Another IRlibrary timer conflict
Hi to everyone. I know this have been posted before, but can't find a solution.
I have a proyect where I control a RGB via bluetooth Serial adapter. Now I want to add IR support, but when I add the line irrecv.enableIRIn() I start getting wrong values in the serial monitor. I'm running arduino UNO.
I'm using SoftwareSerial:
#define Rx       11 //This could be: 8,9,10,11,14 (MISO), 15 (SCK), 16 (MOSI).
#define Tx       2
#include <SoftwareSerial.h>
SoftwareSerial BT(Rx,Tx);
I've tried different pins, and also try modifying the IRremoteInt.h... but not sure which one to use, I'm running arduino UNo atmega328p, but can't find that on the library, this one?
// Teensy 2.0
#elif defined(__AVR_ATmega32U4__)
  #define IR_USE_TIMER1   // tx = pin 14
  //#define IR_USE_TIMER3   // tx = pin 9
  //#define IR_USE_TIMER4_HS  // tx = pin 10
i've tried with the three timers and still getting problems :frowning:
At first I thought it was a problem with PWM but then I realize the serial is going wrong.
Any idea?
Thank you very much!
This is the serial code:
void leerDatos2()
  if(BT.available() > 0)
    Serial.println(BT.read());
void leerDatos()
    char x = BT.read();
    if (x == '>') {
      readInProgress = false;
      newDataFromPC = true;
      inputBuffer[bytesRecvd] = 0;
      parseData();
    if(readInProgress)
      inputBuffer[bytesRecvd] = x;
      bytesRecvd ++;
      if (bytesRecvd == buffSize) {
        bytesRecvd = buffSize - 1;
    if (x == '<')
      bytesRecvd = 0;
      readInProgress = true;
void parseData()
  char * strtokIndx;
  byte aux=0, aux1=0;
  strtokIndx = strtok(inputBuffer,", (");
  aux1 = atoi(strtokIndx);
  opcion(aux1);
  strtokIndx = strtok(NULL, ", (");
  aux = atoi(strtokIndx);
  if(aux!=200)
    dato1 = aux;
  strtokIndx = strtok(NULL, ", ");
  if(aux!=200)
    dato2 = aux;
  if(aux!=200)
    dato3 = aux;
  strtokIndx = strtok(NULL,", )");
  if(aux!=200 && aux1>=1 && aux1<=8)
    dato4 = aux;
  mostrarDatos();
void mostrarDatos()
  Serial.print("<");
  Serial.print(opLed);
  Serial.print(", ");
  Serial.print(dato1);
  Serial.print(", ");
  Serial.print(dato2);
  Serial.print(", ");
  Serial.print(dato3);
  Serial.print(", ");
  Serial.print(dato4);
  Serial.println(">");
