Another Mouse sensor guy needing help
I have read a bunch of them and I am still in need of help processing data from a optical mouse sensor I have either a paw3402 or a mcs12085 (with a seperate resonator) to work with.
Right now I am trying to just get x, y values but eventually I want to interpret those vales and make the arduino spin a haptic motor every time the sensor registers movement over "x" values and then reset to do it again... Can anyone help me???
Right now all I get back is repeating 14640 line after line.
I am jumping off something done by John Graham-Cumming (see below for ino sketch .cpp and .h data)
Thanks a BUNCH,
Rory
mcs-12085.cpp (3.08 KB)
mcs-12085.h (305 Bytes)
mcs-12085.ino (1.59 KB)
I suspect you should call mcs12085_init() in setup().
Too bad the library doesn't come with any examples.
You have to use Pin 4 for clock and Pin 7 data unless you edit mcs-12085.cpp.
John,
Thanks for getting back with me I am using 4 and 7 for now. I inserted the mcs12085_int() and now get data in the serial monitor but it is gibberish.. see screen capture attached
I am guessing wrong baud rate for the chip.
tested baud rate change and no luck. Is there something in the .cpp file that is not converting it to a legible integer? Each line of gibberish is only created when the sensor moving; with no movement it is only a comma.
Got it to give me tangible data in x or y but not together. this is fine because I am only concerned with one axis... So
Can anyone help me with the script to record and sum the outputs from my chip and when the total movement is greater than +/- 10 it runs a vib motor sketch (below) and resets for next delta movement?
I THANK YOU VERY MUCH in advance.
const int motorPin = 3;
pinMode(motorPin, OUTPUT);
digitalWrite(motorPin, HIGH);
delay(40);
I think your problem is this:
Serial.println(mcs12085_dx(),mcs12085_dy());
If you look up the definition of .println() it will not display two integers if you pass two integers. You should make one call per integer:
Serial.print(mcs12085_dx());
Serial.println(mcs12085_dy());
yep your right. I overlooked that fact. I am very new to c++ and am learning the commands as I go. So please be patient.
Now I am trying to sum the outputs and generate my response it works at the correct movement rate. But I want it to fire 3x when I move one large jump that is 3 times my threshold..? should I be using if else statments or sum function? is an if statement the best way to deal with the negative values?
int i = mcs12085_dy();
 for (i;  i >= 4; i = i + i + i + i + i + i + i + i + i + i + i + i + i)
  vib();
 for (i;  i >= 8; i=i)
  vib2();
 for (i; i >= 19; i = i)
 vib3();
// for (int i = mcs12085_dy(); 19 < i < 24; i = i + i + i + i + i)
//  vib4();
 void vib()
  delay(5);
  digitalWrite(motorPin, LOW);
 void vib2()
  delay(5);
  delay(150);
  delay(5);
 void vib3()
  delay(5);
  delay(150);
  delay(5);
  delay(150);
  delay(5);
What I would do is just measure absolute motion and vibrate each time the motion exceeds your vibrate threshold:
unsigned long TotalMotion;
const unsigned long Threshold = 20;  // Vibrate each time motion exceeds 20 pixels
    int motion = mcs12085_dy();
   if (motion >= 0)
      TotalMotion += motion;  /// shorthand for 'TotalMotion = TotalMotion + motion;'
      TotalMotion -= motion;  // Subtract any negative values
  // Vibrate if threshold is reached
   if (TotalMotion >= Threshold) {
     TotalMotion -= Threshold;
      delay(5);
      delay(150);
John-
Thanks. I realize that there are multiple ways to tackle this and I have strugled finding the best way. I was trying to write the script for total motion + motion and didn't know how to write it. Thanks a lot; especially for including the description text next to your code! THANKS again from another novice c++/duino guy.
Hey, Rory.
Still out there, messing with your hacked mouse?
I'm just getting started. I ran across John G-C's article
The mouse I'm using has a MX8733 optical sensor 8-pin chip. It seems very similar to the MCS-12086.
I'm also using an Arduino UNO. I'm connected fine. And I'm running the Arduino code just like yours.
However, I'm only getting -1 for both X and Y. Nothing else.
Could you post a pic of how you wired your mouse chip? I don't get what I'm doing wrong.
Thanks!
Rick
