Robin2:
If you have not already done so you need to write a short program to receive data using Bluetooth and display it on the Serial Monitor. Your Phone app probably just needs to send 'U' for unlock and 'L' for lock. The first example in Serial Input Basics is intended for that sort of simple system.
When you can receive the characters from the phone you probably just need some code to use make your variable buttonState = HIGH or LOW as approporiate depending on the character received.
...R
First off all thanks you very much for your help, much needed,
I can now successfully receive characters on serial monitor, with this code hopefully i did added it correct under Void Loop.
Working:
#include <Servo.h>
String message; //string that stores the incoming message
// constant variables used to set servo angles, in degrees
const int straight = 50;
const int divergent = 145;
// constant variables holding the ids of the pins we are using
const int divergent_led = 6;
const int straight_led = 7;
const int buttonpin = 8;
const int bluetoothclick = 3;
const int servopin = 9;
// servo movement step delay, in milliseconds
const int step_delay = 10;
// create a servo object
Servo myservo;
// global variables to store servo position
int pos = straight; // current
int old_pos = pos; // previous
// set the mode for the digital pins in use
pinMode(buttonpin, INPUT);
pinMode(straight_led, OUTPUT);
pinMode(divergent_led, OUTPUT);
Serial.begin(9600); //set baud rate
// setup the servo
myservo.attach(servopin); // attach to the servo on pin 9
myservo.write(pos); // set the initial servo position
// set initial led states
digitalWrite(straight_led, HIGH);
digitalWrite(divergent_led, LOW);
while(Serial.available())
{//while there is data available on the serial monitor
message+=char(Serial.read());//store string from serial command
if(!Serial.available())
if(message!="")
{//if data is available
Serial.println(message); //show the data
message=""; //clear the data
delay(5000); //delay
// start each iteration of the loop by reading the button
// if the button is pressed (reads HIGH), move the servo
int button_state = digitalRead(buttonpin);
if(button_state == HIGH){
// turn off the lit led
if(pos == straight){
digitalWrite(straight_led, LOW);
old_pos = pos; // save the current position
// Toggle the position to the opposite value
pos = pos == straight ? divergent: straight;
// Move the servo to its new position
if(old_pos < pos){ // if the new angle is higher
// increment the servo position from oldpos to pos
for(int i = old_pos + 1; i <= pos; i++){
myservo.write(i); // write the next position to the servo
delay(step_delay); // wait
} else { // otherwise the new angle is equal or lower
// decrement the servo position from oldpos to pos
for(int i = old_pos - 1; i >= pos; i--){
// turn on the appropriate LED.
digitalWrite(divergent_led, HIGH);
}// end of loop
So after I got that, I tried to fumble it to working as I would say ,
and ended up with this code and that does not work, It will not receive any characters,
I dont think its the right way I done below, But my idea was from bluetooth to trigger a shorting on the switch, ?
Hope It make sense .. thanks !
#include <Servo.h>
const int clicker = 3; // New extra wire to trigger bluetooth
Servo myservo;
pinMode(clicker, OUTPUT); // New extra wire to ground trigger
// setup the servo
if(message!="L")
digitalWrite(3, LOW); // Should trigger it from bluetooth ?????
}// end of loop
