I havent made any significant change to the code that was on the blog i am following.
I only tried messing with the lcd.print and adding delays in between lines but since i couldnt get anything substantial out of those changes so i didnt save them.
As of now, the arduino board has this particular program loaded in it -
#include "LiquidCrystal.h"
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
#define button_B A0
#define button_D A1
#define button_U A2
#define button_E A3
#define ONBOARD_LED 13
#define DEFAULT_DELAY 300
char buttonPressed = '0';
byte menuLevel = 0; // Level 0: no menu display, display anything you like
// Level 1: display main menu
// Level 2: display sub menu
byte menu = 1;
byte sub = 1;
unsigned long relay_val_1 = 0;
unsigned long relay_val_2 = 0;
unsigned long relay_val_3 = 0;
bool LED_STATE = false;
bool currState_B = HIGH;
bool currState_D = HIGH;
bool currState_U = HIGH;
bool currState_E = HIGH;
bool prevState_B = HIGH;
bool prevState_D = HIGH;
bool prevState_U = HIGH;
bool prevState_E = HIGH;
unsigned long prevTime_B = 0;
unsigned long prevTime_D = 0;
unsigned long prevTime_U = 0;
unsigned long prevTime_E = 0;
unsigned long waitTime_B = 50;
unsigned long waitTime_D = 50;
unsigned long waitTime_U = 50;
unsigned long waitTime_E = 50;
lcd.begin(16,2);
pinMode(button_B, INPUT_PULLUP);
pinMode(button_D, INPUT_PULLUP);
pinMode(button_U, INPUT_PULLUP);
pinMode(button_E, INPUT_PULLUP);
pinMode(A4,INPUT);
pinMode(ONBOARD_LED, OUTPUT);
digitalWrite(ONBOARD_LED, LED_STATE);
showHomeScreen();
checkButton();
// You can do other things here below
void checkButton() {
// Button Debouncing
bool currRead_B = digitalRead(button_B);
bool currRead_D = digitalRead(button_D);
bool currRead_U = digitalRead(button_U);
bool currRead_E = digitalRead(button_E);
if (currRead_B != prevState_B) {
prevTime_B = millis();
if (currRead_D != prevState_D) {
prevTime_D = millis();
if (currRead_U != prevState_U) {
prevTime_U = millis();
if (currRead_E != prevState_E) {
prevTime_E = millis();
if ((millis() - prevTime_B) > waitTime_B) {
if (currRead_B != currState_B) {
currState_B = currRead_B;
if (currState_B == LOW) {
buttonPressed = 'B';
} else buttonPressed = '0';
if ((millis() - prevTime_D) > waitTime_D) {
if (currRead_D != currState_D) {
currState_D = currRead_D;
if (currState_D == LOW) {
buttonPressed = 'D';
if ((millis() - prevTime_U) > waitTime_U) {
if (currRead_U != currState_U) {
currState_U = currRead_U;
if (currState_U == LOW) {
buttonPressed = 'U';
//buttonPressed = '0';
if ((millis() - prevTime_E) > waitTime_E) {
if (currRead_E != currState_E) {
currState_E = currRead_E;
if (currState_E == LOW) {
buttonPressed = 'E';
prevState_B = currRead_B;
prevState_D = currRead_D;
prevState_U = currRead_U;
prevState_E = currRead_E;
processButton(buttonPressed);
void processButton(char buttonPressed) {
switch(menuLevel) {
case 0: // Level 0
switch ( buttonPressed ) {
case 'E': // Enter
menuLevel = 1;
menu = 1;
updateMenu();
delay(DEFAULT_DELAY);
case 'U': // Up
case 'D': // Down
case 'B': // Back
default:
case 1: // Level 1, main menu
case 'E': // Enter
updateSub();
menuLevel = 2; // go to sub menu
updateSub();
case 'U': // Up
menu++;
updateMenu();
case 'D': // Down
menu--;
updateMenu();
case 'B': // Back
menuLevel = 0; // hide menu, go back to level 0
showHomeScreen();
default:
case 2: // Level 2, sub menu
case 'E':
menuLevel = 1;
updateMenu();
case 'U': // U
if (menu == 1) {
if (relay_val_1 < 3600000) { // 1 hour max
relay_val_1 = relay_val_1 + 1;
relay_val_1 = 3600000;
} else if (menu == 2) {
if (relay_val_2 < 3600000) { // 1 hour max
relay_val_2 = relay_val_2 + 1;
relay_val_2 = 3600000;
} else if (menu == 3) {
if (relay_val_3 < 3600000) { // 1 hour max
relay_val_3 = relay_val_3 + 1;
relay_val_3 = 3600000;
updateSub();
case 'D': // D
if (menu == 1) {
if (relay_val_1 == 0) {
relay_val_1 = 0;
relay_val_1 = relay_val_1 - 1;
if (relay_val_2 == 0) {
relay_val_2 = 0;
relay_val_2 = relay_val_2 - 1;
if (relay_val_3 == 0) {
relay_val_3 = 0;
relay_val_3 = relay_val_3 - 1;
updateSub();
case 'B': // L
menuLevel = 1; // go back to main menu
updateMenu();
default:
case 3: // Level 3, sub menu of sub menu
default:
void updateMenu() {
switch (menu) {
case 0:
menu = 1;
case 1:
lcd.clear();
lcd.print(">Relay 1: ");
lcd.print(relay_val_1);
lcd.setCursor(0, 1);
lcd.print(" Relay 2 ");
case 2:
lcd.clear();
lcd.print(" Relay 1 ");
lcd.print(">Relay 2: ");
lcd.print(relay_val_2);
case 3:
lcd.clear();
lcd.print(">Relay 3: ");
lcd.print(relay_val_3);
lcd.print(" ");
case 4:
menu = 3;
void updateSub() {
switch (menu) {
case 0:
case 1:
lcd.clear();
lcd.print(" Relay 1:");
lcd.print(" Val 1 = ");
case 2:
lcd.clear();
lcd.print(" Relay 2:");
lcd.print(" Val 2 = ");
case 3:
lcd.clear();
lcd.print(" Relay 3:");
lcd.print(" Val 3 = ");
case 4:
menu = 3;
void showHomeScreen() {
lcd.clear();
lcd.println(" TechToTinker ");
lcd.setCursor(0,1);
lcd.println(" - R for menu ");
