Another one of them TFT issues thread :smiley-confuse:
Hello,
I am having an issue with my TFT touch screen on my arduino Mega, i am sorry as i know there are many more threads but i always find that people have different setups to my self.
you will have to forgive me as i am completely new to all of this, but i have a basic understanding.. Very basic :frowning:
I have a:
Arduino Mega 2560 R3
Elec freaks V2.2 Sheild
TFT_320QVT_9341
I was having issues to begin with regarding a white screen, i changed the parameters on the setup and now i have a display!! but now i have an inverted Axis, im sure that my issue is somewhere to do with the parameters not being correct, can anyone shed any light on this please??
i can attach pictures if needed!!
i have test ran a program from the UTFT Library which is "text rotation" and my number "150" looks like 120
Any help would be greatly appreciated
:slight_smile: :slight_smile:
The official UTFT library does not support the ILI9341 in 16-bit parallel.
TFTLCDCyg has posted a modified library in this message
I suggest that you try it for yourself. And hope that the next official release of UTFT supports your display.
David.
Thanks very much David, I'll try that when I get chance and let you know if it works
Thank you David_prentice
I dont suppose you might also be able to point me in the right direction of a Touch Library that works for my screen also please?? UTouch doesnt seem to be working with an example i have uploaded :confused:
As far as I know, your 40-pin display, the Elecfreaks adapter shield and the UTouch examples will default to the correct pins for your XPT2046 Touch controller.
So I would guess that you just need to specify the UTFT constructor for your ILI9341_16 model and the UTouch examples will work.
If you discover that your Shield maps the XPT2046 pins differently, you need to change the UTouch constructor accordingly.
Although TFTLCDCyg shows a horrific photo of hand-wiring his display, I bet that he uses an Adapter Shield in real life. And he probably uses the same one as you.
David.
Thank you David, i didnt reply as i was working on getting it working, i found an example that works and have adapted it and changed it until i have what i was after :slight_smile:
Thank You!!
