Another nRF24L01 Question
I’m working on a wireless traffic light. For my feeling im I very close. I’m still a bit new to arduino and the RF24 module. But i have it working but not quiet the way i wanted to work. I will post my code below.
The it’s working fine until i put the delay for the timing in the Transceiver module. If i put the timing in the TX code it’s working but if i start more then 1 receiver the loop is not syngrome. even when I restart the RX node.
Can somebody look at my code and explain what i’m doing wrong? if you have any question feel free to ask.
TX
Code For Wireless traffic light Transceiver.
Head node sends signal to 3 other nodes in a star network
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
int msg[1]; // Send over package message
RF24 radio(9,10);       // Set up nRF24L01 radio on SPI bus plus pins 9 & 10
const uint64_t pipe = 0xE8E8F0F0E1LL; // Radio pipe addresses for the 2 nodes to communicate.
int red = 5; // LED red on pin 7
int orange = 4; // LED orange on pin 6
int green = 3; // LED green on pin 5
void setup(void){ //Setup and configure rf radio
  radio.begin();
  radio.openWritingPipe(pipe);  // Open pipe to other nodes for communication
  pinMode (red, OUTPUT); // Pinmode for LED OUTPUT
  pinMode (orange, OUTPUT); // Pinmode for LED OUTPUT
  pinMode (green, OUTPUT);} // Pinmode for LED OUTPUT
void loop(void){
  digitalWrite(red, HIGH); //starting red HIGH
  if (digitalRead(red) == HIGH)delay(1000);{{ // If red is HIGH Send Message 001 for 1 second
  msg[0] = 001;
  radio.write(msg, 1);} //write msg
  digitalWrite(orange, HIGH); //starting red HIGH
  if (digitalRead(orange) == HIGH)delay(1000);{ // If orange is HIGH Send Message 002 for 1 second
  msg[0] = 002; //
  digitalWrite(green, HIGH); //starting red HIGH
  if (digitalRead(green) == HIGH)delay(1000);{ // If red is HIGH Send Message 003 for 1 second
  msg[0] = 003;
  radio.write(msg, 1); //write msg
RX code
Code For Wireless traffic light Receiver.
#include <SPI.h>
#include "RF24.h"
  radio.begin();
  radio.openReadingPipe(1,pipe); //Open pipe to base node for communication
  radio.startListening(); //Starting to listen to base node
  delay(40);
void loop(void){
  if (radio.available()){ // if Radio available start Communication
    bool done = false;
    while (!done){
      done = radio.read(msg, 1);  // if done read msg
      Serial.println(msg[0]); // print msg
      if (msg[0] == 001){delay(10); // if msg 0 is 001 light red will start
      digitalWrite(orange, LOW);
      digitalWrite(green, LOW);
 //     delay(1000);}
      if (msg[0] == 002){delay(10);// if msg 0 is 002 light orange will start
      digitalWrite(red, LOW);
 //     delay(1000);}
      if (msg[0] == 003){delay(10);// if msg 0 is 001 light red will start
//      delay(1000);}
  else{Serial.println("No radio available");}}
