Anomalous LoRa Duinotech Shield
Yet another post in the ongoing saga.
For months I have struggled to get the " callback " function of the LoRa .h working.
I have been unable to get any of the " example " call backs to work.
One Way transmission TX to RX and RX to TX works just fine but I just cannot get the
Rx to TX " callback function to work.
I have " cut and pasted" several sketches I have found and now finally have a functioning
program which does exactly as I require, but I have no idea how or why it works.
I have attached an example of part of the code in the hope that someone might be able to
offer a reason for the following anomalies;
  1. TX code. The callback function only works if I use a MILLIS timing loop with an INTERVAL
    greater than 1999.
    If I use a DELAY the TX works, however I get no callback.
  2. RX code. Unless I use the " VOID CURRENT" I will not get the CALLBACK to work.
I hope someone can offer some relevant and helpful response.
ty//.................................................................   TX SENDER   ..........................................
#include <SPI.h>
#include <LoRa.h>
//................................................................   LORA ADDRESSES   .............SENDER
byte localAddress = 0xAA;
byte destinationAddress = 0xBB;
long lastSendTime = 0;
unsigned int interval = 0;
//................................................................   VARIABLES
int count = 0; unsigned int staT  = 220; //   OUTGOING
int countRec = 0; long int staTRec  = 0; //   INCOMING
int statioN  = 0;  // STATION NUMBER 22 to 33
int onofF    = 0;  // 0 = ON ... 1 = OFF
//________________________________________________________________________________________________________________
//_______________________________________________________________________________________   VOID SETUP  __________SENDER
  //.............................................................   STARTING LORA   ....................
  Serial.println("Start LoRa duplex  TX  Sender");
  if (!LoRa.begin(915E6)) {
    Serial.println("LoRa init failed. Check your connections.");
    while (true) {}
//..............................................................   VOID SENDING DATA   ...........................SENDER
void senddatA()
  if (millis() - lastSendTime > 2000) {
    String sensorData = String(staT);
    sendMessage(sensorData);
    Serial.println("  SENT                 " + sensorData);
    digitalWrite(5, HIGH); delay(1000); digitalWrite(5, LOW);
    // Serial.print(" from 0x" + String(localAddress, HEX));
    // Serial.println(" to 0x" + String(destinationAddress, HEX));
    lastSendTime = millis();
//.............................................................   VOID SEND MESSAGE   .............................SENDER
void sendMessage(String outgoing) {
  LoRa.beginPacket();
  LoRa.write(destinationAddress);
  LoRa.write(localAddress);
  LoRa.write(outgoing.length());
  LoRa.print(outgoing);
  LoRa.endPacket();
//.............................................................   VOID RECEIVING MESSAGE   .........................SENDER
void receiveMessage(int packetSize) {
  if (packetSize == 0) return;
  int recipient = LoRa.read();
  byte sender = LoRa.read();
  byte incomingLength = LoRa.read();
  String incoming = "";
  while (LoRa.available()) {
    incoming += (char)LoRa.read();
  if (incomingLength != incoming.length()) {
    //Serial.println("Error: Message length does not match length");
    return;
  if (recipient != localAddress) {
    //Serial.println("Error: Recipient address does not match local address");
    return;
  staTRec = incoming.toInt();
  Serial.print("                       RECEIVED BACK  "); Serial.println(staTRec);
//_________________________________________________________________________________________________________________
//_______________________________________________________________________________________   VOID LOOP   ___________SENDER
  //............................................................   RECEIVING DATA   .....................
  receiveMessage(LoRa.parsePacket());
  //   <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<       DATA TO SEND      >>>>>>>>>>>>>>>>>>>>>>>>>
  if (millis() - lastSendTime > 2000) {//  2000 and above TX both sends and Receives.If Interval is reduced to less than 2000 it does not send data
    staT = 280; senddatA();
    delay(4000); //        Using delay  TX sends ok and RX sends back but TX  does NOT RECEIVE
}pe or paste code here
typ//.................................................................. RX RECEIVER ..........................................
#include <SPI.h>
#include <LoRa.h>
byte localAddress = 0xBB;
byte destinationAddress = 0xAA;
//................................................................. ENERGY MONITOR ......................................
#include "EmonLib.h" // Include Emon Library
#define CURRENT_CAL 250
EnergyMonitor emon1; // Create an instance
//................................................................. VARIABLES ............................................RX RECEIVER
int interval = 2000;
unsigned int reC = 0;
int statioN = 0;
int onofF = 0;
int incom = reC;
int aaa = 0; // Temp Variable
int loopCount = 0; // Energy Monitor Loop
int currentDraw = 0;
int AConoff = 0; // AC either ON = 1 or OFF = 0
int staToNOFF = 0; // Even number is OFF odd number is ON
int relay = 0;
//................................................................. ENERGY MONITOR ......................................RX RECEIVER
emon1.current(0, CURRENT_CAL); // Current: input pin, calibration.
//................................................................ STARTING LORA ....................................RX RECEIVER
Serial.println("Start LoRa duplex RX Receiver");
while (true) {}
void currenT() {
emon1.calcVI(20, 2000);        // Calculate all. No.of half wavelengths (crossings), time-out
float currentDraw            = emon1.Irms;             //extract Irms into Variable
//................................................................... OUTGOING DATA .....................................RX RECEIVER
LoRa.beginPacket();
LoRa.endPacket();
Serial.print("                           sending back   " ); Serial.println(outgoing);
digitalWrite(7, HIGH); delay(500); digitalWrite(7, LOW);
//................................................................... INCOMING DATA ............................................RX RECEIVER
reC = incoming.toInt();
Serial.print(" REC "); Serial.println(reC);
station();
//.................................................................... STATIONS .............................................RX RECEIVER
void station() {
statioN = ((reC / 10));
currenT(); //<<<<<<<<<<<<<<<<<< Delete this line is left IN the TX does not receive the sendback.
//<<<<<<<<<<<<<<<<<< with left in TX receives the SENDBACK OK >>>>>>>>>>>>>>>>>>>>>>>>>>
String staToNOFF = String(4287);
Serial.print(" SendBack 25 to 33 "); Serial.println(staToNOFF);
sendMessage(staToNOFF); // SEND BACK TO TX
//.................................................................... VOID LOOP .............................................RX RECEIVER
receiveMessage(LoRa.parsePacket()); // RECEIVE MESSAGE
}e or paste code here
4 years here and you aren't posting your code correctly? :slight_smile:
Please consider editing your post and properly putting your code in code tags.
Also, you can probably put all these questions into a single project thread, some might see this as cross-posting, but that's just my opinion. I'd look at your problem but I don't feel like digging through multiple threads.
Tidy up the post so the forum can read the code ?
`Where am I going wrong?
type or paste code here
I cut and paste the code into the above area and it comes out thus
type o#include <SPI.h>
#include <LoRa.h>
EnergyMonitor emon1;             // Create an instancer paste code here
See this post at the top of the forum;
Is this correct?
#include <SPI.h>
#include <LoRa.h>
int statioN  = 0;
int onofF    = 0;
int incom = reC;
int relay = 0;
    while (true) {}
void currenT() {
    LoRa.beginPacket();
    LoRa.endPacket();
  station();
void station() {
#include <SPI.h>
#include <LoRa.h>
    while (true) {}
void senddatA()
  LoRa.beginPacket();
  LoRa.endPacket();
    return;
    return;
Thats better, but a hint, when you post code, go back and hit the copy button and copy it into an Arduino sketch to check its OK.
I dont use that particular LoRa libray (I have my own) but your post says your trying to use the " callback function " and the API guide for that library says that to use callback you need to define it thus;
LoRa.onReceive(nameoffunction);
Do you have an onReceive() in your code ?
// LoRa.onReceive(LoRa.parsePacket());
Tried LoRa.onReceive and the TX received no reply.
Changed to receiveMessage and TX receives the reply OK
