Hello everyone. Currently my ANT BMS sometimes works, and sometimes won't communicate with my arduino nano. I thought there's hardware issues so i did hardware debugging (checking for loose wire, etc) for a while. Then my ant bms started to sending data again to my arduino normally.
But after i turn off my arduino and turning on again, the ANT BMS won't sending data to my arduino nano. I don't know why because in the previous experiment was succesful. Any idea why? This my code. Thank you.
#include <stdint.h>
#include <SoftwareSerial.h>
#define RX 8 // Arduino defined pin (PB0, package pin #5)
#define TX 9 // Arduino defined pin (PB1, package pin #6)
SoftwareSerial mySerial(RX, TX);
const unsigned char request_bms[] = {0x5A,0x5A,0x00,0x00,0x00,0x00};
unsigned long heartbeatMillis, timeoutMillis;
unsigned char serialBuffer[140];
unsigned int serialCursor = 0;
int current = 0;
uint16_t voltage = 0;
int16_t temperature = 0;
uint8_t percentage = 0;
memset(serialBuffer, 0, sizeof(serialBuffer));
mySerial.begin(19200);
Serial.println("Ready!");
const unsigned long currentMillis = millis();
const unsigned long deltaTimeoutMillis = currentMillis - timeoutMillis;
if (serialCursor > sizeof(serialBuffer))
serialCursor = 0;
if (deltaTimeoutMillis > 500) {
for (unsigned int i = 0; i < sizeof(request_bms); i++)
mySerial.write(request_bms[i]);
mySerial.flush();
Serial.println("Requesting...");
timeoutMillis = currentMillis;
serialCursor = 0;
unsigned int serialRemaining = mySerial.available();
if ((serialRemaining + serialCursor) > sizeof(serialBuffer)) {
serialRemaining = sizeof(serialBuffer) - serialCursor;
while (serialRemaining) {
if (serialCursor >= 140) break;
unsigned char eachByte = mySerial.read();
serialRemaining--;
if (serialCursor == 3) {
bool isInvalid = (serialBuffer[0] != 0xAA)
|| (serialBuffer[1] != 0x55)
|| (serialBuffer[2] != 0xAA)
|| (eachByte != 0xFF);
if (isInvalid) {
Serial.println("Wrong start byte, retrying...");
serialCursor = 0;
continue;
//Serial.print("Cursor: ");
//Serial.println(serialCursor);
serialBuffer[serialCursor] = eachByte;
serialCursor++;
if (serialCursor != 140)
return;
serialCursor = 0;
uint16_t calculatedChecksum = 0;
for (unsigned int i = 4; i < 138; i++)
calculatedChecksum += serialBuffer[i];
uint16_t expectedChecksum = (serialBuffer[138] << 8) + serialBuffer[139];
if (calculatedChecksum != expectedChecksum) {
Serial.println("Data corrupted.");
return;
current = serialBuffer[70];
current <<= 8;
current |= serialBuffer[71];
current <<= 8;
current |= serialBuffer[72];
current <<= 8;
current |= serialBuffer[73];
Serial.print("Current: ");
Serial.println(current);
percentage = serialBuffer[74];
Serial.print("SoC: ");
Serial.println(percentage);
temperature = serialBuffer[91];
temperature <<= 8;
temperature |= serialBuffer[92];
Serial.print("Temperature: ");
Serial.println(temperature);
voltage = serialBuffer[121];
voltage <<= 8;
voltage |= serialBuffer[122];
voltage = ((float)voltage) * (20.F / 1000.F);
Serial.print("Voltage: ");
Serial.println(voltage);
