Another Automotive Display
Hello,
as this Projekt is in a presentable state, here it is, another automotive display :slight_smile:
It is a ATmega328 at 16Mhz (running the Arduino Bootloader) with an 20x4LCD sitting directly on top.
The automotive part is a rugged powersupply (as it is on the MultiDisplay: GitHub - designer2k2/multidisplay: The MultiDisplay Project, An opensource datalogger, boost controller and display for cars)
The function is to measure 8 Thermocouples (will be installed in a 6 zylinder turbocharged engine), 1 Oiltemperature, Oilpressue, Fuelpressure, RPM and Boostpressure.
To do this there is a MCP3208 to read the Analog Values, a LTC1050 amplifies the Termocouple Values what are multiplexed by a 74HC4051D.
And USB-Serial is provided by a FT232RL.
Basically it is identical with the MultiDisplay, just smaller...
It has a warning output and the LCD brightness can be adjustet over PWM.
Over the USB Port is Datalogging possible, or the Software can be upgraded. (easier for the auto-guys as to handle ISP programmers...)
Today it had its first real show off, its got the bootloader:
then the big moment, will the USB work??
YES 8)
Putting the LCD on top:
And then just loaded the MultiDisplay code (GitHub - designer2k2/multidisplay: The MultiDisplay Project, An opensource datalogger, boost controller and display for cars)
Now i need to rework the Code that it also works on it... :roll_eyes:
Looks pretty neat. Can you post a schematic.
I'm curious about reading the TCs, I thought you need to have a cold junction reference which is what the special TC chips do.
Also the display, is that an "Electronic Assembly" unit?
Rob
