Animations/ images don't want to be displayed
Hello!
I am in the process of making a MIDI controller, using a KY040, a 0.96 OLED screen, and a DFROBOT for testing which will later be replaced with an ESP32.
I managed to code a large part of the project (thanks to GPT chat because I know nothing haha), but I am stuck on adding animations/images. Where the animations should be displayed, I see white pixels glitching instead.
I can't understand if it's the size of the imported animations that is wrong, a framerate problem, or something completely different.
Here is the code where I added the animation for the "Enceintes" mode.
Quickly, an explanation for clarity:
On the left side of the screen, we have the live volume level, and on the right, the selected mode (SPEAKERS or HEADPHONES), represented by an image/logo. When I press the encoder, the mode changes, and an animation is displayed in the middle of the screen corresponding to the current mode.
Thank you in advance!
#include <Wire.h>
#include <U8g2lib.h>
#include <Encoder.h>
#define SCREEN_I2C_ADDR 0x3C
#define OLED_RST_PIN -1
U8G2_SSD1306_128X64_NONAME_F_HW_I2C display(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
#define CLK_PIN 2
#define DT_PIN 3
#define SW_PIN 4
#define FRAME_DELAY (42)
#define FRAME_WIDTH (50)
#define FRAME_HEIGHT (50)
Encoder encoder(CLK_PIN, DT_PIN);
int encoderPos = 0;
int lastEncoderValue = 0;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 5;
enum Mode
  ENCEINTES,
  CASQUE
Mode selectedMode = ENCEINTES;
bool animationPlayed = false;
// Sample animation frames data
// '_a_frm27,50', 50x50px
const unsigned char enceintesFrames_a_frm27_50 [] PROGMEM = {
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x1f,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x1f, 0x00, 0x00,
	0x00, 0x00, 0x00, 0xf0, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x1f, 0xc0, 0x03, 0x00, 0x00,
	0x00, 0xfc, 0x1f, 0x80, 0x07, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x00, 0x1c, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x38, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0x70, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x60, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0xe0, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0xc0, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0xc1, 0x01, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x81, 0x01, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x83, 0x01, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x83, 0x03, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x07, 0x03, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x06,
	0x03, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x03, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x03, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x03, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x03, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x06, 0x03, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x07, 0x03, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x83, 0x03, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x83, 0x01, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x81, 0x01,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0xc1, 0x01, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0xc0, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0xe0, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x60, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0x70, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x38, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x1c,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x80, 0x07, 0x00, 0x00,
	0x00, 0xf8, 0x1f, 0xc0, 0x03, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xe0,
	0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x1f, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00,
// '_a_frm26,50', 50x50px
const unsigned char enceintesFrames_a_frm26_50 [] PROGMEM = {
// '_a_frm23,40', 50x50px
const unsigned char enceintesFrames_a_frm23_40 [] PROGMEM = {
	0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x1f, 0x20, 0x00, 0x00, 0x00,
	0x00, 0xfc, 0x1f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0xc0, 0x01, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x00, 0x07, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x0e, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0x0c, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x18, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0x38, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x30, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x61, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x61, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0xe3, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0xc3, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0xc7, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0xc6,
	0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0xc6, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0xc6, 0x00, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0xc6, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0xc6, 0x00, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0xc6, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0xc7, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0xc3, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0xe3, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x61, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x61, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x30, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0x38, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x18, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0x0c, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x0e, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x07,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0xc0, 0x01, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0xe0, 0x00, 0x00, 0x00,
	0x00, 0xf8, 0x1f, 0x20, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0,
// '_a_frm22,40', 50x50px
const unsigned char enceintesFrames_a_frm22_40 [] PROGMEM = {
	0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x1f, 0x00, 0x00, 0x00, 0x00,
	0x00, 0xfc, 0x1f, 0x20, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x70, 0x00, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0xc0, 0x01, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x8c, 0x03, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0x07, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x0e, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0x0c, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x18, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x19, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x31, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x33, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x63, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x67, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x66,
	0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x66, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x66, 0x00, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x66, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x66, 0x00, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x66, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x67, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x63, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x33, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x31, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x19, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x18, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0x0c, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x0e, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0x07, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x8c, 0x03, 0x00, 0x00, 0x00, 0xff, 0x1f, 0xc0, 0x01,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x70, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x30, 0x00, 0x00, 0x00,
	0x00, 0xf8, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0,
// '_a_frm25,40', 50x50px
const unsigned char enceintesFrames_a_frm25_40 [] PROGMEM = {
// '_a_frm24,40', 50x50px
const unsigned char enceintesFrames_a_frm24_40 [] PROGMEM = {
	0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x1f, 0x00, 0x01, 0x00, 0x00, 0x00, 0xe0, 0x1f, 0x80, 0x03,
	0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x07, 0x00, 0x00, 0x00, 0xf8, 0x1f, 0x00, 0x0e, 0x00, 0x00,
	0x00, 0xfc, 0x1f, 0x00, 0x1c, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x38, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x00, 0x30, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x70, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0x60, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0xe0, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0xc0, 0x00,
	0x03, 0x83, 0x01, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x87, 0x01, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x86,
	0x01, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x86, 0x01, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x86, 0x01, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x86, 0x01, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x86, 0x01, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x86, 0x01, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x87, 0x01, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x83, 0x01, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x83, 0x01, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x81, 0x01,
	0xff, 0x1f, 0x70, 0xc0, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0xe0, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0x60, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x60, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x30,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x38, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x00, 0x18, 0x00, 0x00,
	0x00, 0xf8, 0x1f, 0x00, 0x1c, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xe0,
	0x1f, 0x00, 0x07, 0x00, 0x00, 0x00, 0xc0, 0x1f, 0x80, 0x03, 0x00, 0x00, 0x00, 0x80, 0x1f, 0x00,
	0x01, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00,
// '_a_frm21,40', 50x50px
const unsigned char enceintesFrames_a_frm21_40 [] PROGMEM = {
	0x00, 0xfc, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x10, 0x00, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x70, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0xec, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x9c,
	0x01, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x03, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0x06, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x0e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x0d, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x19, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x1b, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x13, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x37, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x36,
	0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x36, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x36, 0x00, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x36, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x36, 0x00, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x36, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x37, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x1b, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x1b, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x19, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x0d, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x0e, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0x06, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x03, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x9c, 0x01, 0x00, 0x00, 0x80, 0xff, 0x1f, 0xec, 0x00, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x70, 0x00,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x10, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x00, 0x00, 0x00, 0x00,
// '_a_frm20,50', 50x50px
const unsigned char enceintesFrames_a_frm20_50 [] PROGMEM = {
	0x00, 0xfc, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x18, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x3c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0xfc,
	0x00, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0xf8, 0x01, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0xf0, 0x03, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x07, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x1e,
	0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x1e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x1e, 0x00, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x1e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x1e, 0x00, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x1e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x0f, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x07, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x07, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x03, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0xf0, 0x03, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0xf8, 0x01, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0xfc, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x3c, 0x00, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x18, 0x00,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x00, 0x00, 0x00, 0x00,
// '_a_frm19,40', 50x50px
const unsigned char enceintesFrames_a_frm19_40 [] PROGMEM = {
	0x1f, 0x00, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x1c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x3c,
	0x00, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x00, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0xf0, 0x00, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x03, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x0e,
	0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x0e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x0e, 0x00, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x0e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x0e, 0x00, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x0e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x07, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x03, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x03, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x3c, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x1c, 0x00, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x00,
// '_a_frm18,40', 50x50px
const unsigned char enceintesFrames_a_frm18_40 [] PROGMEM = {
	0x1f, 0x00, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x3c,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x06,
	0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x00, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x06, 0x00, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x06, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x07, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x03, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0x00, 0xf0,
	0x3c, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x00, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x00,
// '_a_frm17,40', 50x50px
const unsigned char enceintesFrames_a_frm17_40 [] PROGMEM = {
	0x1f, 0x00, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x00, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0xfc, 0xf3,
	0x03, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x03, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x01, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0xf0,
	0x1c, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x00, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x00,
// '_a_frm16,40', 50x50px
const unsigned char enceintesFrames_a_frm16_40 [] PROGMEM = {
	0x00, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x00, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0x00, 0x00,
	0xff, 0x5f, 0x80, 0x01, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x06,
	0x03, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x03, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x01, 0x00,
	0xff, 0x1f, 0x70, 0x00, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f,
// '_a_frm15,40', 50x50px
const unsigned char enceintesFrames_a_frm15_40 [] PROGMEM = {
// '_a_frm14,50', 50x50px
const unsigned char enceintesFrames_a_frm14_50 [] PROGMEM = {
// '_a_frm13,40', 50x50px
const unsigned char enceintesFrames_a_frm13_40 [] PROGMEM = {
// '_a_frm12,40', 50x50px
const unsigned char enceintesFrames_a_frm12_40 [] PROGMEM = {
// '_a_frm11,40', 50x50px
const unsigned char enceintesFrames_a_frm11_40 [] PROGMEM = {
// '_a_frm10,40', 50x50px
const unsigned char enceintesFrames_a_frm10_40 [] PROGMEM = {
// '_a_frm9,40', 50x50px
const unsigned char enceintesFrames_a_frm9_40 [] PROGMEM = {
	0x1f, 0x00, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x1c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x7c,
	0x00, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0xf0, 0x01, 0x00,
	0xff, 0x5f, 0x80, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x1f, 0x0e, 0x0e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x07, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x07, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x07, 0x00,
	0xff, 0x1f, 0xf0, 0x01, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x7c, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x1c, 0x00, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x00,
// '_a_frm8,50', 50x50px
const unsigned char enceintesFrames_a_frm8_50 [] PROGMEM = {
	0x1f, 0x38, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x7c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0xfc,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x06, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x07, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x0d, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x0b, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x1b, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x1f, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x1e,
	0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x16, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x16, 0x00, 0xfc,
	0xf3, 0xff, 0x1f, 0x0c, 0x16, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0c, 0x16, 0x00, 0xfc, 0xf3, 0xff,
	0x1f, 0x0e, 0x1e, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x1f, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x1b, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x0f, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x0f, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x07, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x06, 0x00, 0x00, 0xf0,
	0xfc, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x7c, 0x00, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x38, 0x00,
// '_a_frm7,40', 50x50px
const unsigned char enceintesFrames_a_frm7_40 [] PROGMEM = {
	0x00, 0xfc, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x30, 0x00, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0xe0, 0x00, 0x00, 0x00, 0x80, 0xff, 0x1f, 0xcc, 0x01, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0x03, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x06, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0x0e, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x0c, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x19, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x19, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x33, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x33, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x37, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0x26,
	0x1f, 0x0e, 0x26, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0x37, 0x00, 0xfc, 0xf3, 0xff, 0x9f, 0x03,
	0x33, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x33, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x19, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x19, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x0c, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0x0e, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x06, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0x03, 0x00, 0x00, 0x80, 0xff, 0x1f, 0xcc, 0x01, 0x00, 0x00, 0x00, 0xff, 0x1f, 0xe0, 0x00,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x30, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x00, 0x00, 0x00, 0x00,
// '_a_frm6,40', 50x50px
const unsigned char enceintesFrames_a_frm6_40 [] PROGMEM = {
	0x00, 0xfc, 0x1f, 0x60, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0xe0, 0x01, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x80, 0x03, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x07, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0x0e, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x1c, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0x18, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x30, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x31, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0x61, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x63, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x03, 0x63, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x07, 0xc7, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0x0e, 0xc6,
	0x63, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0x63, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0x61, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x31, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x30, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0x18, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x1c, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0x0e, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x07, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x80, 0x03,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0xe0, 0x01, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x60, 0x00, 0x00, 0x00,
// '_a_frm5,40', 50x50px
const unsigned char enceintesFrames_a_frm5_40 [] PROGMEM = {
	0x00, 0xfc, 0x1f, 0x00, 0x07, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x00, 0x1c, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x18, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0x30, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x70, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0x60, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x60, 0x00, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0xc1, 0x00, 0xfc, 0xf3,
	0xff, 0x5f, 0x80, 0xc1, 0x00, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0xc3, 0x00, 0xfc, 0xf3, 0xff, 0x9f,
	0x83, 0x01, 0xfc, 0xf3, 0xff, 0xdf, 0x01, 0xc3, 0x00, 0xfc, 0xf3, 0xff, 0x5f, 0x80, 0xc1, 0x00,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0xc1, 0x00, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x60, 0x00, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0x60, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0x70, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0x30, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x18, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x1c,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x00, 0x07, 0x00, 0x00,
	0x00, 0xf8, 0x1f, 0x80, 0x03, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0xc0, 0x01, 0x00, 0x00, 0x00, 0xe0,
	0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x1f, 0x00,
// '_a_frm4,40', 50x50px
const unsigned char enceintesFrames_a_frm4_40 [] PROGMEM = {
	0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x1f, 0x00, 0x01, 0x00, 0x00, 0x00, 0xe0, 0x1f, 0x00, 0x07,
	0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xf8, 0x1f, 0x00, 0x1c, 0x00, 0x00,
	0x00, 0xfc, 0x1f, 0x00, 0x18, 0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x30, 0x00, 0x00, 0x00, 0xff,
	0x1f, 0x00, 0x70, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x60, 0x00, 0x00, 0xc0, 0xff, 0x1f, 0x1c,
	0xe0, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0xc0, 0x00, 0x00, 0xf0, 0xff, 0x1f, 0x70, 0xc0, 0x00,
	0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0x80, 0x01, 0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x81, 0x01, 0xfc, 0xf3,
	0xfc, 0xf3, 0xff, 0x1f, 0xc0, 0x81, 0x01, 0xf8, 0xf3, 0xff, 0x1f, 0xc0, 0xc0, 0x01, 0x00, 0xf0,
	0xff, 0x1f, 0x70, 0xc0, 0x00, 0x00, 0xe0, 0xff, 0x1f, 0x78, 0xc0, 0x00, 0x00, 0xc0, 0xff, 0x1f,
	0x1c, 0xe0, 0x00, 0x00, 0x80, 0xff, 0x1f, 0x0c, 0x60, 0x00, 0x00, 0x00, 0xff, 0x1f, 0x00, 0x70,
	0x00, 0x00, 0x00, 0xfe, 0x1f, 0x00, 0x30, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0x00, 0x38, 0x00, 0x00,
	0x00, 0xf8, 0x1f, 0x00, 0x1c, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0x00, 0x0c, 0x00, 0x00, 0x00, 0xe0,
	0x1f, 0x00, 0x06, 0x00, 0x00, 0x00, 0xc0, 0x1f, 0x00, 0x03, 0x00, 0x00, 0x00, 0x80, 0x1f, 0x00,
// '_a_frm3,40', 50x50px
const unsigned char enceintesFrames_a_frm3_40 [] PROGMEM = {
// '_a_frm1,40', 50x50px
const unsigned char enceintesFrames_a_frm1_40 [] PROGMEM = {
// '_a_frm2,50', 50x50px
const unsigned char enceintesFrames_a_frm2_50 [] PROGMEM = {
// '_a_frm0,40', 50x50px
const unsigned char enceintesFrames_a_frm0_40 [] PROGMEM = {
// Array of all bitmaps for convenience. (Total bytes used to store images in PROGMEM = 10304)
const int enceintesFramesallArray_LEN = 28;
const unsigned char* enceintesFramesallArray[28] = {
	enceintesFrames_a_frm0_40,
	enceintesFrames_a_frm10_40,
	enceintesFrames_a_frm11_40,
	enceintesFrames_a_frm12_40,
	enceintesFrames_a_frm13_40,
	enceintesFrames_a_frm14_50,
	enceintesFrames_a_frm15_40,
	enceintesFrames_a_frm16_40,
	enceintesFrames_a_frm17_40,
	enceintesFrames_a_frm18_40,
	enceintesFrames_a_frm19_40,
	enceintesFrames_a_frm1_40,
	enceintesFrames_a_frm20_50,
	enceintesFrames_a_frm21_40,
	enceintesFrames_a_frm22_40,
	enceintesFrames_a_frm23_40,
	enceintesFrames_a_frm24_40,
	enceintesFrames_a_frm25_40,
	enceintesFrames_a_frm26_50,
	enceintesFrames_a_frm27_50,
	enceintesFrames_a_frm2_50,
	enceintesFrames_a_frm3_40,
	enceintesFrames_a_frm4_40,
	enceintesFrames_a_frm5_40,
	enceintesFrames_a_frm6_40,
	enceintesFrames_a_frm7_40,
	enceintesFrames_a_frm8_50,
const byte PROGMEM casqueFrames[][288] = {
    { /* YOUR_CASQUE_FRAME_1_DATA_HERE */ },
    { /* YOUR_CASQUE_FRAME_2_DATA_HERE */ },
    // Add more frames as needed
void displayAnimationFrames(const byte *frames, int frameCount, int frameWidth, int frameHeight, int x, int y)
  for (int frame = 0; frame < frameCount; ++frame)
    display.clearBuffer();
    display.drawXBM(x, y, frameWidth, frameHeight, frames[frame]);
    display.sendBuffer();
void updateScreen()
  display.setFont(u8g2_font_logisoso30_tn);
  char volumeText[5];
  snprintf(volumeText, sizeof(volumeText), "%d", abs(encoderPos));
  if (!animationPlayed)
    // Display the animation in the center of the screen
    const byte *currentFrames = (selectedMode == ENCEINTES) ? reinterpret_cast<const byte *>(enceintesFramesallArray) : reinterpret_cast<const byte *>(casqueFrames);
    displayAnimationFrames(currentFrames, sizeof(enceintesFramesallArray) / sizeof(enceintesFramesallArray[0]), FRAME_WIDTH, FRAME_HEIGHT, 30, 0);
    animationPlayed = true; // Mark the animation as played once
    // Display a single image on the right
    const byte *currentFrame = (selectedMode == ENCEINTES) ? reinterpret_cast<const byte *>(enceintesFrames_a_frm0_40[0]) : reinterpret_cast<const byte *>(casqueFrames[0]);
    display.drawXBM(75, 0, FRAME_WIDTH, FRAME_HEIGHT, currentFrame);
    display.drawStr(0, 40, volumeText); // Display volume text on the left
void sendMIDI()
  // Add your MIDI logic here based on encoderPos and selectedMode
  if (!display.begin())
    Serial.println(F("U8g2 init failed"));
    for (;;)
  pinMode(SW_PIN, INPUT_PULLUP);
  int encoderValue = encoder.read() / 2;
  int encoderDelta = encoderValue - lastEncoderValue;
  if (millis() - lastDebounceTime > debounceDelay)
    encoderPos -= encoderDelta;
    encoderPos = constrain(encoderPos, -60, 0);
    lastDebounceTime = millis();
  Serial.print("Encoder Value: ");
  Serial.println(encoderValue);
  if (digitalRead(SW_PIN) == LOW)
    selectedMode = (selectedMode == ENCEINTES) ? CASQUE : ENCEINTES;
    animationPlayed = false; // Reset the animation state
    updateScreen();
    while (digitalRead(SW_PIN) == LOW)
      delay(10);
  updateScreen();
  sendMIDI();
  lastEncoderValue = encoderValue;
Please consider GPT as one path to rapid prototyping…
as we all know, there’s a lot more work to do after the functional prototype.
ORIGINAL PROJECT SCHEDULE
I always divide the project up into clearly defined milestones.
1. Exploration budget & payment plan
2. Research & Viability of customer's idea
3. Ballpark costing of whole project and timeline and repeat
4. Acceptance & rework
5. Element tests
6. POC components for customer approval & understanding
7. Collaborate on Product Spec & then Initial design expectations
-- This far lets you see how much the customer is committed and understands
-- You may walk away now...!
1. FP budget & payment plan
2. **FUNCTIONAL prototype development**
3. Acceptance & rework
4. PP budget
5. **PRODUCTION prototype development**
6. Acceptance & rework
-- The proposal and exploration budget / milestone payments only get this far
-- He may walk away now !
1. Review and marketing analysis
2. PRODUCTION budget & payment plan
3. Away you go...
Steps can be combined - but price just gets compressed - may get slightly higher if timelines are also compressed.
Also let the customer know up front - in writing - that unwritten variation orders don't exist.
Written variation orders will probably cost extra in time and/or money.
Also let them know of limitations up front that are keeping the budget in hand...e.g. limited memory, performance goals etc
If I'm not sure of the customer's position or the budget is more than I can risk...
Payment per stage is 60% up front, 30% on delivery, and balance of 10% on first beneficial use.
All these terms and milestones are clearly repeated with each offer document.
Thank you for your response!
I'm not creating this for commercial purposes; it's just a hobby. I enjoy making things for personal use. Once the project is finished, I plan to share it online with printable 3D files and the code for others to use. :slight_smile:
You should be using drawXBMP(), drawXBM() expects the image to be stored in ram, not PROGMEM.
The other problem is that you are not correctly passing an array of pointers to the displayAnimationFrames function.
Where does displayAnimationFrames() obtain frameCount?
The OP is passing frameCount to the function correctly, the problem is that frames should be a const byte** not a const byte*
doesn't compile, stops here..
i replaced it with this..
    display.drawXBMP(x, y, frameWidth, frameHeight, (const uint8_t*)&frames[frame]);
compiles and does something??
just wanted to watch the ani..
simmed on esp32 here..
good luck.. ~q
The 28 frames making this animated image are 50x50, scanned horizontal. There are a LOT of duplicate frames (taking up memory with "no movement," rather than one frame with a longer delay) in the original sketch.
earthing
I would use larger delays and fewer (half the total) frames.
(edit - due to my editing, the frames of this animation are not in order... I noticed too late that I used "first matrix, first frame" and did not pay attention to the assigned frame number... maybe I need to make a frame-reading-widget)
This is probably static, at 50x50.
The result of displaying a XBM formatted image as a bitmap. The bit order within each byte is reversed.
Image frames correctly ordered. OP mentioned, there are two animations... one to to receive and one to send.
earthing
Try this in your wokwi simulation. The first argument type for the displayAnimationFrames() function has been modified, and a few lines in the updateScreen() function have been modified to get the proper reference to the images.
void displayAnimationFrames(const byte **frames, int frameCount, int frameWidth, int frameHeight, int x, int y)
    display.drawXBMP(x, y, frameWidth, frameHeight, frames[frame]);
    //display.drawXBM(x, y, frameWidth, frameHeight, frames[frame]);
void updateScreen()
  char volumeText[5];
    const byte **currentFrames = (selectedMode == ENCEINTES) ? (const byte **)(enceintesFramesallArray) : (const byte **)(casqueFrames);
    const byte *currentFrame = (selectedMode == ENCEINTES) ? reinterpret_cast<const byte *>(&enceintesFrames_a_frm0_40[0]) : reinterpret_cast<const byte *>(&casqueFrames[0]);
    display.drawXBMP(75, 0, FRAME_WIDTH, FRAME_HEIGHT, currentFrame);
yep, that does it nice..
saved in the sim..
looks better too, at least i can tell what it is..
a speaker with sounds waves, cool..
thanks.. ~q
I have not looked at the animation itself, but in addition to the duplicate images that @xfpd noticed, a considerable amount of memory could be saved by having a base image of the speaker, and only animating the actual sound wave that moves.
Thank you, everyone, for your help! It's working now! I changed my board to an ESP8266 Mini D1, and, as expected, a new challenge arises.
The code appears to upload correctly to the ESP, but there's nothing displaying on the screen. I tested a simple code with a animation, and it's working. I also tried removing the encoder from the code, and it seems to work as well. So, I'm suspecting there might be an issue with the encoder (although it worked fine on my Arduino Mega).
If anyone has insights or suggestions, I would greatly appreciate your assistance!"
I know my code looks horrible so if also you have some advice to make it smoother :slight_smile:
A wokwi with an ESP 32 : ESP32OledAni - Wokwi ESP32, STM32, Arduino Simulator
If i do that, the animation would be less smoother ?
Have you looked to see if there is a rotary encoder library specifically written for the ESP8266?
Removing non-changing frames from the animation and adjusting timing between frames can keep same smoothness . The gain would be in using less memory for frame storage.
@david_2018 has a great suggestion of placing the static portion of the image, and only animating the "wave" portion, saving more than half the current memory usage. (post #14)
You know, don't actually need a lib for the encoder..
Play some pong.. :slight_smile:
Uno Pong
good luck.. ~q
I'm going to check that, thanks! Maybe it's the library; qubbit-us says I don't need a library for the encoder.
Some library don't work on esp8266 ?
