Hi Guys, totally new to Arduino, I've built a 3D scanner off Thingiverse and having trouble with it. It all seems to work ok except an issue with stepper motor getting really hot. It's a known issue with this project and have found some code to fix it but no idea where to place the code into the original .ino file.
This is the project,
(Thingiverse - Digital Designs for Physical Objects)
This is the fix code.
void stop()// When stepper motor doesn't use, control pins are reset to low level
digitalWrite(9, LOW); // logic level is low
digitalWrite(10, LOW); // logic level is low
digitalWrite(11, LOW); // logic level is low
digitalWrite(12, LOW); // logic level is low
int XValue = analogRead(X_pin); // Read the analog value from The X-axis from the joystick
int YValue = analogRead(Y_pin); // Read the analog value from The Y-axis from the joystick
int SwValue = digitalRead(SW_pin); // Read the digital value from The Button from the joystick
stop();// When stepper motor doesn't use, control pins are reset to low level
if (MenuNr < 0){ //This sets the min number of menu's
MenuNr = 0;
And this is the original .ino.
Reworked the original code from Brian Brocken
Using an ESP32 D1 R32 board for Bluetooth connectivity
Reworked the Menu system
Added saving defaults to EEPROM and retrieving then at startup
Added BT HID Keyboard operation to eliminate the servo that operates BT Remote shutter
#include <LiquidCrystal_I2C.h> // library for LCD displays with I2C backpack
#include <Wire.h> // needed for the LCD I2C library.
#include <EEPROM.h> // We will get/put the default settings from/to te EEPROM
#include <Stepper.h> // Lib for the stepper motors
#include <BleKeyboard.h> // Lib for Bluetooth keyboard emulation
// Joystick Pins
#define X_PIN 39 // analog pin connected to X output
#define Y_PIN 36 // analog pin connected to Y output
#define SW_PIN 4 // digital pin connected to switch output
// Stepper Pins
#define IN1_PIN 16
#define IN2_PIN 17
#define IN3_PIN 25
#define IN4_PIN 26
// Menu-system
#define MENUITEM_LENGTH 16 // max length of a menuitem
#define LOW_THRESHOLD 500 // below this analog value, joystick is considered low
#define HIGH_THRESHOLD 3500 // above this analog value, joystick is considered high
#define SLOW_FASTCHANGEDELAY 600
#define FASTCHANGEDELAY 200
#define DEFAULTS_EYECATCHER 0b10101010
#define DEFAULTS_VERSION 0x01
// Stepper parameters
const int stepsPerRevolution = 2096; // change this to fit the number of steps per revolution
int FullRev = 7 * stepsPerRevolution; // 1 full revolution of the big gear -> Small-Big gear ratio is 7:1
Stepper myStepper(stepsPerRevolution, IN1_PIN, IN3_PIN, IN2_PIN, IN4_PIN); // Use these pins for the stepper motor
// We use a 16x2 with I2C backpack
LiquidCrystal_I2C lcd(0x27, 16, 2); // Assumes default I2C address of 0x27
// We will emulate a BLE Keyboard
BleKeyboard myKB("Bluetooth shutter", "Espressif", 100);
// Global variables for joystick operation
int SwValue = 1;
int SwPrevValue = 1;
int XValue = 512;
int XPrevValue = 512;
int YValue = 512;
int YPrevValue = 512;
bool prevDirection = 0;
// Global variables for menu system
int MainMenuPos = 0;
int SubMenuPos = 0;
char MainMenu[6][MENUITEM_LENGTH] =
{ "Main Menu ",
"Photogrammetric",
"Cinematic ",
"Manual mode ",
"Defaults "
char PhotoMenu[7][MENUITEM_LENGTH] =
{ "> Photogrametry",
"#P#", // placeholder nmbr of photos
"#S#", // placeholder motor speed
"#B#", // placeholder delay before
"#A#", // placeholder delay after
"Press to start ",
"Return to Main "
char CineMenu[5][MENUITEM_LENGTH] =
{ "> Cinematic ",
"#T#", // placeholder nmbr of turns
"Press to start ",
"Return to Main "
char ManualMenu[5][MENUITEM_LENGTH] =
{ "> Manual mode ",
"#Z#", // placeholder step size
"Press to start ",
"Return to Main "
char DefaultsMenu[11][MENUITEM_LENGTH] =
{ "> Defaults ",
"#D#", // placeholder key to send
"#K#", // placeholder key to send
"Press to save ",
"Return to Main "
// FastChange variables
const unsigned long FastDelay = 1000; // delay mode time (before values change fast)
int FastChng = 0; // indicates fast change value mode. 0 = off, 1 = up mode, -1 = down mode
unsigned long SetTime = 0; // time value for fast change & button cancel modes. Used to calculate time intervals
// Hardcoded operation parameter limits
const int MAX_PHOTOS = 200;
const int MIN_PHOTOS = 2;
const int MAX_TURNS = 200;
const int MIN_TURNS = 1;
const int MAX_SPEED = 17;
const int MIN_SPEED = 1;
const int MAX_SIZE = 150;
const int MIN_SIZE = 1;
const int MAX_KEY = 2;
const int MIN_KEY = 1;
const int MAX_BEFORE = 5;
const int MIN_BEFORE = 0;
const int MAX_AFTER = 10;
const int MIN_AFTER = 1;
// The current values of the operation parameters
int CurTurns;
int CurSpeed;
int CurPhotos;
int CurStepSize;
char CurDirection;
int CurDelayBefore;
int CurDelayAfter;
int CurKey2Send;
// The structure used to store defaults to the EEPROM
struct MyDefaults_struct {
uint8_t EyeCatcher;
uint8_t Version;
int DefaultTurns;
int DefaultSpeed;
int DefaultPhotos;
int DefaultStepSize;
int DefaultKey2Send;
int DefaultDelayBefore;
int DefaultDelayAfter;
char DefaultDirection;
int EEPROM_SIZE = sizeof(MyDefaults_struct);
// The global instance of the default-structure
MyDefaults_struct MyDefaults;
const int eeAddress = 0; // We expect the defaults to be at address 0 in the eeprom
// setup
// My insert
lcd.init(); // LCD init
lcd.backlight(); // LCD turn backlight on
pinMode(SW_PIN, INPUT_PULLUP); // Joystick pushbutton as input
EEPROM.begin(EEPROM_SIZE);
// Ready to connect via Bluetooth
myKB.begin();
Serial.println( "Ready to connect over Bluetooth...");
// Read the defaults from the EEPROM
Serial.println( "Reading defaults from EEPROM...");
EEPROM.get( eeAddress, MyDefaults);
if ((MyDefaults.EyeCatcher != DEFAULTS_EYECATCHER) || (MyDefaults.Version != DEFAULTS_VERSION)) {
// EEPROM does not have saved default values, so use hardcoded ones instead
Serial.println( "No defaults found in EEPROM...");
Serial.println( "Using hardcoded default values...");
MyDefaults.DefaultTurns = 1;
MyDefaults.DefaultSpeed = 15;
MyDefaults.DefaultPhotos = 8;
MyDefaults.DefaultStepSize = 2;
MyDefaults.DefaultKey2Send = 1;
MyDefaults.DefaultDelayBefore = 1; // 1= Enter(Android) / 2=Vol.Up (IOS)
MyDefaults.DefaultDelayAfter = 1;
MyDefaults.DefaultDirection = 'L'; // L=Left (Clockwise) / R=Right (Counterclockwise)
MyDefaults.EyeCatcher = DEFAULTS_EYECATCHER;
MyDefaults.Version = DEFAULTS_VERSION;
else {
Serial.println( "Defaults found in EEPROM...");
Serial.print( "Defaults version is ");
Serial.println( MyDefaults.Version, DEC);
Serial.print( "Default turns= ");
Serial.println( MyDefaults.DefaultTurns, DEC);
Serial.print( "Default manual step-size= ");
Serial.println( MyDefaults.DefaultStepSize, DEC);
Serial.print( "Default direction= ");
Serial.println( MyDefaults.DefaultDirection);
Serial.print( "Default photos= ");
Serial.println( MyDefaults.DefaultPhotos, DEC);
Serial.print( "Default key to send= ");
Serial.print( MyDefaults.DefaultKey2Send, DEC);
Serial.print( " (1=Enter;2=Volume Up)");
Serial.print( "Default delay before= ");
Serial.println( MyDefaults.DefaultDelayBefore, DEC);
Serial.print( "Default delay after= ");
Serial.println( MyDefaults.DefaultDelayAfter, DEC);
// Startup Screens
lcd.setCursor(4, 0);
lcd.print("Welcome!");
lcd.setCursor(0, 1);
lcd.print("ESP32 Soft.V1.0.");
delay(3000);
lcd.clear();
lcd.print("Designed by");
lcd.print("Brian Brocken");
delay(3000);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Software by");
lcd.print("Marco64");
delay(3000);
// keyPressed - determines if the joystick is pressed
bool keyPressed() {
if ((SwValue == 0) && (SwPrevValue != SwValue)) {
SetTime = 0;
FastChng = 0;
return (1);
else {
return (0);
// rightPressed - determines if the joystick is moved to the right
bool rightPressed() {
if ((XValue <= LOW_THRESHOLD) && (XPrevValue > LOW_THRESHOLD)) {
prevDirection = 1;
FastChng = 0;
SetTime = 0;
FastChng = 0;
return (1);
else {
return (0);
// leftPressed - determines if the joystick is moved to the left
bool leftPressed() {
if ((XValue >= HIGH_THRESHOLD) && (XPrevValue < HIGH_THRESHOLD)) {
prevDirection = 1;
FastChng = 0;
SetTime = 0;
FastChng = 0;
return (1);
else {
return (0);
// upPressed - determines if the joystick is moved up
bool upPressed() {
if ((YValue <= LOW_THRESHOLD) && (YPrevValue > LOW_THRESHOLD)) {
SetTime = millis();
prevDirection = 1;
FastChng = 0;
return (1);
else {
(FastChng == 0) &&
((millis() - SetTime) > FastDelay)) {
FastChng = 1;
Serial.println("Entering fastchange mode");
return (0);
// downPressed - determines if the joystick is moved down
bool downPressed() {
if ((YValue >= HIGH_THRESHOLD) && (YPrevValue < HIGH_THRESHOLD)) {
SetTime = millis();
prevDirection = 1;
FastChng = 0;
return (1);
else {
(FastChng == 0) &&
FastChng = -1;
return (0);
// noDirection - determines if the joystick is in 'neutral' position
bool noDirection() {
if ((YValue < HIGH_THRESHOLD) &&
(YValue > LOW_THRESHOLD) &&
(XValue < HIGH_THRESHOLD) &&
(XValue > LOW_THRESHOLD) &&
!keyPressed() &&
prevDirection == 1) {
SetTime = 0;
FastChng = 0;
prevDirection = 0;
return (1);
else {
return (0);
// readInputs - read the analog values from the joystick
void readInputs() {
// save previous values
SwPrevValue = SwValue;
XPrevValue = XValue;
YPrevValue = YValue;
// Read all inputs
XValue = analogRead(X_PIN); // Read the analog value from The X-axis from the joystick
YValue = analogRead(Y_PIN); // Read the analog value from The Y-axis from the joystick
SwValue = digitalRead(SW_PIN); // Read the digital value from The Button from the joystick
// placeholderPrint - print menuitems with placeholders and their values to the LCD screen
void placeholderPrint(char* iPlaceholder) {
if (strcmp(iPlaceholder, "#P#") == 0) {
lcd.print("# Photo's: ");
lcd.setCursor(13, 1);
lcd.print(CurPhotos);
else if (strcmp(iPlaceholder, "#T#") == 0) {
lcd.print("# Turns: ");
lcd.print(CurTurns);
else if (strcmp(iPlaceholder, "#S#") == 0) {
lcd.print("Motor Speed: ");
lcd.print(CurSpeed);
else if (strcmp(iPlaceholder, "#D#") == 0) {
lcd.print("Direction: ");
lcd.print(CurDirection);
else if (strcmp(iPlaceholder, "#K#") == 0) {
lcd.print("Shutter Key: ");
lcd.print(CurKey2Send);
else if (strcmp(iPlaceholder, "#B#") == 0) {
lcd.print("Delay Before: ");
lcd.print(CurDelayBefore);
else if (strcmp(iPlaceholder, "#A#") == 0) {
lcd.print("Delay After: ");
else if (strcmp(iPlaceholder, "#Z#") == 0) {
lcd.print("Step size: ");
lcd.print(CurStepSize);
else {
lcd.print(iPlaceholder);
// placeholderInc - increment the variable using its placeholder
void placeholderInc(char* iPlaceholder) {
CurPhotos += 2; // step by 2 at a time
if (CurPhotos > MAX_PHOTOS) CurPhotos = MAX_PHOTOS;
if (FastChng == 1) delay(FASTCHANGEDELAY);
CurTurns++;
if (CurTurns > MAX_TURNS) CurTurns = MAX_TURNS;
CurSpeed++;
if (CurSpeed > MAX_SPEED) CurSpeed = MAX_SPEED;
if (FastChng == 1) delay(SLOW_FASTCHANGEDELAY);
CurKey2Send++;
if (CurKey2Send > MAX_KEY) CurKey2Send = MAX_KEY;
CurDelayBefore++;
if (CurDelayBefore > MAX_BEFORE) CurDelayBefore = MAX_BEFORE;
CurDelayAfter++;
if (CurDelayAfter > MAX_AFTER) CurDelayAfter = MAX_AFTER;
CurStepSize++;
if (CurStepSize > MAX_SIZE) CurStepSize = MAX_SIZE;
if (CurDirection == 'L') CurDirection = 'R';
else if (CurDirection =='R') CurDirection = 'L';
// placeholderDec - decrement the variable using its placeholder
void placeholderDec(char* iPlaceholder) {
CurPhotos -= 2; // step by 2 at a time
if (CurPhotos < MIN_PHOTOS) CurPhotos = MIN_PHOTOS;
if (FastChng == -1) delay(FASTCHANGEDELAY);
CurTurns--;
if (CurTurns < MIN_TURNS) CurTurns = MIN_TURNS;
CurSpeed--;
if (CurSpeed < MIN_SPEED) CurSpeed = MIN_SPEED;
if (FastChng == -1) delay(SLOW_FASTCHANGEDELAY);
CurKey2Send--;
if (CurKey2Send < MIN_KEY) CurKey2Send = MIN_KEY;
CurDelayBefore--;
if (CurDelayBefore < MIN_BEFORE) CurDelayBefore = MIN_BEFORE;
CurDelayAfter--;
if (CurDelayAfter < MIN_AFTER) CurDelayAfter = MIN_AFTER;
CurStepSize--;
if (CurStepSize < MIN_SIZE) CurStepSize = MIN_SIZE;
// showMenu
// Generic routine to display menu and return the choice made
// The menuItems to display are passed using an array
// The first entry of the array is the name of the menu
int showMenu(int iItemsCount, char iMenuItems[][MENUITEM_LENGTH] ) {
int MenuPos = 1;
Serial.println("Entering showMenu");
Serial.print("Menu to display:");
Serial.println(iMenuItems[0]);
lcd.clear();
lcd.print(iMenuItems[0]);
if (iMenuItems[MenuPos][0] == '#') {
placeholderPrint(iMenuItems[MenuPos]);
else lcd.print(iMenuItems[MenuPos]);
readInputs();
while (!keyPressed()) {
if (!noDirection()) {
if (leftPressed()) {
MenuPos++;
if (MenuPos > iItemsCount - 1) MenuPos = 1;
if (rightPressed()) {
MenuPos--;
if (MenuPos < 1) MenuPos = iItemsCount - 1;
if (upPressed() || FastChng == 1) {
placeholderInc(iMenuItems[MenuPos]);
if (downPressed() || FastChng == -1) {
placeholderDec(iMenuItems[MenuPos]);
readInputs();
return (MenuPos);
// takePhoto - send the correct key to the smartphone over BLE to take a picture
void takePhoto() {
if (myKB.isConnected()) {
if (CurKey2Send == 2) {
Serial.println("Sending Volume Up key for IOS devices ...");
myKB.write(KEY_MEDIA_VOLUME_UP);
else {
Serial.println("Sending Enter key for Android devices ...");
myKB.write(KEY_RETURN);
// photoDialog - the dialog of the Photogrammetric mode
void photoDialog() {
int MenuChoice = 0;
while (MenuChoice != 6) {
MenuChoice = showMenu(7, PhotoMenu);
switch (MenuChoice) {
case (5): {
// Start Photogrammetric mode
// Show number of photos on LCD
lcd.clear();
lcd.print("Running...");
myStepper.setSpeed(CurSpeed); //Set RPM of steppermotor
//Calculate number of steps between photo's
int numSteps = FullRev / CurPhotos;
// Determine direction
if (CurDirection == 'L') numSteps = -numSteps;
int i = 1;
do {
lcd.print("Photo ");
lcd.print(i);
lcd.print(" of ");
myStepper.step(numSteps);
delay(CurDelayBefore * 1000);
takePhoto();
delay(CurDelayAfter * 1000);
i++;
} while (i <= CurPhotos);
otherwise: {
return;
// cineDialog - the dialog of the Cinematic mode
void cineDialog() {
int MenuChoice = 0;
while (MenuChoice != 4) {
MenuChoice = showMenu(5, CineMenu);
case (3): {
// Start Cinematic mode
// Show number of turns on LCD
int i = 1;
lcd.clear();
int numSteps = FullRev;
do {
lcd.print("Turn ");
lcd.print(i);
lcd.print(" of ");
i++;
} while (i <= CurTurns);
otherwise: {
return;
// manualDialog - the dialog of the Manual mode
void manualDialog() {
int MenuChoice = 0;
MenuChoice = showMenu(5, ManualMenu);
case (3): {
// Start Manual mode
// Show instructions on LCD
lcd.clear();
lcd.print("Press to leave.");
do {
readInputs();
lcd.print("<- direction ->");
// Move in the desired direction
myStepper.step(-CurStepSize * 100);
myStepper.step(CurStepSize * 100);
} while (!keyPressed());
otherwise: {
return;
// defaultsDialog - the dialog of the operation defaults ( saving to EEPROM )
void defaultsDialog() {
int MenuChoice = 0;
while (MenuChoice != 10) {
MenuChoice = showMenu(11, DefaultsMenu);
case (9): {
//Save the defaults to EEPROM
MyDefaults.DefaultTurns = CurTurns;
MyDefaults.DefaultPhotos = CurPhotos;
MyDefaults.DefaultSpeed = CurSpeed;
MyDefaults.DefaultStepSize = CurStepSize;
MyDefaults.DefaultKey2Send = CurKey2Send;
MyDefaults.DefaultDelayBefore = CurDelayBefore;
MyDefaults.DefaultDelayAfter = CurDelayAfter;
MyDefaults.DefaultDirection = CurDirection;
EEPROM.put(eeAddress, MyDefaults);
EEPROM.commit();
otherwise: {
return;
// mainMenu - the main menu dialog
void mainMenu() {
int MenuChoice;
MenuChoice = showMenu(5, MainMenu);
case (1): {
photoDialog();
case (2): {
cineDialog();
case (3): {
manualDialog();
case (4): {
defaultsDialog();
// loop - the main loop
CurTurns = MyDefaults.DefaultTurns;
CurSpeed = MyDefaults.DefaultSpeed;
CurPhotos = MyDefaults.DefaultPhotos;
CurStepSize = MyDefaults.DefaultStepSize;
CurKey2Send = MyDefaults.DefaultKey2Send;
CurDelayBefore = MyDefaults.DefaultDelayBefore;
CurDelayAfter = MyDefaults.DefaultDelayAfter;
CurDirection = MyDefaults.DefaultDirection;
mainMenu();
Any help greatly appreciated.
