Another Class where method calls show the "does not name a type" problem
Hello,
I'm quite new to arduino and programming in general. My problem however is quite strange, since it seems others don't have a problem with this particular class. The class im talking about is SendOnlySoftwareSerial. I downloaded the class from the MultiWii project website and tried to use it in my own project, but somehow it isn't recognized by the aruino ide (Linux, v1.0.5). I created a test project, and stripped the class to bare minimum, but the problem remains. Below three files are all in a 'test' directory:
SendOnlySoftwareSerial.h
#ifndef SendOnlySoftwareSerial_h
#define SendOnlySoftwareSerial_h
#include "Arduino.h"
#include <inttypes.h>
#include <Stream.h>
class SendOnlySoftwareSerial : public Stream
private:
  uint16_t _tx_delay;
  uint16_t _inverse_logic;
  uint16_t _errors_ok;
  // private methods
  void setTX(uint8_t transmitPin);
public:
  // public methods
  SendOnlySoftwareSerial(uint8_t transmitPin, bool inverse_logic = false, bool errors_ok = false);
  ~SendOnlySoftwareSerial();
  void begin(long speed);
  void end();
  int peek();
  size_t write(uint8_t b);
  virtual int read();
  virtual int available();
  virtual void flush();
#endif  // SendOnlySoftwareSerial_h
SendOnlySoftwareSerial.cpp
#include <Stream.h>
#include <avr/pgmspace.h>
#include "SendOnlySoftwareSerial.h"
SendOnlySoftwareSerial::SendOnlySoftwareSerial(uint8_t transmitPin, bool inverse_logic /* = false */, bool errors_ok /* = false */) :
  _tx_delay(0),
  _inverse_logic(inverse_logic),
  _errors_ok(errors_ok)
  setTX(transmitPin);
SendOnlySoftwareSerial::~SendOnlySoftwareSerial()
  end();
void SendOnlySoftwareSerial::setTX(uint8_t tx)
  pinMode(tx, OUTPUT);
  digitalWrite(tx, HIGH);
void SendOnlySoftwareSerial::begin(long speed)
  _tx_delay = 200;
void SendOnlySoftwareSerial::end()
size_t SendOnlySoftwareSerial::write(uint8_t b)
    return 0;
int SendOnlySoftwareSerial::available()
    return 0;
int SendOnlySoftwareSerial::read()
    return -1;
void SendOnlySoftwareSerial::flush()
    return;
int SendOnlySoftwareSerial::peek()
    return -1;
test.ino
#define TELEMETRY_FRSKY_SOFTSERIAL_PIN 2
SendOnlySoftwareSerial sserial(TELEMETRY_FRSKY_SOFTSERIAL_PIN, true, true);
sserial.begin(9600);
This results in:
Error compiling.
test.ino:7:1: error: ‘sserial’ does not name a type
The same error comes, if I try to call the public 'write' method of the class, but doesn't come I just call the constructor (which does call the private 'setTX' method). Is there something obvious I'm missing here?
I'd appreciate any help... tia, juhis
Is that test.ino file ALL of your sketch? sserial.begin() is a method call, and cam not happen outside of a function.
