Another arduino mega and wii nunchuck
Accidentally posted this in the wrong spot, so I'm re-posting it here :stuck_out_tongue:
Hey guys, so I figured I've lurked around on here long enough and although I've spent a bit of time poking around with the arduino, I still consider myself very green. I couldn't find this specific problem anywhere in the forum so I thought I'd post it here. I just learned not too long ago that the arduino can interface with a wii nunchuck and read the accelerometer data along with the joystick position, very cool! It saves me from having to buy one and solder it into a breakout board while trying to keep it somewhat level. Anyway, I've tried to communicate with the nunchuck using the code from windmeadow but I can't seem to get it working. I'm using the arduino mega (I had one lying around) and I have the SDA and SCL pins connected to pins 20 and 21. I upload the code, switch to the serial monitor, and all I get is "Finished Setup". So, I added a few more Serial.print lines just to see where things were stopping, and it looks like it stops communicating during nunchuck_init(), more specifically right after it sends the 0 at Wire.send(0x00) and before Wire.endTransmission(). Here's the code with the few serial.print lines I've added. Any thoughts on this? Thanks in advance!
#include <Wire.h>
#include <string.h>
#undef int
#include <stdio.h>
uint8_t outbuf[6];            // array to store arduino output
int cnt = 0;
int ledPin = 13;
void
setup ()
  Serial.begin (19200);
  Serial.print ("Finished setup\n");
  Wire.begin ();            // join i2c bus with address 0x52
  nunchuck_init (); // send the initilization handshake
void
nunchuck_init ()
  Serial.print ("Begin handshake\n");
  Wire.beginTransmission (0x52);      // transmit to device 0x52
  Serial.print ("0x52\n");
  Wire.send (0x40);            // sends memory address
  Serial.print ("0x40\n");
  Wire.send (0x00);            // sends sent a zero.
  Serial.print ("0x00\n");
  Wire.endTransmission ();      // stop transmitting
  Serial.print ("End handshake\n");
void
send_zero ()
  Wire.send (0x00);            // sends one byte
void
loop ()
  Wire.requestFrom (0x52, 6);      // request data from nunchuck
  while (Wire.available ())
      outbuf[cnt] = nunchuk_decode_byte (Wire.receive ());      // receive byte as an integer
      digitalWrite (ledPin, HIGH);      // sets the LED on
      cnt++;
  // If we recieved the 6 bytes, then go print them
  if (cnt >= 5)
      print ();
  cnt = 0;
  send_zero (); // send the request for next bytes
  delay (100);
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits.  That is why I
// multiply them by 2 * 2
void
print ()
  int joy_x_axis = outbuf[0];
  int joy_y_axis = outbuf[1];
  int accel_x_axis = outbuf[2] * 2 * 2;
  int accel_y_axis = outbuf[3] * 2 * 2;
  int accel_z_axis = outbuf[4] * 2 * 2;
  int z_button = 0;
  int c_button = 0;
 // byte outbuf[5] contains bits for z and c buttons
 // it also contains the least significant bits for the accelerometer data
 // so we have to check each bit of byte outbuf[5]
  if ((outbuf[5] >> 0) & 1)
      z_button = 1;
  if ((outbuf[5] >> 1) & 1)
      c_button = 1;
  if ((outbuf[5] >> 2) & 1)
      accel_x_axis += 2;
  if ((outbuf[5] >> 3) & 1)
      accel_x_axis += 1;
  if ((outbuf[5] >> 4) & 1)
      accel_y_axis += 2;
  if ((outbuf[5] >> 5) & 1)
      accel_y_axis += 1;
  if ((outbuf[5] >> 6) & 1)
      accel_z_axis += 2;
  if ((outbuf[5] >> 7) & 1)
      accel_z_axis += 1;
  Serial.print (joy_x_axis, DEC);
  Serial.print ("\t");
  Serial.print (joy_y_axis, DEC);
  Serial.print (accel_x_axis, DEC);
  Serial.print (accel_y_axis, DEC);
  Serial.print (accel_z_axis, DEC);
  Serial.print (z_button, DEC);
  Serial.print (c_button, DEC);
  Serial.print ("\r\n");
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char
nunchuk_decode_byte (char x)
  x = (x ^ 0x17) + 0x17;
  return x;
