Hello,
Im just starting to get a grasp of pointers. I’m told they work really well for passing arrays to functions.
I made this program last night that gets a temp reading from a OneWire sensor and then prints elapsed time. It does this in two ways; passing the global address array to a function that takes it in as a pointer and the other function doesnt get passed the array at all, it just uses the global array when talking to the sensor. On average, the pointer function was 220 microseconds quicker but uses 6 more bytes of instruction memory.
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
#define oneWireBus 2
byte address[8];
OneWire oneWire(oneWireBus);
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
float temp;
unsigned long lastTime = 0, currentTime = 0;
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
digitalWrite(3, HIGH);
digitalWrite(4, LOW);
lcd.begin(16, 2);
lcd.print(F("oneWire temp ptr"));
Serial.begin(19200);
lcd.clear();
oneWire.search(address);
currentTime = micros();
temp = getOneWireTemp(address);
lastTime = micros();
Serial.print(F("temp is: "));
Serial.print(temp);
Serial.print(F("C. It took "));
Serial.print(lastTime - currentTime);
Serial.println(F(" ms.")); //takes 9400/474
temp = getOneWireTemp2();
Serial.print(F("temp2 is: "));
Serial.print(temp);
Serial.println(F(" ms.")); //takes 9394/474.
float getOneWireTemp(byte *str) { //get OneWire temp.
byte data[2]; //array to store data retrieved from sensor.
oneWire.reset();
oneWire.select(str);
oneWire.write(0x44, 1); //start conversion.
oneWire.reset();
oneWire.write(0xBE); //read scratchpad.
for (byte i = 0; i < 2; i ++) {
data[i] = oneWire.read(); //collect data.
} //end for.
int16_t raw = (data[1] << 8) | data[0]; //convert raw data to C.
return (float)raw / 16.0;
} //end getOneWireTemp().
float getOneWireTemp2() { //get OneWire temp.
oneWire.reset();
oneWire.select(address);
oneWire.reset();
} //end for.
So onto my question: I get that Im sending the array as an argument to the function that is taking it IN as a pointer. Would you ever send a pointer OF the array AS the argument? Again, my grasp of pointers is very limited at this point so any very help is very much appreciated.
