Annoying compliler errors
I am getting this error:
sketch_mar31a:-1: error: expected ',' or '...' before '&' token
sketch_mar31a:-1: error: ISO C++ forbids declaration of 'T' with no type
sketch_mar31a:-1: error: 'T' was not declared in this scope
sketch_mar31a:-1: error: 'value' was not declared in this scope
sketch_mar31a:9: error: 'template<class T> int file_readAnything(T&)' redeclared as different kind of symbol
sketch_mar31a:-1: error: previous declaration of 'int file_readAnything'
from this code
template <class T> int file_writeAnything(const T& value)
  const byte* p = (const byte*)(const void*)&value;
  int i;
  for (i = 0; i < sizeof(value); i++)
    //file.write(*p++);
  return i;
template <class T> int file_readAnything(T& value)
  byte* p = (byte*)(void*)&value;
  int i;
   // *p++ = file.read();
  return i;
The above code is a segment from a larger project and it used to work before I upgraded to the latest IDE.
Struggleing here.
I know there is no code in the setup and loop functions, but it should still complie without any problems.
Any ideas?
It's a known bug with version 22. One workaround is putting the templete code into a tabbed window and call it something.h and then include it in your main sketch. Here is the issue entry for the bug:
http://code.google.com/p/arduino/issues/detail?id=472&sort=-id -type
Lefty
Excellent. Thanks, Lefty.
However now I have a further problem. The code is now in an .h tab (and so are various other bits in the project) but now it is trying to tell me I am redefining things that I am defining for the first time.
errors:
In file included from version0_6.cpp:18:
storage.h:5: error: redefinition of 'Sd2Card card'
storage.h:5: error: 'Sd2Card card' previously declared here
storage.h:6: error: redefinition of 'SdVolume volume'
storage.h:6: error: 'SdVolume volume' previously declared here
storage.h:7: error: redefinition of 'SdFile root'
storage.h:7: error: 'SdFile root' previously declared here
storage.h:8: error: redefinition of 'SdFile file'
storage.h:8: error: 'SdFile file' previously declared here
storage.h:10: error: redefinition of 'template<class T> int file_writeAnything(const T&)'
storage.h:10: error: 'template<class T> int file_writeAnything(const T&)' previously declared here
storage.h:19: error: redefinition of 'template<class T> int file_readAnything(T&)'
storage.h:19: error: 'template<class T> int file_readAnything(T&)' previously declared here
storage.h: In function 'boolean setupStorage()':
storage.h:30: error: redefinition of 'boolean setupStorage()'
storage.h:30: error: 'boolean setupStorage()' previously defined here
storage.h: In function 'void getConfigData()':
storage.h:85: error: redefinition of 'void getConfigData()'
storage.h:85: error: 'void getConfigData()' previously defined here
storage.h: In function 'void updateConfigData()':
storage.h:102: error: redefinition of 'void updateConfigData()'
storage.h:102: error: 'void updateConfigData()' previously defined here
storage.h: In function 'void storeData()':
storage.h:115: error: redefinition of 'void storeData()'
storage.h:115: error: 'void storeData()' previously defined here
and the code:
#define CD_PIN 3
#define CARDSPEED SPI_HALF_SPEED    //this can be set to SPI_FULL_SPEED if you want
//SD Card
Sd2Card   card;
SdVolume  volume;
SdFile    root;
SdFile    file;
  int i;
    file.write(*p++);
  return i;
  int i;
    *p++ = file.read();
  return i;
  if (!enable_storage) {
    messageln ("Logger Disabled");
    return false;
  pinMode(CD_PIN, INPUT);
  digitalWrite(CD_PIN, HIGH);
  //look for a card
  if (digitalRead(CD_PIN)) {
    error ("SD Card: There is no SD card installed");
    enable_storage = false;
    return false;
  //try and initalise the card
  if (!card.init(CARDSPEED,9)) {
    error("SD Card: Failed to initalise card");
    return false;
  else {
    messageln ("SD Card: SD Card Initalised");
  if (!volume.init(&card)) {
    error("SD Card: Failed to initalise volume");
    return false;
  else {
    messageln ("SD Card: Volume initalised");
  if (!root.openRoot(&volume)) {
    error ("SD Card: Failed to initalise Root");
    return false;
  else {
    messageln ("SD Card: Root initalised");
  message("SD Card: Card Type - ");
  switch(card.type()) {
  case SD_CARD_TYPE_SD1:
    messageln("SD1");
  case SD_CARD_TYPE_SD2:
    messageln("SD2");
  case SD_CARD_TYPE_SDHC:
    messageln("SDHC");
  default:
    messageln("Unknown");
  if (!enable_storage) return;
  if (!file.open(&root, "config.alt", O_READ)) { //file doesn't exists
    if (file.open(&root, "config.alt", O_CREAT | O_APPEND | O_WRITE)) {
       file_writeAnything(configData);
       file.close();
       messageln("Created new config data file");
     file_readAnything(configData);
     file.close();
     messageln("Loaded config data");
  SdFile::remove(&root, "config.alt");
       file.close();
       messageln("Updated config data");
void storeData()
  char name[12];
  sprintf(name, "flt%05d.csv", flight_number);
  if (!file.open(&root, name, O_CREAT | O_APPEND | O_WRITE)) {
    error("Unable to open file");
  file.print(millis());
  file.print(",");
  file.print(altitude);
  file.print(",");
  file.print(filter.x);
  file.println();
  if (file.writeError) {
    error("File write failed");
  if (!file.close()) {
    error("File close failed");
ignore that last post.
Fixed it. :blush:
