Another Arduino + Serial Stepper Question
Hello,
I am having an awful time with such a simple thing. If anyone can help, it would be so much appreciated.
I am using an Arduino Mega + this stepper drive:
http://www.automationdirect.com/adc/Shopping/Catalog/Motion_Control/Stepper_Systems/Stepper_Drives_-z-_Power/STP-DRV-80100
It's a really cool drive. Just send serial, using their "SCL" syntax, and it just works. See page 9 of the manual for commands, and page 75 for basic setup.
http://www.automationdirect.com/static/manuals/surestepmanual/scl_manual.pdf.
I've used these drives all day with PLC's and no problem. The drive also works just fine with the supplied setup application. But with an Arduino, all I get after sending a command is a blinking light pattern indicating a COMM error.
My code starts off with:
Serial3.begin(9600);
some other non serial stuff here
and then on button press, initiates the following:
Serial3.print("FL20000\r");
I've tried all kinds of variations:
Serial3.println("FL20000");
Serial3.print("FL20000");
delay(10);
Serial3.print('\r');
Any suggestions? I'm pretty sure I didn't cross the Rx and Tx. I tried both ways several times, and I am clear on how that should work. Thanks to anyone who responds.
But you haven't told us what you have connected, where. You have connected grounds, right?
Are you using a MAX232 between the device and the Arduino? It looks to me like the device expects to be connected to a PC's serial port, which is NOT TTL serial, like the Arduino.
PaulS:
Ok, right. Attached is my wiring diagram. There is too much info on there, which is why I didn't post it. I also use a custom shield, so didn't want to confuse anyone. The serial pins connect directly to the stepper drive. Definitely, all grounds are connected.
Anyway, the drive came with a special cable- DB9 on one side and RJ11 on the other to connect to the drive. I cut the cable (I have a few extras), and by doing a continuity test I determined which were tx and rx and gnd. I confirmed this by doing another test with the RJ11 side, as indicated on page 75 of the SCL manual. I connected the tx, rx, and gnd from that cut cable directly to the arduino Serial3 pins D14 and D15. I did this cable cut method to get the drive working with a PLC (as instructed by AutomationDirect) on several occasions, and worked like a charm. I used this PLC:
http://www.automationdirect.com/adc/Shopping/Catalog/Programmable_Controllers/CLICK_Series_PLCs_(Stackable_Micro_Brick)/PLC_Units/C0-01DR-D.
I was of the understanding that an Arduino could communicated directly with a computer. And if that is the case, I figured that the Arduino could connect directly to the stepper drive just as well. I have the Arduino connected directly to the stepper drive, no MAX232 between.Thanks so much for replying to my question. I've done a lot of hardware work, but I'm fairly light on serial communication protocols.
Here's some more info on the drive.
It can. Through a serial to USB connection, NOT directly to a serial port.
Then the stepper drive wouldn't have come with a DB9 connector. The DB9 connector is to connect directly to a serial port. Serial output is +/- 12 to 15V, inverted from TTL serial, which is 0 or 5V.
Which says that it is a RS232 device (+/- 12 V), not a TTL device.
Well, I think you guys nailed it. Thank you for responding, and I am glad I posted! I'll look around and see if I can find a TTL to 232 converter. I see a bunch that work the other way around. But I'll look for the correct one. If you have one to recommend, let me know.
Thanks again.
PaulS:
A MAX232 chip converts from RS232 to TTL and from TTL to RS232. That is needed if communication is to be 2 way.
