Another menu attempt
Hi all, having somewhat given into the complexities of the previous menu system I was trying to get working, I have stumbled across this one which I have adapted for use with an OLED display. It all works fine, but I have been trying unsuccessfully to
A: Add or subtract menus.
B: Make the sub menus longer in options.
I seem to be doomed to failure on menus at the moment.
I want to understand how to fix it, so any suggestions would be awesome. Plus any ways in which the menu system could be improved?
Code below in two sections due to max length restrictions
Cheers
  //       Arduino Rotary Encoder Menu        //
 //                 v1.0                     //
//           http://www.educ8s.tv           //
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <ClickEncoder.h>
#include <TimerOne.h>
int menuitem = 1;
int frame = 1;
int page = 1;
int lastMenuItem = 1;
String menuItem1 = "Contrast";
String menuItem2 = "Volume";
String menuItem3 = "Language";
String menuItem4 = "Difficulty";
String menuItem5 = "Light: ON";
String menuItem6 = "Reset";
boolean backlight = true;
int contrast=60;
int volume = 50;
String language[3] = { "EN", "ES", "EL" };
int selectedLanguage = 0;
String difficulty[2] = { "EASY", "HARD" };
int selectedDifficulty = 0;
boolean up = false;
boolean down = false;
boolean middle = false;
ClickEncoder *encoder;
int16_t last, value;
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
  pinMode(7,OUTPUT);
  turnBacklightOn();
  encoder = new ClickEncoder(A1, A0, A2);
  encoder->setAccelerationEnabled(false);
  display.begin();
  display.clearDisplay();
  Timer1.initialize(1000);
  Timer1.attachInterrupt(timerIsr);
  last = encoder->getValue();
  drawMenu();
  readRotaryEncoder();
   ClickEncoder::Button b = encoder->getButton();
   if (b != ClickEncoder::Open) {
   switch (b) {
      case ClickEncoder::Clicked:
         middle=true;
  if (up && page == 1 ) {
    up = false;
    if(menuitem==2 && frame ==2)
      frame--;
     if(menuitem==4 && frame ==4)
      frame--;
      if(menuitem==3 && frame ==3)
      frame--;
    lastMenuItem = menuitem;
    menuitem--;
    if (menuitem==0)
      menuitem=1;
  }else if (up && page == 2 && menuitem==1 ) {
    up = false;
    contrast--;
  else if (up && page == 2 && menuitem==2 ) {
    up = false;
    volume--;
  else if (up && page == 2 && menuitem==3 ) {
    up = false;
    selectedLanguage--;
    if(selectedLanguage == -1)
      selectedLanguage = 2;
    else if (up && page == 2 && menuitem==4 ) {
    up = false;
    selectedDifficulty--;
    if(selectedDifficulty == -1)
      selectedDifficulty = 1;
  if (down && page == 1) //We have turned the Rotary Encoder Clockwise
    down = false;
    if(menuitem==3 && lastMenuItem == 2)
      frame ++;
    }else  if(menuitem==4 && lastMenuItem == 3)
      frame ++;
     else  if(menuitem==5 && lastMenuItem == 4 && frame!=4)
      frame ++;
    menuitem++;
    if (menuitem==7)
      menuitem--;
  }else if (down && page == 2 && menuitem==1) {
    down = false;
    contrast++;
  else if (down && page == 2 && menuitem==2) {
    down = false;
    volume++;
   else if (down && page == 2 && menuitem==3 ) {
    down = false;
    selectedLanguage++;
    if(selectedLanguage == 3)
  else if (down && page == 2 && menuitem==4 ) {
    down = false;
    selectedDifficulty++;
    if(selectedDifficulty == 2)
  if (middle) //Middle Button is Pressed
    middle = false;
    if (page == 1 && menuitem==5) // Backlight Control
      if (backlight)
        backlight = false;
        menuItem5 = "Light: OFF";
        turnBacklightOff();
        backlight = true;
        turnBacklightOn();
    if(page == 1 && menuitem ==6)// Reset
      resetDefaults();
    else if (page == 1 && menuitem<=4) {
      page=2;
      else if (page == 2)
      page=1;
  void drawMenu()
  if (page==1)
    display.setTextSize(1);
    display.setTextColor(BLACK, WHITE);
    display.setCursor(15, 0);
    display.print("MAIN MENU");
    display.drawFastHLine(0,10,83,BLACK);
    if(menuitem==1 && frame ==1)
      displayMenuItem(menuItem1, 15,true);
      displayMenuItem(menuItem2, 25,false);
      displayMenuItem(menuItem3, 35,false);
    else if(menuitem == 2 && frame == 1)
      displayMenuItem(menuItem1, 15,false);
      displayMenuItem(menuItem2, 25,true);
    else if(menuitem == 3 && frame == 1)
      displayMenuItem(menuItem3, 35,true);
     else if(menuitem == 4 && frame == 2)
      displayMenuItem(menuItem2, 15,false);
      displayMenuItem(menuItem3, 25,false);
      displayMenuItem(menuItem4, 35,true);
      else if(menuitem == 3 && frame == 2)
      displayMenuItem(menuItem3, 25,true);
      displayMenuItem(menuItem4, 35,false);
    else if(menuitem == 2 && frame == 2)
      displayMenuItem(menuItem2, 15,true);
    else if(menuitem == 5 && frame == 3)
      displayMenuItem(menuItem3, 15,false);
      displayMenuItem(menuItem4, 25,false);
      displayMenuItem(menuItem5, 35,true);
    else if(menuitem == 6 && frame == 4)
      displayMenuItem(menuItem4, 15,false);
      displayMenuItem(menuItem5, 25,false);
      displayMenuItem(menuItem6, 35,true);
      else if(menuitem == 5 && frame == 4)
      displayMenuItem(menuItem5, 25,true);
      displayMenuItem(menuItem6, 35,false);
      else if(menuitem == 4 && frame == 4)
      displayMenuItem(menuItem4, 15,true);
    else if(menuitem == 3 && frame == 3)
      displayMenuItem(menuItem3, 15,true);
      displayMenuItem(menuItem5, 35,false);
    else if(menuitem == 4 && frame == 3)
      displayMenuItem(menuItem4, 25,true);
    display.display();
  else if (page==2 && menuitem == 1)
   displayIntMenuPage(menuItem1, contrast);
  else if (page==2 && menuitem == 2)
   displayIntMenuPage(menuItem2, volume);
   else if (page==2 && menuitem == 3)
   displayStringMenuPage(menuItem3, language[selectedLanguage]);
  else if (page==2 && menuitem == 4)
   displayStringMenuPage(menuItem4, difficulty[selectedDifficulty]);
I'm looking through all the else if statements like these and I can't see the rhyme or reason there. They seem all jumbled up. Get them into some order that makes sense and you might see something.
I did notice that there were two entries for 2 and 2 like this:
Seems like all of those else ifs do basically the same thing only with different menu items and different arguments. Seems like there should be a way to make that into a single function that takes the menuitem and frame as arguments and either calculates those numbers or looks them up in an array.
