfc, 0x1c, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0f, 0x00, 0x80, 0xff, 0x0b, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xc0, 0x0f, 0x00, 0xc0, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xc1, 0x0f, 0x00, 0xe0, 0xff, 0xef, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xbf, 0xc1, 0x0f, 0x00, 0xe0, 0xff, 0xef, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x7f, 0xef, 0x07, 0x00, 0xe0, 0xff, 0x4f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x7f, 0xff, 0x07, 0x00, 0xf0, 0xc3, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x03, 0x00, 0xf0, 0xc3, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf3, 0x00, 0x00, 0xf0, 0x01, 0xdf, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0x00, 0x00, 0xf0, 0x00, 0xde, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0x00, 0xf0, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xe0, 0x00, 0xee, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xe0, 0x81, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc7, 0xe3, 0xf7, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xbf, 0xff, 0xfb, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xfe, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-2', 128x64px
const unsigned char epd_bitmap_blob_02 [] PROGMEM = {
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xcc, 0xfd, 0x0f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xff, 0x19, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f, 0x7f, 0xf8, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8f, 0x7f, 0x3f, 0xf0, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x3c, 0x00, 0xe0, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xc0, 0xff, 0xf0, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf0, 0xff, 0x9f, 0x1f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf4, 0xff, 0x3f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf0, 0xff, 0x03, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x49, 0xfa, 0xff, 0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xfd, 0xff, 0x06, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xff, 0xff, 0x01, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x77, 0xfe, 0xff, 0xff, 0x03, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x6d, 0xfd, 0xff, 0xff, 0x1f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xad, 0xfd, 0xff, 0xff, 0x3f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xfb, 0xff, 0xff, 0x7f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xfb, 0x0f, 0xfc, 0xff, 0xe7, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xe0, 0x0f, 0xc0, 0xff, 0x00, 0x18, 0xfe, 0xff, 0xff, 0xff, 0xff,
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-3', 128x64px
const unsigned char epd_bitmap_blob_03 [] PROGMEM = {
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x3e, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0xf0, 0x03, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xfd, 0x0f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xce, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xfe, 0x1f, 0x1e, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xff, 0xff, 0x39, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x9f, 0x7f, 0x1f, 0xec, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x7f, 0xff, 0xc3, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x3c, 0xe0, 0xff, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xc0, 0x3f, 0xfe, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf0, 0xff, 0xfb, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf0, 0xff, 0xcf, 0x1f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf4, 0xff, 0x1f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xfa, 0xff, 0x05, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x49, 0xfa, 0xff, 0x00, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xfd, 0xff, 0x06, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xfb, 0xfe, 0xff, 0xff, 0x01, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x27, 0xfe, 0xff, 0xff, 0x05, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x2c, 0xfd, 0xff, 0xff, 0x03, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x6f, 0x8c, 0xfd, 0xff, 0xff, 0x1f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x6f, 0x12, 0xfd, 0xff, 0xff, 0x3f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xfb, 0xff, 0xff, 0x7f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xff, 0xe7, 0xff, 0xff, 0xdf, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xff, 0xcf, 0xff, 0xff, 0xef, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xf1, 0x0f, 0xfc, 0xff, 0xe7, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0f, 0x00, 0x80, 0xff, 0x0b, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xcf, 0xc0, 0x0f, 0x00, 0xc0, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x9f, 0xc1, 0x0f, 0x00, 0xe0, 0xff, 0xef, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x3f, 0xef, 0x07, 0x00, 0xe0, 0xff, 0x4f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x7f, 0xfc, 0x03, 0x00, 0xf0, 0xc3, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0x00, 0x00, 0xf0, 0x01, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0xf0, 0x00, 0x9e, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0x00, 0xf0, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xe0, 0x00, 0xce, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xe0, 0x81, 0xcf, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0xc0, 0xe3, 0xe7, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8f, 0xff, 0xf3, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-4', 128x64px
const unsigned char epd_bitmap_blob_04 [] PROGMEM = {
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x2f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x17, 0x00, 0x7f, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x40, 0xf2, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x51, 0x01, 0x80, 0xf2, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf9, 0xf0, 0x03, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xed, 0xfd, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xfc, 0xff, 0xff, 0x39, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0x70, 0x3f, 0xe4, 0x3f, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x70, 0xe7, 0xc3, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x70, 0xe0, 0xff, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x19, 0xe4, 0x7f, 0xfe, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x09, 0xf8, 0xff, 0xfb, 0x3f, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xfa, 0xff, 0xef, 0x1f, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xfc, 0xff, 0x3f, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xfc, 0xff, 0x9f, 0x02, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xfe, 0xff, 0x03, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0xff, 0xff, 0x01, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf9, 0xff, 0xff, 0x00, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x06, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x77, 0xfe, 0xff, 0xff, 0x05, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x6d, 0xfd, 0xff, 0xff, 0x03, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x8e, 0xfd, 0xff, 0xff, 0x1f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x6f, 0x1e, 0xfd, 0xff, 0xff, 0x3f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xff, 0xfc, 0xff, 0xff, 0x7f, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xf7, 0xff, 0xff, 0x3f, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe7, 0xff, 0xff, 0xdf, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xff, 0xdf, 0xff, 0xff, 0xef, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xf1, 0x0f, 0xfc, 0xff, 0xe7, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xef, 0xe1, 0x0f, 0xc0, 0xff, 0xc1, 0x18, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0f, 0x00, 0x80, 0xff, 0x53, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xdf, 0x80, 0x0f, 0x00, 0xc0, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0x0f, 0x00, 0xe0, 0xff, 0xef, 0xfe, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x7f, 0xff, 0x07, 0x00, 0xe0, 0xff, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x7f, 0xff, 0x07, 0x00, 0xf0, 0xe3, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf5, 0x00, 0x00, 0xf0, 0x01, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0x00, 0x70, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0x60, 0x00, 0xee, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0xe0, 0x80, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x9f, 0xff, 0xfb, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x41, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-5', 128x64px
const unsigned char epd_bitmap_blob_05 [] PROGMEM = {
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-6', 128x64px
const unsigned char epd_bitmap_blob_06 [] PROGMEM = {
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-7', 128x64px
const unsigned char epd_bitmap_blob_07 [] PROGMEM = {
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-8', 128x64px
const unsigned char epd_bitmap_blob_08 [] PROGMEM = {
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-9', 128x64px
const unsigned char epd_bitmap_blob_09 [] PROGMEM = {
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-10', 128x64px
const unsigned char epd_bitmap_blob_10 [] PROGMEM = {
// '60f1f2463be74dabb2567b7d9f0419553grJSumCxqa4QQbO-11', 128x64px
const unsigned char epd_bitmap_blob_11 [] PROGMEM = {
// Array of all bitmaps for convenience. (Total bytes used to store images in PROGMEM = 4800)
const int epd_bitmap_allArray_LEN = 50;
const unsigned char* epd_bitmap_allArray[50] = {
//yawn
epd_bitmap_blob_01,
epd_bitmap_blob_02,
//40 frames of the same pose
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
epd_bitmap_blob_03,
//scratch
epd_bitmap_blob_04,
epd_bitmap_blob_05,
epd_bitmap_blob_06,
epd_bitmap_blob_07,
epd_bitmap_blob_08,
epd_bitmap_blob_09,
epd_bitmap_blob_10,
epd_bitmap_blob_11
int anim_frame = 0; // animation frame for the blob / metaballs animation
void setup(void) {
u8g2.begin(); // start the u8g2 library
void loop(void) {
u8g2.clearBuffer(); // clear the internal memory
u8g2.setBitmapMode(1); // draw transparent images
u8g2.drawXBMP(0, 0, 128, 64, epd_bitmap_allArray[anim_frame]); // draw the image of the outline of the battery icon
u8g2.sendBuffer(); // transfer internal memory to the display
// current frame for the blob animation, 0-50
anim_frame = (anim_frame + 1) % 50;
delay(300);
