antenna range and power
Hi forum, Is it possible to find the distance between transmitter and receiver using arduino. Also is the power calculation possible. Please suggest a good set up. Thanks in advance, bharath :) ;D
I believe the XBee modules can calculate range (roughly). You can do this using X-CTU at least. I presume you can do this when they're not connected to a computer.
What do you mean?
A lot depends on the location of the system and what blocking / reflecting objects are in the path. It is not as easy as it sounds. What sort of distance and what sort of accuracy are you after?
If there was a GPS on each end for each arduino to get its location, the math to do the distance calculation between 2 points is pretty straightforward. Given that each point has view of the sky to see satellites. And probably limited to 100' accuracy (or whatever the dithering is they have built in these days). Or the operator could enter each arduinos lat/long coordinates.
There’s a lot of variables here.
Are the transmitter (Tx) and receiver (Rx) allowed to talk to each other? If so, then this gets easier. We know radio waves travel at the speed of light in air so then distance = speed x time. You record the time the signal is sent and the time the signal is received; the difference is the time it took it to get to the Rx. Multiply that by speed of light in air (almost a constant, if you really wanted to get picky you could measure the temperature and get the exact value) and you know distance. But this takes very precise measurements. Light travels very fast and your equipment has to be spot on otherwise your margin for error is huge.
Power calculation is best done at the Tx end… it’s kind of possible to measure as a Rx, but it’s not as accurate. What kind of waves are you collecting? Ground, air, sky? Anything that goes into the Ionosphere gets tricky/not reliable as far as calculating power to transmit. Also what band are you collecting? HF, VHF, UHF? All of that plays into how successful you’ll be. This isn’t an easy thing to do.
But all of that said, I wouldn’t use an Arduino to do this. You need serious antennas and I wouldn’t have the slightest clue how to hook up a DF array to an arduino. You’d want a laptop with dedicated software.
This is a big endeavor here, not a weekend project and it requires a lot of knowledge of the electromagnetic spectrum, along with some physics knowledge and math that I wouldn’t call necessarily hard, but it’s things you wont find in a high school math book at the local library. I would suggest finding a local ham radio operator and asking to have them explain their gear. Most hams love talking about their gear, then after you get on their good side ask them about finding distances and power to transmit from somebody else’s antenna.
thanks everyone for the reply. I need some sort of antenna tracking mobile Robot. I don't know how to do that. Any suggestions would be helpful.
Vicky,
You haven’t given us enough to go on to help you out.
Having an antenna that can zero in on the transmission source is one big project. RF? Infrared? Sound?
Building a robot is another. You haven’t mentioned inside/outside/terrain/obstacles/etc.
Why not start with one or the other?
Check out the mobile robots at pololu.com, will be on sale this weekend, that could be a good starting point.
One of natures warning signs is that if what you want to do is simple and practical, you would find a lot of info on the net on how to do it. I doubt that what you want to do with radio location is going to happen.
