[ANY ADVICE WOULD BE GOOD] How do I use 4 FSRs that have an indepent LED common Cathode?
Hello,
The Arduinos I have are both the uno and/or a Mega Rev3
I am very new to using an Arduino and coding but this is vital part of my current project for school. I am responsible or coding 4 independent FSR sensors that when 0.617 psi is applied a corresponding LED common cathode will light up to signal that the user is applying too much pressure to that given area. So I apologize in advance for the multitude of questions I am about to ask:
  1. How do I first of all set up and code a single FSR to this specification to cause a light to turn on at that threshold?
  2. Any suggestions on how to best set up breadboard(or boards)
  3. How do I find out battery power required?
Have a look here - Using an FSR | Force Sensitive Resistor (FSR) | Adafruit Learning System
Put together and post a preliminary schematic, not a frizzy picture and post links to each of the hardware items that give technical information. Since this is a group project what resources of the processor are available to you (timers, piins, etc)? This will take a few passes but you will resolve the problem and be able to explain your solution.
Sure. Don't use Uno or Mega with breadboards. Use an Arduino that is breadboard compatible, like Nano.
You can quite easily connect either a Uno or a Mega to a breadboard. The OP also said he had a Uno and /or a Mega at hand. I think the main thing the OP needs to do is to have a good read of - Using an FSR | Force Sensitive Resistor (FSR) | Adafruit Learning System - as pretty much everything is explained in a step-by-step fashion there. :slight_smile:
Show me a picture of that. And no sneaky cheating with wires!
:grinning: No cheating? Well I'm afraid I'd cheat and use hook up wires. But yes, a nano will slot right in. (It's actually my "goto" for most projects as I like it's diminutive form factor!)
Hook_up_wires
