Animatronic Show - Help -
Hello,
I want to give a relative an animatronic.
I want to do an animatronic music show, but I am new.
I am going to use 5 servo motors, I have an Arduino UNO board, but if necessary I would buy a better one.
The question is, I want to do an animatronic music show, but I don't know how to program the servo motors and synchronize the music with the program. I have been told that it can be done with MIDI, but I have no idea how it is done or what program to use.
Can someone help me?
Thank you.
Controlling 5 servo using an UNO is no problem. However, the music is. Using an UNO You will need a separate music player being told by the UNO to play this or that music.
Thanks for answering!
How can I program? I have never programmed, nor do I know which program to use.
Thank you
That's troubelling a bit.
You need some kind of a cource in programming unless You can start using example tasks and go on from that. Knowing/learning programming is not like going to the chemist, buy a pill and swallow it.
Ok, i will try to find information thanks.
Hello,
I'm going to make an animatronic with 5 servo motors and an Arduino UNO board, but I don't know how to program it, nor what program to use.
Thank you.
There are examples with the Servo library.
roberc37, welcome to the forum.
You have duplicate posts on multiple different forums. This is not allowed. Consider going to your other posts, click the 'report to moderator' and ask for it to be removed.
It is confusing and wasted effort to have multiple threads on the same subject going.
You mention an arduino UNO. What other hardware do you have? Hobby servos? Which model?
As for where to start, the servo sweep tutorial is a great place. Note that the tutorial shows powering the servo from the 5v pin. This is NOT the way to go with multiple servos that are actually moving things. Google "arduino servo separate power supply". 4 AA batteries are reasonable.
For your project, you could construct a framework of code that reads a list of servo position and time data. Kick off the program at the same time the music kicks off. You could then process the list of movements that you build to match the music.
But start out with the sweep tutorial. We can build from there.
"I'm going to make an animatronic with 5 servo motors and an Arduino UNO board, but I don't know how to program it, nor what program to use."
You might give some details on the "what program to use". Do you expect to develop program routines for the animatronic to run/perform?
Cross posted in project guidance.
https://forum.arduino.cc/index.php?topic=677891.0
Duplicate topics merged
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
