Another Chinese Digital Caliper
Hello all,
First of all thanks for the help i have found on this forum, its a great source of info.
Secondly i thought i would share my code to read my chinese digital verneer caliper. I have found lots of examples out there, but couldn't see a complete code for this type. Also i dont claim for one minute that i have (or could) write this code from scratch - it is more of a combination of lots of other peoples code as found on the net.
If anyone has advice of code improvement please let me know.
The caliper is the type that sends a single 24bit word of the structure described here -
I boutght mine from Chronos in the UK.
I hope this is of use to people.
Next i would like to expand it to read multiple calipers. I'm told that its possible to enable more than the standar 2 interrupts on a uno..... i'll put my investigating hat on.
Thanks again.
// code by mbconfuse 29/05/11
#include <avr/interrupt.h>
volatile int bumper;
int clockPin = 2;
int dataPin = 4;
int counter = 0;
const int numberBits = 24;
int data[numberBits];
int usedData[numberBits];
int decimalVal = 0;
int oldDecimalVal = 0;
int passedSync=0;
  pinMode(clockPin, INPUT);
  pinMode(dataPin, INPUT);
  attachInterrupt(0, bumperISR, FALLING);
  interrupts();
  bumper = 0;
void bumperISR()
char sample = 0;
  if(digitalRead(clockPin) == LOW)    sample++;
  if(sample > 2)
    bumper = 1;
// make sure loop starts at the begining of the data set
syncronization();
//start that data conversion
  if (bumper == 1 && passedSync ==1)
    //sample the reading 3 times
    data[counter] = sampleData (digitalRead(dataPin), 1);
    bumper = 0;
    counter++;
    if(counter >=numberBits)
     // tick the syncronisatoin button
     passedSync = 1;
     counter =0;
     //reverse the order of the binary bits
     reverseData();
     //printBinary();
     //convert the binary to decimal
     binaryToDecimal(usedData, numberBits);
// convert a binary string to a decimal number, returns decimal value
void binaryToDecimal(int TheArray[], int numBits)
int b, k, m, n;
int len;
//start bit and end bit are chosen to chop out the unwanted bits
int startBit = 3;
int endBit = 22;
  len = numBits;
  for(k = startBit; k <= endBit; k++)
    n = TheArray[k];
    if ((n > 1) || (n < 0))
      Serial.println("non_binary number!!");
    for(b = 1, m = endBit; m > k; m--)
      // 1 2 4 8 16 32 64 ... place-values, reversed here
      b *= 2;  //same as b = b * 2
    decimalVal = decimalVal + n * b;
     //only print if the decimal value has changed
     if (decimalVal != oldDecimalVal)
     Serial.print("Decimal =");
     // the 3rd bit is the positive/negative bit.  if it is 1 then value is negative.
     if(TheArray[2] == 1)
      Serial.print(" -");
     Serial.println(decimalVal);
     oldDecimalVal = decimalVal;
     decimalVal = 0;
//sample data three times
int sampleData(int readData, int highLow)
char sample = 0;
  if(readData == highLow)    sample++;
  if(sample > 2)
    return(highLow);
  else return((1-highLow));
//reverse all the binary bits
void reverseData()
     int k=0;
     for(int j = (numberBits-1) ; j >= 0; j--)
       usedData[k] = data[j];
       k++;
//print the binary
void printBinary()
        for (int i = 0 ; i < numberBits; i++)
           Serial.print(usedData[i]);;
       Serial.println("");
//sync so we start at the begining of a data set
//320 is approx lenght of gap between data sets
void syncronization()
      if(bumper == 1 && passedSync == 0)
      int time;
       do
        time = pulseIn(clockPin, HIGH);
      } while(time <  320);
           passedSync = 1;
           Serial.print("time - ");
           Serial.println(time);
           delay (320);
           bumper =0;
Yes it's called the pin change interrupt and an example of using it is in this project of mine.
http://www.thebox.myzen.co.uk/Hardware/Crazy_People.html
Thanks GrumpyMike, ive had a look at the page and i'll check out your code. Nice project. I had a shufti through some of your other bits and found your cnc mill video, which linked me on to your maker fair 2011 vid - amazing how many of my boxes that show ticked! Something for everyone there. It made me think of RepRap - RepRap, have you come across it?
